How Does Photon Energy Influence Exponential Attenuation in Matter?
In summary, the attenuation of photon intensity within matter is exponential as a function of depth, due to the probabilistic nature of photon interactions with electrons. However, the energy loss of incident photons through Compton interactions does not agree with this theory, as the rate of energy loss would decrease with decreasing energy. This is because only the initial interaction is considered in attenuation calculations.
Orlando
I am researching how photon intensity attenuates within matter and am a bit confused by what I have come across.
Several sources state that the attenuation of photon intensity within matter is exponential (as a function of depth). The explanation is that photon interactions with electrons in matter are probabilistic and the chances of such interactions must therefore be equal for each photon in order for an exponential relationship to eventuate, otherwise the attenuation coefficient would not be constant.
However, all sources state that with Compton interactions a photon is scattered with decreased energy and that the energy of an incident photon influences the probability of the photon being scattered at a particular angle (this is based on the Klein-Nishina differential cross section). My issue is that this does not agree with the exponential attenuation theory as it appears to me that as the incident photons lose energy as they are scattered, the rate at which they lose energy will decrease as it will become less likely that they will be scattered at large angles. An exponential relationship would require a constant rate of energy loss, would it not?
Can someone help me understand this? Much appreciated.
Science news on Phys.org
If you speak about attenuation, you usually consider collimated beam (usually of defined frequency). Thus single Compton interaction (or any other scattering) removes this photon from the original beam - so it is considered lost - the same as absorbed photon.
Further history of scattered (in any mechanism) photon does not count - the original beam is already weakened, and probability that after many scatterings photon eventually returns to the beam is usually neglected.
Thanks for the response, that makes sense.
Related to How Does Photon Energy Influence Exponential Attenuation in Matter?
1. What is photon intensity attenuation?
Photon intensity attenuation refers to the decrease in the number of photons (particles of light) as they pass through a material or medium. This decrease in intensity can be caused by absorption, scattering, or a combination of both.
2. How does photon intensity attenuation affect imaging and detection techniques?
Photon intensity attenuation can impact imaging and detection techniques by reducing the contrast and resolution of the image or signal. This is because as photons are attenuated, the information they carry is lost, resulting in a less detailed image or signal.
3. What factors can contribute to photon intensity attenuation?
The main factors that contribute to photon intensity attenuation include the type of material the photons are passing through, the thickness of the material, and the energy of the photons. Additionally, the density and atomic number of the material can also play a role.
4. How is photon intensity attenuation measured?
Photon intensity attenuation is typically measured using a technique called spectrophotometry. This involves passing a beam of light through a sample and measuring the amount of light that is transmitted through the sample. The difference in intensity between the incident and transmitted light can then be used to calculate the attenuation coefficient.
5. Why is understanding photon intensity attenuation important in various fields of science?
Understanding photon intensity attenuation is important in various fields of science, such as medicine, environmental science, and material science, as it allows us to better interpret imaging and detection techniques, study the properties of materials, and develop new materials with desired properties. It also helps us to understand the behavior of light and its interaction with matter.
  • Optics
