Why Is the Photoelectric Effect Considered Proof of Light's Particle Nature?
In summary, the conversation discusses the photoelectric effect and its relation to the particle nature of light. While the effect is often used as proof for light being a particle, the discussion points out that the means of explaining the effect still involves the use of wavelengths and frequency. However, the experiment conducted by Thorn et al. provides undeniable evidence for the quantum behavior of light and the existence of photons. This is further supported by Beck's textbook on quantum mechanics.
Dr. Manoj
I've a doubt regarding photoelectric effect. It's said that photoelectric effect is proof for light to be a particle. But, when seen into the theory, relations between wavelength and kinetic energy, frequency and photoelectric current are explained. The means we have used wave characters like wavelength to explain photoelectric effect but still is accepted as proof for particle nature of light. Why? Anyone please explain.
No, it just proves light can show particle-like effects.
The photoelectric effect is completely independent of wavelengths. You can purely work with the photon energies.
mfb said:
No, it just proves light can show particle-like effects.The photoelectric effect is completely independent of wavelengths. You can purely work with the photon energies.
But I've learned recently that, if wavelength of incident radiation decreases, kinetic energy of photoelectron increases and if frequency increases, photoelectric current also increases. So as there is relation between wavelength and kinetic energy of photoelectron, frequency and photoelectric current, I got the doubt.
While that is correct, you don't learn that from the photoelectric effect because it does not measure any wavelength.
Not in general. It depends on the remaining setup, what happens with the intensity, your bias voltage, the geometry of everything and so on.
While the wavelength/frequency of the incoming light does affect the results of the experiment, the key is that there is a certain frequency/wavelength beyond which no current is detected, no matter the intensity of the incoming light.* This is odd because if light behaved like classical waves you should be able to simply increase the intensity of the light without changing the frequency and get ejected electrons, and the energy of each ejected electron should increase as the intensity of the light increases. But this doesn't happen. The simplest explanation that matches all observations is that light interacts with matter discretely, not continuously. By that I mean that energy from the light wave isn't absorbed in a continuous manner, as a classical wave would behave, but in discrete "packets", where each packet of energy is absorbed all at once. The amount of energy in each packet increase as frequency increases, explaining why the energy of the ejected electrons increases with the increasing frequency of the light. These packets of energy are called photons.
*Note that once the frequency of the light is high enough to eject electrons, the intensity of the incoming light can be reduced to nearly zero and you still get ejected electrons with the same energy as when the light intensity is much higher, albeit at a very low rate. This should not happen if light were just a classical wave and is further evidence that light has a particle-like behavior. If the light wave behaved classically, the electrons would absorb energy continuously over time, which would mean the electrons are behaving more like they do in a radio antenna. In an antenna, the electrons absorb energy in a near-continuous manner (owing to the very low energy per photon or radio waves) and this energy is dissipated as heat. No electrons are ejected from the antenna unless the intensity of the incoming radio waves is extremely high. So you can think of it as needing to deposit energy into the electrons faster than they can get rid of it as heat.
The photoelectric effect shows us that this behavior is only an approximation of a classical wave at low frequencies and that it fails when the frequency of the light is high enough. Classically, the incoming light would not eject any electrons below a certain intensity and increasing the intensity would always allow us to eject electrons. Instead, we get electrons regardless of intensity as long as the frequency is high enough and increasing the intensity of the light has no effect if the frequency is too low. As I said before, the best explanation is that light is not purely a classical wave and consists of photons.
Likes Dr. Manoj
If you are interested in experimental proof regarding the particle nature of light:
http://people.whitman.edu/~beckmk/QM/grangier/Thorn_ajp.pdf
Observing the quantum behavior of light in an undergraduate laboratory
J. J. Thorn, M. S. Neel, V. W. Donato, G. S. Bergreen, R. E. Davies, and M. Beck
Abstract:
While the classical, wavelike behavior of light (interference and diffraction) has been easily observed in undergraduate laboratories for many years, explicit observation of the quantum nature of light (i.e., photons) is much more difficult. For example, while well-known phenomena such as the photoelectric effect and Compton scattering strongly suggest the existence of photons, they are not definitive proof of their existence. Here we present an experiment, suitable for an undergraduate laboratory, that unequivocally demonstrates the quantum nature of light. Spontaneously downconverted light is incident on a beamsplitter and the outputs are monitored with single-photon counting detectors. We observe a near absence of coincidence counts between the two detectors—a result inconsistent with a classical wave model of light, but consistent with a quantum description in which individual photons are incident on the beamsplitter. More explicitly, we measured the degree of second-order coherence between the outputs to be g^(2)(0) = 0.0177±0.0026, which violates the classical inequality g^(2)(0)>=1 by 377 standard deviations.
Likes Dr. Manoj and Drakkith
Beck has also written a textbook on quantum mechanics, "Quantum Mechanics: Theory and Experiment"
https://www.amazon.com/dp/0199798125/?tag=pfamazon01-20
and in this book, Beck derives the results of the photoelectric effect by treating electromagnetism using classical waves and atoms using quantum mechanics.
Likes bhobba
Thank you. I got whole idea.
It is odd not because it contradicts the properties of classical light but because it contradicts the properties of classical electrons.
It is known since 1963 that quantum matter plus classical radiation already produces the photoeffect. See http://physics.stackexchange.com/a/131483/7924
Likes mfb and Drakkith
A. Neumaier said:
It is odd not because it contradicts the properties of classical light but becuase it contradicts the properties of classical electrons.
If you want to keep energy conservation, the energy in the electromagnetic field has to decrease in quantized steps as well.
1. What is the photoelectric effect?
The photoelectric effect is a phenomenon where electrons are emitted from a material when it is exposed to light. It occurs when a photon of sufficient energy strikes an electron in the material, causing it to be ejected.
2. How does the photoelectric effect support the particle theory of light?
The photoelectric effect can only be explained by the particle theory of light, which states that light is made up of particles called photons. This theory explains why a certain threshold frequency of light is required to cause the emission of electrons, and why the number of electrons ejected is proportional to the intensity of the light.
3. What is the work function and how does it relate to the photoelectric effect?
The work function is the minimum amount of energy required to remove an electron from a material. In the photoelectric effect, the energy of the photon must be equal to or greater than the work function of the material in order to eject an electron.
4. Can the photoelectric effect be observed with all types of light?
No, the photoelectric effect can only be observed with light of a certain frequency or higher. If the frequency of the light is too low, even if the intensity is high, no electrons will be emitted. This supports the idea that light is made up of discrete particles rather than a continuous wave.
5. How is the photoelectric effect used in technology?
The photoelectric effect is used in a variety of technologies, such as solar panels, digital cameras, and photocopiers. In solar panels, the photoelectric effect converts light energy into electrical energy. In digital cameras and photocopiers, it is used to capture and transfer images. It is also used in sensors, such as in automatic doors and motion detectors.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
