Poor convergence using Fe HMOs for FMO in Gamess
WillCawdell
Hello!
I'm trying to model an interaction between ligands and a heme group using FMO in Gamess.
I've tried to make HMOs for the FMOBND section of the input file (using an Fe-F complex), the HMOs are shown below:
STO-3G 19 5
0 1 0.992624, 0.019366, 0.000000, 0.000000,-0.000001,-0.014838, 0.000000,
0.000000, 0.000004, 0.005535, 0.005534, 0.005534, 0.000000, 0.000000,
0.000000,-0.000595, 0.000000, 0.000000,-0.000029
1 0 0.420492,-1.033033, 0.000000, 0.000000,-0.000111,-0.314157, 0.000000,
0.000000, 0.000062, 0.110327, 0.111004, 0.109981,-0.000339, 0.000000,
0.000000,-0.010802, 0.000000, 0.000000,-0.000514
0 1 -0.000040, 0.000094, 0.000000, 0.000000,-0.990859, 0.000170, 0.000000,
0.000000,-0.026700,-0.000085,-0.000086,-0.000094, 0.000001, 0.000000,
0.000000, 0.000139, 0.000000, 0.000000, 0.002284
0 1 0.000000, 0.000000, 0.928325, 0.346200, 0.000000, 0.000000, 0.025225,
0.009407, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000, 0.000008,
0.000003, 0.000000,-0.001955,-0.000729, 0.000000
0 1 0.000000, 0.000000,-0.346473, 0.929057, 0.000000, 0.000000,-0.008635,
0.023155, 0.000000, 0.000000, 0.000000, 0.000000, 0.000000,-0.000003,
0.000009, 0.000000, 0.000689,-0.001848, 0.000000
These HMOs work to a certain extent, allowing monomer calculations on the heme group, cysteine donor and my ligand donor to converge, however the value they converge to is oscillating between 2 points thus never converging according to Gamess. So the calculation cannot proceed to the dimer stage.
Does anyone have any ideas how to make my convergence better? U currently use DIIS as a start an initial convergence mode then switch to SOSCF to fine tune the convergence value
Thannks a lot in advance!
Caveat 1: I've never been great at solving SCF convergence problems, and I'm not sure anyone actually is. It's a bit of an art.
Caveat 2: I never really used GAMESS as extensively as some other QC programs, so I'm not as familiar with its syntax and its capabilities.
If your convergence value is oscillating between two points, it might be the case that the ground state and the first excited state are fairly close in energy, and the program can't decide which one is which. If you know which one is your ground state, and if its orbital occupation numbers are significantly different from the first excited state, you might be able to resolve the problem with a better initial guess. Absent that, you could try DIIS damping or turn off DIIS completely. This will take longer but might help convergence. Good luck.
Thanks a lot for your help! I agree convergence is a black art! I appreciate what you're saying about the ground and excited states I should have thought of that sooner! I think I'll try the DIIS changes you suggested! Thanks!
Likes jim mcnamara and TeethWhitener
I'll keep my fingers crossed for you. If that doesn't work, it's not a bad idea to poke around google or some of the QC program forums for advice on convergence problems.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
