Metal sphere drawn and then repelled by charged rod
When a positively charged glass rod is brought near an uncharged metal sphere, the sphere is attracted due to the rod's positive charge attracting the sphere's negative charges while repelling its positive charges. Upon contact, some electrons may transfer from the sphere to the rod, slightly neutralizing the rod's charge and making the sphere positively charged. Once both objects are positively charged, the sphere is repelled by the rod due to like charges repelling each other. The discussion highlights the importance of charge transfer, even in nonconducting materials, and the role of electric fields in attraction and repulsion. This phenomenon illustrates fundamental principles of electrostatics.
MonkeyDLuffy
An uncharged metal sphere hangs from a nylon thread. When a positively charged, nonconducting glass rod is brought close to the metal sphere, the sphere is drawn toward the rod. But if the sphere touches the rod, the sphere suddenly flies away from the rod. Explain why the sphere is first attracted and then repelled.
Assuming there are only horizontal components making a contribution,
a = the distance from the rod to a point on the sphere
L = the length of the rod
Q = total charge
k = constant
Ex = (kQ) / (a2 + aL)
[/B]
At first the sphere is attracted by the rod because the positive charge on the rod attracts the negative charge on the sphere while repelling the positive charge on the sphere. This part I understand.
Initially I thought that when sphere touched the rod the excess positive charge would flow into the sphere and the rod would repel the sphere. However, because the rod is nonconducting there should be no flow of charge.
In another attempt I thought that perhaps when the sphere made contact with the rod, then it was close enough for the electric field which repels the sphere to overcome the electric field which attracts the sphere. But if the repulsive field increases, I'm assuming the attractive field is increasing at the same rate.
From here I'm not sure what other angles I can look at this from. Could it be the case the rod is not perfectly non conducting so some positive charge does flow into the sphere and thus the repulsion occurs?
That alone is not sufficient. The positive and negative charge have the same charge (in magnitude). The effect you are looking for needs one step more.
Positive charges are nuclei of atoms, those don't move in solids. The rod might not be a good conductor, but there are no perfect insulators. Some charge will be transferred.
mfb is absolutely correct, what moves around are electrons (negatively charged). I can conceive that upon contact, some electrons move from the sphere to the non-conducting rod, but not much though, and the potential of the non-conducting rod remains positive, even though it is now a little less than it started. That will be enough though to make the sphere positively charged.
Now that both objects are positively charged, you can guess what happens next!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
