Why Does MATLAB Show NaN for Truss Deflections?
In summary, a matrix in Matlab is a two-dimensional array of numbers or variables represented using square brackets. Matrices can be created using the "[]" brackets and can be accessed and modified using row and column indices. Common operations that can be performed on matrices in Matlab include addition, subtraction, multiplication, and division. Matrices can also be combined or concatenated using the "[]" brackets and either a semicolon or comma.
nate9519
47
I'm using MATLAB to design a truss and the output is suppose to be the deflections caused by the applied loads. But I keep getting "not a number" for my deflections . here is the warnings I get.
Warning: System may be partially constrained.
> In truss3 (line 222)
In truss3ex2 (line 26)
Warning: Matrix is singular to working precision.
> In truss3 (line 224)
relevant lines from truss3 starting at line 219
Matlab:
% Solve the force-displacement equations.AA = [a,zero1;e,d]; BB = [b,zero2]'; detAA = det(AA);
if abs(detAA) < 1e-16
warning('System may be partially constrained.')
end
AAinv = inv(AA); sol = AAinv*BB;
% Prepare the output quantities.
pp = 0;
for i = 1:nJforce(i,1) = i; Jdispl(i,1) = i;
isol = 2*m+p+3*(i-1);
Jdispl(i,2) = sol(isol+1); Jdispl(i,3) = sol(isol+2);
Jdispl(i,4) = sol(isol+3);
[\code][h2]The Attempt at a Solution[/h2]
[/B]
here is the code.
[code=matlab]
% class design project example%
% all of the members are quenched steel
% k = 2000 k-lb, Pmax = 1500 k-lb (A = 100 sq-inch)
clear
n = 24; m = 60; LOADZ = -20000; LOADY = 1000; A = 100;
joint = [0,0,0;0,0,-10;0,0,-20;12,0,0;12,0,-10;12,0,-20;...
0,10,0;0,10,-10;12,10,0;12,10,-10;0,20,0;0,20,-10;...
12,20,0;12,20,-10;0,30,0;0,30,-10;12,30,0;12,30,-10;...
0,40,0;0,40,-10;0,40,-20;12,40,0;12,40,-10;12,40,-20];
assembly = [1,2;1,4;1,7;2,3;2,4;2,5;2,6;2,7;2,8;3,6;3,8;...
4,5;4,9;5,6;5,9;5,10;6,10;7,8;7,9;7,11;8,9;8,10;8,11;...
8,12;9,10;9,13;10,13;10,14;11,12;11,13;11,14;11,15;11,16;...
12,14;12,16;13,14;13,17;13,18;14,18;15,16;15,17;15,19;15,20;...
16,17;16,18;16,20;16,21;17,18;17,22;17,23;18,23;18,24;19,20;...
19,22;20,22;20,23;20,24;21,24;22,23;23,24];
forceJ = [3,1,1,1;3,1,1,1;3,1,1,1;3,1,1,1;3,1,1,1;...
3,1,1,1;-1,0,0,0;-1,0,0,0;...
-1,0,0,0; -1,0,0,0;-1,0,LOADY,LOADZ;-1,0,0,0;...
-1,0,LOADY,LOADZ;-1,0,0,0;-1,0,0,0;-1,0,0,0;-1,0,0,0;-1,0,0,0;...
3,1,1,1;3,1,1,1;3,1,1,1;3,1,1,1;3,1,1,1;3,1,1,1];
for i = 1:m; stretch(i) = 2000*1000; end; stretch(1);
index = 1;
[Jforce,Mforce,Jdispl,Mdispl] = ...                                                ([B]LINE 26)[/B]
truss3(n,m,joint,assembly,forceJ,stretch,index);
peak_klb = 18*A
maxMforce_klb = max(abs(Mforce/1000))
maxJdispl = max(abs(Jdispl*12));
maxDX_in = maxJdispl(2),maxDY_in = maxJdispl(3),maxDZ_in = maxJdispl(4)
[\code]for forceJ, (3,1,1,1) indicates a external joint with 3 reaction forces. (-1,0,0,0) indicates an internal joint with no loads.
Can anyone help me figure out this problem with the matrices? I have no idea what to do
Hi, you want to use ##[##code=matlab##]##
(code goes here)​
##[##\code##]##
to keep it legible:
Matlab:
end
pp = 0;
for i = 1:n
end
% 3. The Attempt at a Solution
% here is the code.
clear
index = 1;
[Jforce,Mforce,Jdispl,Mdispl] = ...                                     %           ([B]LINE 26)[/B]
peak_klb = 18*A
Seems like this is old news.
In order for the stiffness matrix equations to have a solution, at least one or more nodes need to have an initial displacement specified. Thus usually is accomplished by specifying a zero displacement at the support points of the structure.
It's not clear from your code where such initial conditions are specified by the user. Without being able to specify an initial displacement for at least one node, the stiffness matrix equations are probably giving a singular result when the deflections are being solved for.
See p. 11 of the following article:
http://www.engr.sjsu.edu/ragarwal/ME273/pdf/Chapter 4 - Beam Element.pdf
More details can be found in the attached file below.
  • SegerlindApp3.pdf
1. What is a matrix in Matlab?
In Matlab, a matrix is a two-dimensional array of numbers or variables. It is represented using square brackets and can contain any number of rows and columns. Matrices are used to store and manipulate data in Matlab.
2. How do I create a matrix in Matlab?
To create a matrix in Matlab, use the "[]" brackets and separate each element with a space or comma. For example, "[1 2 3; 4 5 6; 7 8 9]" creates a 3x3 matrix with the numbers 1-9. You can also use the "zeros" or "ones" function to create a matrix filled with 0s or 1s, respectively.
3. How do I access and modify elements in a matrix?
To access an element in a matrix, use the row and column indices in square brackets. For example, "A(2,3)" would access the element in the second row and third column of matrix A. To modify an element, use the same syntax but assign a new value to it. For example, "A(2,3) = 10" would change the element at (2,3) to 10.
4. What are some common operations that can be performed on matrices in Matlab?
Matlab has many built-in functions and operations that can be performed on matrices, such as addition, subtraction, multiplication, and division. Other common operations include transposing, finding the determinant or inverse, and solving systems of linear equations.
5. How can I combine or concatenate matrices in Matlab?
To combine matrices, use the "[]" brackets and separate each matrix with a semicolon. For example, "[A; B]" would combine matrices A and B by stacking them on top of each other. To concatenate matrices horizontally, use a comma instead of a semicolon. For example, "[A, B]" would combine matrices A and B by placing them side by side.
