Opposing Moments on Levered Beam
The discussion revolves around calculating the force F1 necessary to bend a steel tube beam to a radius of 7.5m. Participants explore the use of the moment-curvature relationship and the second moment of area to determine the required force at points C and D. Initial calculations yielded a moment of 1.25 x 10^6 N/m, leading to a force of 9.9 x 10^5 N, which some participants questioned as being excessively high. A revised second moment of area calculation resulted in a moment of 1.441 x 10^5 N, prompting further discussion on the accuracy of the calculations. The thread emphasizes the importance of verifying calculations in structural engineering contexts.
nickbarker77
Calculate the force F1 to bend the beam AB to a radius of 7.5m. Assume the beam is a steel tube 200mm OD with wall thickness 20mm. The arm's AC and BD can be assumed rigid.
The force F1 acts on pivots at C and D and is always in the x direction.
I = pi (do4 - di4) / 64
My first thought was to assume the beam was fixed at one end and then work out the deflection required to achieve a a radius of 7.5m. From this I substituted into the deflection formula to work out a point load need on the end of the cantilevered beam to produce the deflection.
I think i should be calculating the moment at point C and D but I'm struggling a bit, any help would be greatly appreciated.
Why not just use
M/I = σ/y = E/R
E is given for the material and you know R. Just get M.
Thanks rock.freak667.
i have since found this formula and came out with an answer of 1.25 x 10^6 N/m for the moment required.
this is using a value of 4.637 x 10^-5 for the second moment of area and a young's modulus of 200GPa for the steel.
As the arms at the end of the beam are 1.25m long then the required force at points C and D would be 9.9 x 10^5 N.
This seem a little high?
When I calculated the second moment of area I got 2.701*10^-5 m^4 based on this:
I=\frac{\pi*\left[\left(200mm\right)^{4}-\left(200mm-20mm\right)^{4}\right]}{64}=2.701\times10^{-5}m^{4}
This would change your results a little bit. Solving out the ratio before of M/I = E/R gives:
\frac{M}{I}=\frac{E}{R}
M=\frac{EI}{R}
M=1.441\times10^{5}N
I would definitely double check what I did. 32,394 pounds of force seems reasonable to me though.
