Maxwell Eqns - Prob converting from fundamental to time-harmonic form
In summary, the textbook does not explicitly show how to derive the time-harmonic form of the Maxwell equations from the original, time-dependent form. However, if we assume that the time-varying form of the field is represented by a real part and a complex part, then the time-harmonic form of the field is usually preferred because it is a more general solution of the wave equation. Furthermore, j, the imaginary unit used in the definitions of E and B, is not the current density vector but just another way of defining imaginaries. Finally, the time-harmonic forms of the field can be represented by a sum of time-independent E- and B-fields.
JamesGoh
143
Hi all
Im trying to derive the time-harmonic form of the Maxwell equations from the original, time-dependent form, however I am not sure if my working and logic is correct
e.g. for
[tex]\nabla\times E = -dB/dt[/tex]
I want to be able to get
[tex]\nabla\times \vec{E}[/tex] = [tex]-j\omega\vec{B}[/tex]
where
[tex]E[/tex] = time-varying form of E-field
[tex]B[/tex] = time-varying form of applied magnetic field (is this the correct assumption ?)
[tex]\vec{E}[/tex] = time-harmonic form of E field
[tex]\vec{B}[/tex] = time-harmonic form of applied magnetic field
The textbook has given the relationship between the time-varying and time-harmonic forms of the field as follows
[tex]E = [/tex] Re([tex]\vec{E}[/tex]ej*[tex]\omega[/tex]*t) (1.1)
[tex]B = [/tex] Re([tex]\vec{B}[/tex]ej*[tex]\omega[/tex]*t) (1.2)
where Re() = real part of complex number
However, if this is the case, [tex]E = \vec{E}cos(\omega*t)[/tex] will be true and given that there is a time-derivative to the RHS of the time-varying equation (which is going to produce [tex]dB/dt = -\omega*\vec{B}sin(\omega*t)[/tex]), it would be impossible to get the time-harmonic form, as you have cosine on one side and sine() on the other.
The textbook simply substitutes the time-harmonic version over its time-varying version and differentiates the
[tex]B = [/tex] [tex]\vec{B}[/tex]ej*[tex]\omega[/tex]*t
term and
eliminates the common e(j*[tex]\omega[/tex]*t) on both sides, however I cannot seem to see the link between this and the equations linking the time-varying and time-harmonic forms, What could I possibly be doing wrong or misunderstand ?
Shouln't your omega be a vector?
Whats your reasoning behind why omega should be a vector ?
I wonder if the textbook is causing confusion by not explaining how an arbitrary time-varyng function can (usually) be represented as a sum of time-harmonic functions. OTOH, the relationships you gave for time-varying vs. time-harmonic are very simple, so perhaps not.
In any case, the time-harmonic form is usually preferred becasue it's a more general solution ot the wave equation.
E is a scalar from equation 1.1; because it is the real part of something... But it should be a vector if a crossproduct can be made. That is my confusion 1
Could it be that j is not the current density vector, but just the other way of defining imaginaries (used by physici) so the direction i, at right angle with the real axis?
Then omega indeed no vector yet it has the possibility to vary, and in the first equation I see a total derivative of the magnetic field... It should be a partial derivative to time...
yeah j = sqrt(-1). I am more used to j then i since I come from an Elec Eng background
Ok I realized just then from re-reading the book that I made a slip-up in the definitions
[tex]\vec{E}[/tex] = E-field in terms of spatial coordinates (e.g. cartesian system) only
[tex]\vec{B}[/tex] = Applied magnetic field in terms of spatial coordinates only
To avoid more potential confusion * = scalar multiplication
Also, the textbook does not show how arbitrary time-varyng function can be represented as a sum of time-harmonic functions.
I think better notation for the time-harmonic forms would be:
[tex]\vec{E}(\vec{r},t)=\Re[ \widetilde{E}(\vec{r},t)]=\Re[\vec{E}_0(\vec{r}) e^{j \omega t}][/tex]
[tex]\vec{B}(\vec{r},t)=\Re[ \widetilde{B}(\vec{r},t)]=\Re[\vec{B}_0(\vec{r}) e^{j \omega t}][/tex]
Where [itex]\vec{E}_0(\vec{r})[/itex] and [itex]\vec{B}_0(\vec{r})[/itex] are time-independent E- and B-fields AND [tex]\widetilde{E}(\vec{r},t)=\vec{E}_0(\vec{r}) e^{j \omega t}[/tex] and [tex]\widetilde{B}(\vec{r},t)=\vec{B}_0(\vec{r}) e^{j \omega t}[/tex] are the complex time-harmonic E- and B-fields
The reason that you can represent any time dependent electric and magnetic field by an infinite sum these time-harmonic fields is that the set of these time-harmonic fields over all possible frequencies [itex]\omega[/itex] is a complete set of orthogonal functions , and in general you can represent any continuous, differentiable function by a linear combination of orthogonal functions like this (similar to a Fourier series)...This is why studying the time-harmonic fields is a good indicator of the behavior of any general time-dependent field.
...Now, when you apply maxwell's law's to the time-harmonic fields, you actually want to deal with the complex time-harmonic fields [tex]\widetilde{E}(\vec{r},t)[/tex] and [tex]\widetilde{B}(\vec{r},t)[/tex]...that should give you your desired forms of the maxwell equations.
My apologies, but I'm having trouble seeing exactly what your question is; maybe you can clarify specifically what you are uncomfortable with. Regardless, let me see if I can help. You seem to have problem with the RHS of the Faraday law. In the general form, you (correctly) found the RHS to give you
[tex]\frac{dB}{dt}=-\omega B _0 sin(\omega t)[/tex]
Now consider the time-harmonic expression for B
[tex]B=Re( B _0 e^{i \omega t} )[/tex]
Then the time-derivative is
[tex]\frac{dB}{dt}=Re( i \omega B _0 e^{i \omega t} )[/tex]
Isn't this the same as the first equation?
Is that what you were asking?
Um basically what I want to do is derive the time-harmonic form of maxwell's equations from the fundamental form strictly using (1.1) and (1.2).
My problem came from the fact that to get the fundamental form of the field, you have to take the real part of the time-independent part when multiplied with the phasor.
When you say "time-harmonic" the implicit assumption is that the (magnetic) field can be written in the following form:
(1) [tex]B=B_0 cos \omega [/tex]
where B0 is a function of position only. The same idea follows for the electric field.
Concentrating on the magnetic field, the foregoing equation can be written as
(2) [tex]B=Re(B_0 e^{i \omega t})[/tex]
For convenience, we often write simply:
(3) [tex]B=B_0 e^{i \omega t}[/tex]
where it is understood that we will take the real part at the end.
So, for example, Faraday's law:
(4) [tex] \nabla\times E=-\frac{dB}{dt}[/tex]
We may plug in the time-harmonic form of the fields on both sides and it is understood that at the very end we will take the real part of the entire equation.
Also, substitute (3) into the RHS of (4). This will give you the time-harmonic form of Faraday's law. Is this what you were asking?
Yep that makes sense. thanks heaps everyone :)
Related to Maxwell Eqns - Prob converting from fundamental to time-harmonic form
1. What are Maxwell's equations?
Maxwell's equations are a set of four fundamental equations in classical electromagnetism that describe the relationship between electric and magnetic fields, electric charges, and currents. They were first derived by James Clerk Maxwell in the 19th century and are essential for understanding the behavior of electromagnetic waves.
2. What is the fundamental form of Maxwell's equations?
The fundamental form of Maxwell's equations expresses the relationships between electric and magnetic fields, electric charge, and current in their original, differential form. These equations are used to describe the behavior of electromagnetic fields in space.
3. What is the time-harmonic form of Maxwell's equations?
The time-harmonic form of Maxwell's equations is a simplified version of the fundamental form that is often used in practical applications. It describes the behavior of electromagnetic fields in terms of their frequency and phase, rather than their spatial coordinates. This form is particularly useful for analyzing electromagnetic waves in different media.
4. How do you convert from the fundamental to the time-harmonic form of Maxwell's equations?
To convert from the fundamental to the time-harmonic form of Maxwell's equations, the differential equations for the electric and magnetic fields are replaced with their corresponding complex forms, and the time derivative is replaced with the imaginary unit, i. This transformation simplifies the equations and allows for easier analysis of electromagnetic wave behavior.
5. Why is it important to convert from the fundamental to the time-harmonic form of Maxwell's equations?
The time-harmonic form of Maxwell's equations is often easier to work with, especially in practical applications. It allows for a better understanding of the behavior of electromagnetic waves and their interactions with different materials. Additionally, it is the basis for many important concepts in electromagnetism, such as impedance and reflection coefficients.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
