Molecular Hydrogen Ionization
In summary, an electrostatic field of 1488 kJ/mol would be needed to ionize all of the H2 molecules at a distance of d from the source of the field. This would be difficult to do because the ionization energy for H2 is 15.4 eV. However, using microwaves could be a way to do it if the radiation is intense enough.
Misha Kuznetsov
49
The ionization energy of H2 is 1488 kJ/mol. How strong of a DC electrostatic field would be need to ionize H2 molecules all at a distance 'd' from the source of the field? What I am asking is how to convert the known unit (joule) into a measure of an electrostatic field since electric fields are expressed in Newtons per coulomb or volts per meter.
Would this be easier to do if the ionization energy was in eV rather than in joules? (It is approximately 15.4 eV)
I need to know how to do this for a personal project, not for homework.
Thank you.
You can't convert the electric field to an energy. You have to calculate the probability of ionization for the molecule placed in a given electric field. See tunnel ionization.
As far as I know, there is no way you can create in practice a DC field strong enough to actually ionize H2.
In that case, what would be a practical way to do it? I read something about using microwaves, could that work to do it?
If what you read seems trustworthy, that is it presents experimental data, then it worths a try. Just one thing for sure, you will need a system that is able to produce very strong microwave radiation because the ionization energy you mentioned above cannot be overcome by photon energy of microwave field.
Can anyone recommend a way to ionize very small volumes of hydrogen gas that is both effective, and more importantly, not too energy consuming? By small volume, I mean no more than a few hundred molecules at STP. In the case of multiphoton ionization, does each photon have to have lots of energy?
On the contrary, multiphoton ionization takes place when photon energy (## \hbar \omega ##) is less than ionization energy. Therefore it takes multiple of photons for them to add up their individual energy so that the sum can surpass the ionization energy. However the ionization rate of multiphoton ionization strongly depends on the light's intensity, that's why when using laser, short pulse and tight focusing are required.
One photon ionization is another way to ionize thing as long as one photon energy is sufficient to exceed the ionization potential, in the case of 15.4 eV potential you need to provide radiation within XUV range. However working in UV region down to shorter wavelengths requires evacuating the system (such as using vacuum chamber) because air molecules heavly absorbs photons with short wavelengths.
Likes Misha Kuznetsov
In the olden olden days, people studied H2+ molecular ion. Looking at Herzberg's Diatomics yields: H. Beutler and H. O. Juenger, Z. Physik 101, 304 (1936); O. W. Richardson, Proc. Roy. Soc. London 152, 503 (1935); O. W. Richardson, Nuovo cimento, 15, 232 (1938).
A very nice review article on the spectroscopy of molecular ions has references for experimental work on H2+ as well as HD+. The original papers will describe how they produced the ions -- generally an electric discharge is used to produce the ions (electron impact ionization). It is very difficult to make ca. 15eV photons, but not so hard to make 15eV electrons with which to ionize the H2.
http://www.cchem.berkeley.edu/rjsgrp/publications/papers/1980-1983/13_saykally_1981.pdf
Likes DrClaude and Misha Kuznetsov
What is molecular hydrogen ionization?
Molecular hydrogen ionization is a process in which a hydrogen molecule (H2) loses an electron and becomes a positively charged ion (H+). This can occur through various methods, such as exposure to high-energy radiation or chemical reactions with other molecules.
Why is molecular hydrogen ionization important?
Molecular hydrogen ionization is important because it plays a crucial role in many chemical and physical processes. It is involved in the formation of ions in the Earth's atmosphere, which affects weather patterns and the ozone layer. It also plays a key role in the formation of stars and other celestial bodies in space.
How does molecular hydrogen ionization occur?
Molecular hydrogen ionization can occur through several processes, including photoionization (where a photon of light is absorbed and an electron is ejected), collisional ionization (where a high-energy particle collides with a molecule and causes an electron to be ejected), and chemical reactions (where a molecule reacts with another molecule, causing an electron to be transferred).
What are the effects of molecular hydrogen ionization on living organisms?
Molecular hydrogen ionization can have both positive and negative effects on living organisms. On one hand, it plays a crucial role in photosynthesis, which is the process by which plants and other organisms convert sunlight into energy. On the other hand, it can also be harmful to living cells by causing damage to DNA and other molecules.
How is molecular hydrogen ionization studied?
Molecular hydrogen ionization is studied through various methods, including laboratory experiments, computer simulations, and observations of natural phenomena. Scientists use specialized equipment and techniques to create and measure ionization in controlled environments, and also study the effects of ionization on different substances and organisms.
  • Astronomy and Astrophysics
  • Atomic and Condensed Matter
