Multivariate gaussian integral
In summary, the multivariate gaussian integral over a vector x with an arbitrary vector a as upper limit and minus infinity as lower limit can be solved using methods such as Cholesky decomposition or spectral decomposition. These methods involve transforming the integral into a standard multivariate gaussian integral with a diagonal covariance matrix, which can then be solved using standard methods. If an analytical solution cannot be found, numerical methods may be used. For more information, consult a textbook on multivariate calculus or probability theory.
Alexandra97
I am looking for the solution of a multivariate gaussian integral over a vector x with an arbitrary vector a as upper limit and minus infinity as lower limit. The dimension of the vectors x and a are p $\times$ 1 and T is a positive definite symmetric p $\times$ p matrix. The integral is the following:
$$\int_{x=-\infty}^{x=a} x e^{ (-0.5 x'T^{-1}x)} d^p\bf{x}$$
I have tried to solve it with the cholesky decomposition and substitution with the Jacobian, but the dimension of the solution is not a p $\times$ 1 vector. When a equals $\infty$ the solution is of course an p $\times$ 1 vector of zero's (since it is the expected value).
Since I am not very experienced in integrating over vectors, also a good reference about this subject would be greatly appreciated.
Thank you for your question regarding the multivariate gaussian integral. This type of integral is commonly encountered in many fields of science and mathematics, and there are several methods for solving it.
One approach to solving this integral is by using the Cholesky decomposition, as you have mentioned. This method involves decomposing the covariance matrix T into a lower triangular matrix L such that T = LL'. Then, by making a change of variables x = Ly, the integral can be transformed into a standard multivariate gaussian integral with a diagonal covariance matrix. This can be solved using standard methods, and the resulting solution will be a p $\times$ 1 vector.
Another approach is by using the spectral decomposition of T. This involves diagonalizing T into a matrix UDU', where U is an orthogonal matrix and D is a diagonal matrix containing the eigenvalues of T. The integral can then be transformed into a standard multivariate gaussian integral with a diagonal covariance matrix by making a change of variables x = Uy. Again, this can be solved using standard methods, and the resulting solution will be a p $\times$ 1 vector.
It is also worth mentioning that there are numerical methods for solving this type of integral, such as Monte Carlo integration or numerical quadrature methods. These methods may be useful if an analytical solution cannot be found.
As for references, a good textbook on multivariate calculus or probability theory may provide more detailed explanations and examples of how to solve this type of integral. Some recommended textbooks include "Multivariate Calculus" by James Stewart and "Probability and Random Processes" by Geoffrey Grimmett and David Stirzaker.
I hope this helps and good luck with your integration!
1. What is a multivariate gaussian integral?
A multivariate gaussian integral is a mathematical concept used in statistics and probability theory to calculate the probability density function of a multivariate normal distribution. It involves integrating a function over multiple variables, typically with a mean and covariance matrix.
2. How is a multivariate gaussian integral different from a univariate gaussian integral?
A multivariate gaussian integral involves integrating over multiple variables, while a univariate gaussian integral only involves one variable. Additionally, the multivariate gaussian integral uses a covariance matrix to account for the correlation between variables, while the univariate gaussian integral uses a variance term.
3. What is the significance of a multivariate gaussian integral in statistics?
The multivariate gaussian integral is important in statistics because it allows for the calculation of probabilities for multiple variables, taking into account their correlation. This is useful in many applications, such as in finance, where variables are often correlated.
4. How is a multivariate gaussian integral used in machine learning?
In machine learning, the multivariate gaussian integral is used to model data with multiple features. It is commonly used in algorithms such as linear regression and Gaussian naive Bayes classification.
5. Are there any limitations to using a multivariate gaussian integral?
One limitation of the multivariate gaussian integral is that it assumes a normal distribution, which may not always be the case in real-world data. Additionally, it can become computationally expensive for datasets with a large number of variables.
  • Calculus
