Null geodesics of light from a black hole accretion disk
Favicon
Sorry I don't know latex so this may look a little messy.
I'm trying to solve the equation for null geodesics of light traveling from a rotating black hole accretion disk to an observer at r = infinity. The point of emission for each photon is given by co-ordinates r, phi where r is radial distance from centre of the black hole, phi is azimuthal angle around the accretion disk (phi = 0 is defined to be the tangent point). The problem is stated as follows:
"Light travels on null geodesics given by the solution of the equation
d2u/dphi2 = 3u2 - u
where u = 1/r. The full paths can be found by integrating this from u=1/rem, phiem to u = 0 (r=infinity), phi = 0. This requires varying the initial gradient (du/dphi)em = - uemtanE until the correct solution is found for an angle E = E' + theta, where E' is the 'straight line' angle, and theta is the additional deflection from lightbending as the photon travels from rem to infinity. Explore the size of theta to estimate where the straight line approximation may break down."
I've also been told that to solve the equation I need to split it into two 1st order ODEs, but I'm not sure how to do that.
I'm really struggling just to try and understand the description, let alone solve the equation. Please could someone explain to me what this means and how I can extract the light paths from the given equations?
I learned latex when I joined Physics Forums. See
https://www.physicsforums.com/showthread.php?t=8997.
d2u/dphi2 = 3u2 - u
where u = 1/r.
But this equation is for null geodesics of non-rotating black holes. Is this what you want to do?
This second-order equation can be reduced to a pair of first-order equations by setting p = du/d\phi, so that dp/d\phi = d^2 u/d\phi^2. Consequently,
the second-order equation is eqiuvalent to
<br /> \begin{equation*}<br /> \begin{split}<br /> \frac{du}{d\phi} &amp;= p \\<br /> \frac{dp}{d \phi} &amp;= 3u^2 - u.\\<br /> \end{split}<br /> \end{equation*}<br />
Thanks for the latex tip.
Yes it probably is a non-rotating black hole. I'm actually writing a program to produce the expected line spectrum from a black hole, but the description I've been given (to explain the physics of relativistic line smearing) isn't very clear so when it talked about the motion of the accretion disk I assumed it meant the black hole itself was rotating.
\frac{du}{d\phi} = p
\frac{dp}{d\phi} = 3u^{2} - u
So now I have
\frac{du}{d\phi} = p_{em} = -u_{em}tan(E)
and have to vary E? But I still can't see how I'll know when I've found the correct value for E.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
