Does the Michelson-Morley Experiment Solely Confirm Constant Light Speed?
  • I
  • Thread starter LSMOG
  • Tags
    Experiment
In summary: So basically, rotating the interferometer continuously won't cause the waves to phase shift even if their speeds are different?Thanks a looooooot! So basically, rotating the interferometer continuously won't cause the waves to phase shift even if their speeds are different?In summary, even though the two waves are traveling at different speeds, they maintain a constant phase relationship after they are recombined at the beam splitter.
LSMOG
62
In Michelson-Morley experiment, the two light beams arrive in phase at the detector, so they say this means waves are traveling at the same speeds because they arrive in phase at the detector,
What if the waves started in phase and their path difference is an integer multiple of the wave lengths (meaning they will arrive in phase at the detector too).
I am arguing that same speed is not the only condition for constructive interference.
While this is true, it does nothing for the interpretation of the experiment. The point is that the interference pattern does not change when the device is rotated. There is also no a priori requirement that the interference should be constructive.
Likes vanhees71
But then you rotate the experiment and the relative velocities change (or, more precisely, Michelson and Morley expected them to change).
Also, with a bit of practice it's fairly easy to recognise the zero path difference fringe. Due to finite coherence times, it has the strongest contrast between it and the adjacent minima (black/white rather than dark grey/light grey).
Likes vanhees71
Okay thanks, I think its becoming clear now. Is it possible for two waves traveling at different speeds to be in phase? Why?
Even under the ether model Michelson and Morley assumed, the waves are traveling at the same speed in the output arm because they're traveling in the same direction. They would pick up a phase difference inside the interferometer, but would then maintain a constant phase relation after they were recombined at the beam splitter.
Now I think my problem is solved! This means getting bright fringe at the detector means there has been no such phase difference even if the interferometer was rotated CONTINUOUSLY in all angles??
You would typically zero your interferometer at a bright fringe, then show that you had a bright fringe at all angles and in all seasons, yes. Strictly, the bright fringe isn't necessary - an unchanging fringe is all you need. Practically, though, the brightest thing is the easiest to find and track.
Thanks a looooooot!
Related to Does the Michelson-Morley Experiment Solely Confirm Constant Light Speed?
1. What is the Michelson-Morley experiment?
The Michelson-Morley experiment was a scientific experiment conducted in 1887 by Albert Michelson and Edward Morley to measure the speed of light and detect the presence of the hypothetical "ether" that was believed to be the medium through which light waves traveled.
2. What were the results of the Michelson-Morley experiment?
The results of the experiment were unexpected and groundbreaking. They showed that the speed of light was the same in all directions, regardless of the Earth's motion around the Sun. This disproved the existence of the ether and provided evidence for Albert Einstein's theory of special relativity.
3. How was the Michelson-Morley experiment conducted?
The experiment involved splitting a beam of light into two perpendicular paths, one parallel to the Earth's motion and one perpendicular to it. The light beams were then recombined and the interference pattern was observed with the use of a sensitive instrument called an interferometer.
4. Why is the Michelson-Morley experiment important?
The Michelson-Morley experiment was important because it provided evidence against the existence of the ether and contributed to the development of the theory of special relativity, which revolutionized our understanding of space and time. It also paved the way for further experiments and discoveries in the field of physics.
5. Are there any modern applications of the Michelson-Morley experiment?
While the original experiment is no longer conducted, the principles and techniques used in the Michelson-Morley experiment are still important in modern physics. They have been applied in various experiments and technologies, such as the Global Positioning System (GPS), which relies on the constancy of the speed of light to determine location and time.
