Molecular formula of hydrocarbon
In summary, the conversation is discussing the calculation of the molecular formula of a gaseous hydrocarbon using the volume of oxygen required for complete combustion and the resulting volume of carbon dioxide. The attempt at a solution involved finding the greatest common divisor, but it was determined to be incorrect. The correct approach involves creating a balanced equation with variables for carbon and hydrogen, and then solving for the molecular formula in terms of x and y. The final equation provided by the CCEA specification is CxHy + (x+y/4)O2 --> xCO2 + y/2H2O.
Sam_
0.1 dm^3 of a gaseous hydrocarbon may require 0.45 dm^3 of oxygen for a complete combustion to give 300 cm^3 of Carbon dioxide. All volumes are measured in the same environment. Calculate the molecular formula of the hydrocarbon.
i tried getting the gdc of 10, 30 and 45 =90. and the have like
9 CxHy + 2 O2 --> 3 CO2 + H2O
but I cannot go further than this. please help. Thanks.
as for the formula you have taken.. i don't understand why you've taken the GCD, but it is fundamentally wrong as the oxygen is not balanced on both sides [and neither is carbon or hydrogen].
What you need is a equation which is prefixed and suffixed by variables on both the sides to get you a linear equation which you can then solve...
Can you think of a way to calculate the amount of carbon in CO2 and hydrogen in H2O? You have a good start here:
CxHy + O2 --> CO2 + H2O
I've removed the prefixes you had (the '9', '2' and '3'). Can you solve it in terms of 'x' and 'y'?
CxHy + (x+y/4)O2 --> xCO2 +y/2H2O
thats the correct answer from ccea spec for alevel chemistry =]
What is the molecular formula of hydrocarbon?
The molecular formula of hydrocarbon is CnH2n+2, where n is the number of carbon atoms in the molecule. This formula represents the ratio of carbon and hydrogen atoms present in a hydrocarbon compound.
How is the molecular formula of hydrocarbon determined?
The molecular formula of hydrocarbon is determined by analyzing the structure of the molecule and counting the number of carbon and hydrogen atoms present. This can be done through techniques such as spectroscopy and mass spectrometry.
What is the significance of the molecular formula of hydrocarbon?
The molecular formula of hydrocarbon provides important information about the structure, properties, and behavior of the compound. It helps in identifying the type and number of atoms present, as well as predicting the physical and chemical properties of the molecule.
What are some common examples of hydrocarbons?
Some common examples of hydrocarbons include methane (CH4), propane (C3H8), and octane (C8H18). These compounds are commonly found in natural gas, gasoline, and other fossil fuels.
How does the molecular formula of hydrocarbon relate to its structural formula?
The molecular formula of hydrocarbon provides the overall ratio of carbon and hydrogen atoms, while the structural formula shows the specific arrangement of these atoms in the molecule. The structural formula can be derived from the molecular formula by considering the valency of each atom.
  • Mechanical Engineering
