Why are all values NaN after mapping 'player_name' column in Pandas Data Frame?
In summary, there are two dataframes, df1 and df2, with df1 having 'player_name' and 'player_id' columns and df2 having a 'player_id' column. The goal is to pass the 'player_name' column from df1 to df2 using the 'player_id' column. The code used was df2['player_name'] = df2['player_api_id'].map(df1['player_name']), but it resulted in all values being NaN. This may be due to the dataframes not being the same size and not sharing a primary key column. To solve this, a dictionary was created using the 'player_api_id' and 'player_name' columns from df1, and then mapped
Arman777
Insights Author
193
I have two data frames df1 and df2
df1 has two columns 'player_name' and 'player_id'.
Similarly df2 has 'player_id' column.
From this configuration I want to pass 'player_name' column to df2 by using 'player_id'. For this reason I have tried something like this,
Code:
The code runs without error and I obtain 'player_name' column in df2 but all the values are NaN. I did not understand why this happens.
Technology news on Phys.org
Two questions. Are the two dataframes the same size and do they share a column that acts like a primary key? If so, then I would use a merge with just the column that you want to add and its key from the other dataframe.
You can look at the data from here
https://www.kaggle.com/hugomathien/soccer
I am only interested in Player and Player_Attributes datas. In those data as you can see there are two columns that has the same name; player_api_id.
So as I have said before I want to move player_name from the Player data to Player_Attributes by using the player_api_id.
Nope
I guess so
Sorry, I was responding from my phone and didn't read closely enough.
If you want to add player names to df2 from df1, you would need to replace the df1['player_name'] part with a dictionary of IDs and player names from df1. Assuming that the Player table has no duplicates, something like this:
player_name_dictionary = dict(zip(df1.player_api_id, df1.player_name)) df2['player_name'] = df2['player_api_id'].map(player_name_dictionary)
Likes Arman777
thanks a lot. It works
Likes Borg
What is a Pandas Data Frame Mapping?
A Pandas Data Frame Mapping is a process of creating a visual representation of a data frame in Pandas, using various mapping techniques and tools.
How do I create a Pandas Data Frame Mapping?
To create a Pandas Data Frame Mapping, you can use the built-in mapping functions and methods in Pandas or external libraries such as Matplotlib or Seaborn. You can also customize your mapping by specifying different parameters and settings.
What are the benefits of using Pandas Data Frame Mapping?
Pandas Data Frame Mapping allows you to easily visualize and analyze complex data sets, identify patterns and trends, and communicate your findings effectively. It also helps in identifying missing or erroneous data, making data cleaning and preprocessing easier.
Can I save my Pandas Data Frame Mapping as an image or file?
Yes, you can save your Pandas Data Frame Mapping as an image or file by using the "savefig" function in Matplotlib or the "save" function in Seaborn. You can also specify the file format, resolution, and other parameters when saving the mapping.
Are there any limitations to using Pandas Data Frame Mapping?
Pandas Data Frame Mapping may not be suitable for all types of data and may not provide accurate results if the data set is too large or complex. It also requires some knowledge of data analysis and mapping techniques to create meaningful visualizations.
25K
