Normal Force (Reaction Force)
In summary, the conversation discusses the determination of the force that a well gives to a homogeneous stick placed inside it with a smooth surface. Two possible free body diagrams are presented, and it is concluded that walls and floors can only exert a reaction force perpendicular to the surface, unless there is friction involved.
terryds
392
http://www.sumoware.com/images/temp/xzmbharheaqshjjf.png
A homogeneous stick with mass M is placed in a well with smooth surface (see picture). θ is the angle between the stick and the floor.
Determine the force the well gives to the stick.
ΣF = 0
Στ = 0[/B]
I draw the free body diagram but I'm not sure
http://www.sumoware.com/images/temp/xzgemxpxlpjnkafk.png
The first body-diagram has normal force 1 is perpendicular to the surface (like common ladder problem)
or
http://www.sumoware.com/images/temp/xzjmplgoxrepcxct.png
The second body diagram has normal force 1 is up-left in direction. I think it's because the stair push the wall down-right, it must give the reaction in opposite direction.
Which one is correct ? The first one or the second one ?
The end of the stick is curved, it can push the wall in any direction, but the vertical smooth wall can exert only horizontal force, perpendicular to the contact surface. As the wall exerts horizontal force on the stick, the stick must exert also horizontal force on the wall (Newton's third law) .
Likes terryds
So, walls and floors can only give the reaction force perpendicular to the surface, right ?
Then,
∑Fy = 0
N2y - W = 0
N2y = W
∑Fx = 0
N2x - N1 = 0
N2x = N1
∑τ = 0
W cos Θ * 0.5 L - N1 sin Θ * L= 0
W cos Θ = N1 sin Θ * 2
W = 2 N1 tanΘ
N1 = W / 2tanΘ
Then, N2 = √((N2x)^2 + (N2y)^2) = √((W / 2tanΘ)^2 + (W)^2)
Right ?
terryds said:
N1 = W / 2tanΘ
Right ?
It is right, but use parentheses in the denominators. N1 = W / (2tanΘ) and N2 = √((W / (2tanΘ))^2 + (W)^2) and pull out W from the square root.
Likes terryds
Thanks a lot
You are welcome:)
Likes terryds
Only if contact is frictionless.
Edit: Your diagram shows the bottom in the corner of the well so it wouldn't apply there.
What is Normal Force?
Normal force, also known as reaction force, is the force that a surface exerts on an object that is in contact with it. This force is perpendicular to the surface and is what prevents an object from falling through or sinking into the surface.
How is Normal Force calculated?
Normal force is calculated by using Newton's third law of motion, which states that for every action, there is an equal and opposite reaction. In the case of normal force, the object's weight (which is the force of gravity acting on it) is equal to the normal force pushing back on it.
What factors affect the magnitude of Normal Force?
The magnitude of normal force depends on the weight of the object and the angle at which it is placed on the surface. The steeper the angle, the greater the normal force will be. Additionally, the type of surface and the roughness of the surface can also affect the magnitude of normal force.
Can Normal Force be greater than the weight of an object?
Yes, normal force can be greater than the weight of an object. This can happen when an object is placed on an inclined surface, as the normal force will increase to balance out the component of the weight that is acting perpendicular to the surface. In this case, the normal force will be equal to the weight only if the surface is horizontal.
Why is Normal Force important in everyday life?
Normal force plays a crucial role in our daily lives. It is what allows us to walk on the ground without sinking, sit on a chair without falling through, and even hold objects without them slipping out of our hands. It also helps us understand and analyze the forces acting on objects in various situations, which is important in fields such as engineering and physics.
