Particle in a box. KE from Δx?
In summary, the particle has a minimum energy when it is in a region of width 2L and its energy is given by: E=\frac{p^2}{2m}=\frac{h^2}{2m\lambda^2}
Hertz
180
Suppose a particle is confined in one dimension to a region of width L. Obtain an approximate formula for its minimum kinetic energy.
ΔxΔp ≥ h/4π
1. Put L in for Δx
2. Divide by L. It is positive
3. Δp ≥ h/(4πL)
4. KE = (p^2)/2m
Now what? Ok, so you're telling me that the uncertainty in the momentum can be determined. What does that say about the actual value of the momentum? Wouldn't the minimum momentum technically be zero? Wouldn't this mean the minimum KE is zero? There is no way this is right... It would be too easy..
Please please please help with this. My teacher is so bad and this of all classes is the class I'm falling behind in.. It's his first semester teaching and he just runs through calculations all day and apparently expects us to learn all this stuff at home.. I don't have time for this. A simple explanation will do me wonders. Thanks so much
ΔxΔp ≥ h/4π
1. Put L in for Δx
3. Δp ≥ h/(4πL)
4. KE = (p^2)/2m
In quantum mechanics you can't know an exact value for position and momentum simultaneously. If you knew the momentum exactly, you would know nothing about position. In this case, you know an approximate position, which says you can only know an approximate momentum. Neither is definite. The details involve knowing a position distribution is related to a momentum distribution by a Fourier transform. They are both wave function distributions, not exact values. The uncertainty relation gives you a best case for how what you know about position is related to what you know about momentum. In that sense, it's a minimum.
Likes 1 person
I wouldn't use the uncertainty principle, as the above poster mentioned, it's all about the error bars that go on the measurement.
Consider that the particle is a standing wave in the box. It's energy is related to its wavelength. If you want to know the minimum energy you need to know the longest wave you can fit in the box. Well, the wave function has to be zero at the endpoints, so you can fit a half wavelength in the box, so [itex]\lambda=2L[/itex].
The kinetic energy of a particle is given by [itex]E=\frac{p^2}{2m}=\frac{h^2}{2m\lambda^2}[/itex] (Remember that [itex]p=h/\lambda[/itex])
I've given you the wavelength for the particle with minimum energy and the energy as a function of the wavelength, mash em together.
Related to Particle in a box. KE from Δx?
1. What is a particle in a box?
A particle in a box is a theoretical model used in quantum mechanics to describe a particle confined to a specific region or space. It is often used to explain the behavior of electrons or other subatomic particles in a potential well.
2. How does the size of the box affect the particle's kinetic energy?
According to the particle in a box model, the kinetic energy of a particle is inversely proportional to the size of the box. This means that as the size of the box decreases, the kinetic energy of the particle increases.
3. How is the kinetic energy of a particle in a box related to its wavelength?
The kinetic energy of a particle in a box is directly proportional to its wavelength. As the kinetic energy increases, the wavelength of the particle decreases.
4. Can the kinetic energy of a particle in a box have a negative value?
No, according to the particle in a box model, the kinetic energy of a particle is always a positive value. This is due to the fact that the particle is confined to the box and cannot have a negative kinetic energy.
5. How does the number of energy levels in a particle in a box relate to the particle's kinetic energy?
The number of energy levels in a particle in a box is directly proportional to the particle's kinetic energy. As the number of energy levels increases, the kinetic energy of the particle also increases.
