Optics reflection/refraction problem
  • Thread starter Thread starter raindrops
    Optics
The discussion revolves around a physics problem involving optics, specifically reflection and refraction in a water-filled tank. The key question is whether marks on the tank can be seen from the top or bottom, requiring an understanding of Snell's Law to analyze light behavior as it passes through different media. Participants emphasize the importance of sketching light rays from the marks to the observer's eye level to visualize the scenario. The need for a mathematical approach to determine visibility is highlighted, suggesting calculations based on the refractive index of water. Ultimately, the problem requires both conceptual understanding and mathematical application to find the correct answer.
raindrops
The 80 cm tall, 65 cm wide tank shown in the figure is completely filled with water (n=1.33). The tank has marks every 10 cm along one wall, and the 0 cm mark is barely submerged. As you stand beside the opposite wall, your eye is level with the top of the water.
a.) Can you see the marks from the top of the tank (the 0cm mark) going down, or from the bottom of the tank (the 80cm mark) coming up? Explain
b.) Which is the lowest or highest mark, depending on the your answer to part a, that you can see?
I'm not sure what equations are relevant. maybe snell's law? n1sin\vartheta2=n2sin\vartheta2
I'm really not sure where to even start.
** drawing is attached.
Sketch the rays coming form the marks to your eye.
He's looking for a mathematical answer, not just a drawing. Any ideas on how to do that?
