Postulates of many worlds interpretation of QM
In summary, the Many-worlds interpretation postulates that the existence of many worlds in superposition is not accomplished by introducing a new axiom to quantum mechanics, but by removing the axiom of the probabilistic collapse of the wave function. This theory also claims that the Born's probability law can be derived from other axioms of quantum mechanics. However, there is still debate over the exact postulates of MWI, and there is no clear list of postulates.
  • #36
Yes, sorry for the confusion :)
  • #38
Fra said:
Sorry for the confusion here :) My actual first name is Fredrik which is the simple reason I have it as my sig.
No problem. It's a common name (in Sweden). By the way, I didn't mean to sound upset about it. :smile: (I'm not).
Back on topic... I read Hartle's paper. It contains some good stuff, and is definitely an interesting read, but he's assuming that if the states of a system are represented by the rays of a Hilbert space H, and you combine several such systems into a larger system, then the Hilbert space of the larger system is the tensor product H¤...¤H. He offers no justification for this. So his derivation of the Born rule has the same problem as everyone else's. (See #27).
Also, he doesn't mention the MWI at all. In fact, he spends half the paper arguing that states are not objective properties of systems. This is of course less relevant. If he had been able to derive the Born rule without assuming that we should use tensor products, it would have been very relevant for the MWI, regardless of whether he says it is.
Fra said:
Not to mention that user=Fredrik is a superhero,...
You just made me picture myself in spandex and a cape...it wasn't pretty.
  • #39
Dmitry67 said:
An observer is defined based on the question asked.
"I am going to see a dead or alive cat?" defines YOU as an observer, and a CAT
The very need for a Decoherence starts from the question. You can not ask any question bout physics without already making some sorts of decompositions - into you, cat, moon, earth, accelerator etc.
Sorry, but I don't follow. I exist independent of the questions I ask. I can ask a lot of different questions, but these questions do not define me. Not even metaphorically. If your point of view would be true, it would be one more reason to object against its use of various notions as confusing, but in this case MWI seems innocent, and it seems to be your personal confusion.
Correct, we get some results for the given basis. But this basis is not special in any way. We can chose any other basis based on our needs.
That's also not the standard understanding of MWI. Instead, MWI people have tried a lot to get some preferred basis (this problem is known as the preferred basis problem, and they were very happy finding that decoherence can give them a preferred basis. Unfortunately, it cannot give a preferred basis, because it depends on the decomposition into systems.
But of course it gives! It is like in CI where wavefunction is just a 'knowledge' so different observers can get different values for all operators. In the example with Wigners friend, there are different results: for multiple copies of the already-decoherenced observer and for the distant not-decoherenced observer.
The question is not if different observers see different things. This is so even in classical physics and was known already in Ancient Greece. Different physics means that for the same experiment, observed by the same observer, we obtain different statistics of measurement results. That means different Born rule distributions.
You can't talk about MWI ignoring the branches.
As events in different branches are different then of course they MUST have different physics, and of course before an observer is decoherenced with an observable his pre-calculated (based on his previous knowledge) values of p, r etc should not agree with the values observed by the decoherenced observer!
Different physics means different laws of physics, leading to different predictions about probabilities of measurement outcomes. And, again, regarding the probabilistic measurement outcomes I'm talking about the shut up and calculate interpretation. I don't see that talking about branches and MWI gives in any way the Born distributions, therefore I'm not talking about branches. But because I don't plan to prove that it is really impossible in MWI to obtain somehow the Born rule, I can accept, for the purpose of the argument, that MWI can recover somehow the shut up and calculate predictions based on the Born rule.
However note that p, r are not observables until you get decoherenced with a system. If I pre-calculate them in advance based on the system setup (the system itself can be in Andromeda) is a one thing, but MEASURE a position (hence beging decoherenced = forced to 'chose' one branch) is another thing.
I disagree. The observables are (and have to be) well-defined without decoherence - they are self-adjoint operators, and such self-adjoint operators are defined once the Hilbert space is defined. In particular, the Hamilton operator is well-defined without any decoherence. What decoherence can do (given the decomposition into systems) is to make a choice among the preexisting observables - it prefers some subset of observables as especially easy to measure - the decoherence-preferred observables. The other observables remain observable, but measuring them does not give much, because interaction of the measured system with the environment changes the state in short time, and after this the information you have obtained during your measurement is of not much value.
Then, decoherence has nothing to do with some force to choose a branch. There is no such force, and decoherence does not lead to such a force. All what decoherence does is to define, for a given decomposition into systems, a preferred q-like basis, something which is a necessary prerequisite for the definition of the branches.
  • #40
Wolverine has a cape :confused:
  • #41
The question is not if different observers see different things. Different physics means that for the same experiment, observed by the same observer, we obtain different statistics of measurement results. That means different Born rule distributions.
1,2
Well, may be I am really believe in a slightly different flavor or MWI?
For me it was absolutely obvious that you can't discuss 'what X is observing' without using X as 'preferred basis'. And you can't use any other basis if you are discussing X's impressions of the world. Hence your argument is valid for those whole believe in some 'preferred basis' (for me it is a nonsense) but in my flavor of MWI there is no paradox, because you are not free in chosing the basis.
Wiki article states that the choice of basis is arbitrary. Do you have any links about 'how standard MWI defines a preferred basis'?
This is what was called an observable in good old QM which did not include measurement. But you can't 'observe' it, it is just a mathematical operatior. You can observe an arrow of a voltmeter. The only true observables are the macroscopic events. Only thermodynamically irreversible events can be remembered (as memory is irreversible by definition) and hence be a part of your consciousness, hence, a particle must be irreversibly absorbed in order to say something about p, r etc.
But of course, you can calculate the result of these operators based on your knowledge about the wavefunction, but you don't know exactly your branch and wavefunction, so you should not be surprised that different observers get different results.
  • #42
Dmitry67 said:
1,2
I take Wallace and Zurek as the writers which explain MWI in the best way. I have no links, but use arxiv.org search for Zurek or Wallace on quant-ph, and you will find among them what are the IMHO best articles about MWI.
But this is only a personal opinion, and, as you can judge from the style of my papers, I try to avoid mentioning details of MWI. The reason is that my picture of MWI does not really make sense, at least I'm unable to understand how one can take MWI (given in my understanding) seriously. Because this may be the flaw of my understanding of MWI, I prefer to be careful. Here I can be a little less careful, I think.
About the preferred basis: If there exists a preferred basis, one is, of course, not free to choose one, but has to use the preferred one. If you don't want a preferred basis, you end up with (in)consistent histories, which is even worse, because it is a rejection of classical logic without necessity.
The main problem with your scheme - an observer defining a decomposition of the universe, and, then, consequently a preferred basis by decoherence - is that no such standard decomposition exists, because there are states of the universe without me, but no states of a decomposition of the universe without a state of all the subsystems. Such a decomposition makes sense only in some environment of the actual state of universe, described not by the state vector, but by some branch in MWI jargon. Thus, all this looks heavily circular.
I disagree that only decoherence-preferred observables are observable. There may be operators which are not observable - those with macroscopic superpositions as eigenstates. But in pure quantum theory we can measure lot's of different operators, for sufficiently small ones you can even measure every operator, not only the decoherence-preferred ones (as far as this notion makes sense for small pure quantum systems), because decoherence needs some time, is only an approximate mechanism.
  • #43
That choice of words makes the problem with that scheme pretty clear. A "decomposition of the universe" is a way to express the Hilbert space of states of the universe as a tensor product: [itex]\mathcal H=\mathcal H_1\otimes\mathcal H_2[/itex]. But the "observer" here is the physical system with Hilbert space [itex]\mathcal H_2[/itex]. So to say that the observer defines the decomposition is essentially the same thing as saying that [itex]\mathcal H_2[/itex] defines [itex]\mathcal H_2[/itex], and that doesn't really say anything.
  • #44
Again, it is possible (and very likely) that in act different observers do not agree on what you call an 'observables', and even on the number of the elementary particles, but they Do agree ont he microscopic events. Unruh effect is a good example
in the Universe without YOU there is no need to calculate a decoherence in some basis at all: you can be satisfied with a unitary evolution of the 'universe' wavefunction.
Note the words I highlighted
So, you do not get the values of these 'observables' directly.
At first, you must decoherence your system (or a particle) with some macroscopic device, right?
  • #45
My problem with this is not that it is in some sense tautological. In [itex]\mathcal H=\mathcal H_1\otimes\mathcal H_2[/itex] the "observer" is always in some state. But what is my state if the wave function is localized around a state of the universe where the Earth does not exist? It could be, at best, something like the state of my immortal soul or so.
  • #46
Dmitry67 said:
Again, it is possible (and very likely) that in act different observers do not agree on what you call an 'observables', and even on the number of the elementary particles, but they Do agree on the microscopic events. Unruh effect is a good example
In standard semiclassical gravity they can agree about the observables as well as in classical relativity, where everybody agrees about the showings of a traveling clock from A to B along a given trajectory.
One can associate some observables with some observers, but this association is quite arbitrary. If one considers a particle detector in some state of movement, say, along a given trajectory, the prediction about the resulting average particle numbers measured by this detector is unique, well-defined.
You have not got the point. The wave function is a function on the space of all possible universes. From this birds view there are only particular branches with or without me, the multiverse is not with or without me.
Now I have a wave function, and want to know what I can expect to observe. How does this work? You would like to look at branches which contain me. But the branches are simply not defined before decoherence has finished its job. You need decoherence to define the branches. To define decoherence, you need a decomposition into systems. This decomposition into systems has to be defined on the full Hilbert space, the one which contains all these superpositions of something close to our own branch (better, what becomes our own branch, everything else appropriately defined) to something where Earth does not exist.
The "decomposition into systems" means some [itex]H=H_{rest}\otimes H_{obs}[/itex]. Then, every basic state (branch) is a product [itex]\psi=\psi_{rest}\psi_{obs}[/itex]. What is [itex]\psi_{obs}[/itex] supposed to describe if the Earth does not exist? [itex]H_{obs}[/itex] is always the same, independent of the question if [itex]\psi_{rest}[/itex] describes a state where the Earth exists or not.
If you want to talk about the standard applications of decoherence outside many worlds, no problem. You have some classical Copenhagen part of the world, and this part defines nicely a decomposition into various systems, in part classical, in part quantum. The observer is, in this case, classical, thus, fixed at every moment of time. States where the Earth does not exist are simply not part of such considerations.
MWI has the problem how to obtain all this background in a consistent way. It cannot start with me or some other systems here on Earth to define a decomposition into systems to start decoherence, because these systems are only defined in some small subset of the small part of the multiverse which contains our Earth.
Now about the usual way to apply decoherence: I measure what I like, by rotating variouos devices in various ways. If the measurement device is rotated in one way, the decoherence-preferred observable is, say, S1, if it is rotated in another way it may be something different, S2. Thus, for small quantum systems all quantum observables may appear observable, one simply has to use some appropriate environment, with appropriately rotated devices, where it appears decoherence-preferred.
  • #47
I don't understand the arguments about decoherence being necessary to define observers. Suppose you have a quantum computer that can implement internal observers. I.e. observers are computer programs that can observe their virtual world. Then one can always project out the sectors of the individual programs to compute the probabilities of what they observe.
Here you do have a definiton of each program in some standard basis and you can argue that you could map arbitrary states to computational states of any program. This problem also exist in purely classical models. You can always invent a mapping from the states of one physical system (say a gas) to another system (say a brain). Then the reason why a gas in a container is not conscious is presumably because what matters is the program the brain is running. The mapping from the gas to the brain would contain all the nontrivial aspects of that program.
This then suggests that observers would always have to be defined as algorithms.
  • #48
Ilja,
I understand what you are saying now and I agree - yes, it is a little bit recursive. While I am thinking about "what is a probability in MWI" I can give you a short answer. Just to explain, why I am not worrying about that recursion.
Yes, you exist only in some subset of branches. We don't have a formal definition of a human, or an observer, that notion is fuzzy. Hence, we can't define what branches you 'occupy' precisely. It is even possible that some deep things like 'what is an observation?' can be explained only it very high level terms which require a definition of consciousness. Yes, I have to admit that everything fuzzy, recursive and observer-dependent. The way Fra likes it :)
Why I am still optimistic?
In MWI the only and ultimate reality is the global wavefunction. And our 'sense of reality' is just an illusion. There is no classical behavior at all, it is one of the biggest illusions we have.
For that reason I do not really care about the problem with the 'preferred basis', because basis and decoherence are not needed to define physical laws or reality - they are just needed to explain the illusion a particular frog has.
For that very reason I am sure that all frogs impressions are consistent - because frogs impression is just a mapping of the bird's view using some basis. And when we map the same thing we always get the consistent partial views. To repeat, decoherence does not explain the reality, it explains an illusion
Even may be MWI requires a definition of an observer and may be even consiousness to explain all the observations, it is much much better then CI because CI uses these high level things (like 'knowledge of an observer') to explain the microscopic world, while MWI uses it to explain only high level things, so it might require a definition of consciousness to explain, what we 'feel', but we don't need all that stuff in the microscopic world.
But I have to agree with you, there are some deep questions in MWI which are not clear right now.
  • #49
That's the way Wallace explains how MWI works. There are no observers in general, but the notion of an observer is derived, follows from decoeherence, appear only in the classical limit, as some emergent subjects. It's not me who has invented this, it is the (IMHO wrong) idea of the many worlders that they can derive everything from the wave function taken alone.
About quantum programs able to observe something none-classical I don't even want to speculate in a forum. I don't know enough about them.
  • #50
Sorry, but I could not resist to transform this argument into a theological one:
UnknownTheolog said:
Yes, I have to admit that everything fuzzy.
In religion the only and ultimate reality is God. And our 'sense of reality' is just an illusion. There is no classical behavior at all, it is one of the biggest illusions we have.
For that reason I do not really care about the problem with human reality, because human reality is not needed to define Gods laws or Gods reality - they are just needed to explain the illusion a particular frog has.
They are inconsistent with each other - the inconsistent histories interpretation uses an explicit consistency condition to define consistent parts of it. For some given preferred basis, they become consistent, this is why MWI needs one preferred, and not some.
The shadows on the wall seen by Plato's prisoners are real shadows. Because they follow from the really existing objects, the really existing source of light, and the really existing wall. Naming them illusion explains nothing. An explanation has to describe how the illusion emerges, in a logically consistent way.
CI uses high level things, but gets the real answers. MWI has yet to show that it gets them. With my counterexample, the job of the many worlders becomes (I think) much harder. I think I have shown that MWI needs some additional structure to fix the physics, thus, to become equivalent as a physical theory to QM.
I have today received the journal ref:
Found Phys (2009) 39: 486–498
DOI 10.1007/s10701-009-9299-4
Why the Hamilton Operator Alone Is not Enough
I. Schmelzer
  • #51
This is a good example. Yes, shadows on the wall. And it is not well defined what is a wall. And these walls are not flat. And to analyze their shape, we use the shadows.
BTW, returning to the 'observables' which are not obserables at all: can you see elementary particles with your naked eye? You do you use some devices to get values of these 'observables'?
  • #52
I don't - I'm a pure theorists. Your point being? Of course one has to use devices. My argument was that for pure quantum systems one can use very different devices measuring very different observables, in simple cases all of them. Without any contradiction with decoherence.
  • #53
My point is that you can't observe them. You can read some numbers from your device. Hence you never get the true value of your 'observable', but just a result of a decoherence of a particle or other QM system with a measurement device. Again, you can never get values of p, r DIRECTLY.
  • #54
I can never get even the color of the tomato I like to eat DIRECTLY. So I don't see a point. All measurement results are indirect, depend in their interpretation on our theories.
  • #55
My point isthat in your article you have proven the tautology (you call it a "different physics"). The culmination of your proof is the point what you say that p, r have different values based on the basis, so it mean "different physics". But it is predicted by MWI!
1. In Wigners friend experiment, p,r of the cat is different in the basis of the Wigner and in the basis of his friend inside the box. This is how this experiment is explained in MWI
2. Different 'branches' of the same observer might have different values of 'observables', for example, the same observer have have different values for the cat (dead and alive version/branch).
  • #56
No. In Wigners friend, the basis is the same: the positions (or something close to it which is decoherence-preferred) of Wigner, his friend, and the remaining part of the universe. And all their observations are compatible with standard QM laws of physics, with the standard Hamiton operator.
And different branches see different results, but all results are results compatible with the same laws of physics. Instead, the different phyisics related with my non-uniqueness examples means different laws of physics, where Hamilton operators are different, even if they have a similar form in the canonical variables.
  • #57
I am trying to understand, are you talking about 'different laws' relative to different decoherence basis or relative to the different 'branches'?
Different basis and bracnhes form 2 levels of hierarchy: we can have different decoherence basis and for each basis we can have different branches. For example, in Wigners friend experiment we have:
*** Before the box is opened:
1. Wigners friend basis
1.1 Wigners friend branch - observing a dead cat
1.1 Wigners friend branch - observing a cat which is alive
2. Wigner's basis (not decoherenced yet with the inside of the box)
*** After the box is opened:
2. Wigner's basis
2.1 (in sync with 1.1) Dead cat
2.2 (in sync with 1.2) Alive cat
  • #58
Different basis and branches form 2 levels of hierarchy: we can have different decoherence basis and for each basis we can have different branches. For example, in Wigners friend experiment we have:
2. Wigner's basis
First, again, there is no difference between "Wigner's basis" and "Wigner's friends basis". The preferred basis is for everything, and it is uniquely defined given a decomposition of the whole universe into different subsystems. Now, in Wigner's case we have three different subsystems - Wigner, his friend, and the rest of the world - and the decomposition into these three subsystems is the same, therefore the preferred decoherence basis is the same.
The non-uniqueness has nothing to do with different branches. Branches depend already in their definition on the choice of a decoherence-preferred basis.
The non-uniqueness is below that level. There are different decompositions into systems, which lead to different choices of the decoherence-preferred basis, and, as a consequence, to different definitions what it means to be a "branch".
  • #59
  • #60
cstromeyer said:
Hi, this paper by S. Dolev and A.C. Elitzur shows that the results of their experiment are not compatible with a "collapse" (or "wave guide" interpretation of QM such as Bohmian mechanics) on pages 3-4:
http://arxiv.org/abs/quant-ph/0102109
As an argument against pilot waves this is clearly not conclusive. Pilot wave trajectories are known to behave strangely (which is sometimes used as an argument against them).
  • #61
  • #62
Just because in practice the basis is the same doesn't mean that the laws of physics forbid other bases. Suppose a quantum computer is built in which the decoherence basis is the tensor product of the |0>, |1> bases for each qubit. This quantum computer is almost perfectly isolated from the environment so that decoherence effects are negligible.
We switch to the |0'>, |1'> basis:
|0'> = 1/sqrt(2) [|0> - |1>]
|1'> = 1/sqrt(2) [|0> + |1>]
and implement (classical) observers in this basis.
Then why can't this be done?
  • #63
cstromeyer said:
Ilja, the experiment shows that the wavefunction in QM is non-sequential and non-causal. By definition, Bohmian mechanics is a causal interpretation. Please see:
http://plato.stanford.edu/entries/qm-bohm/
There is nothing in the experiment which contradicts standard quantum theory. And, once there is an equivalence theorem, the results of the experiment cannot contradict BM as well.
Thus, there is only an apparent contradiction. In particular, BM is known to be nonlocal, and naive attempts to find realistic interpretations often assume locality implicitly. Then, in BM it is extremely important to consider the whole experiment - including all measurement and storage instruments, up to the final moment - into the consideration.
This is clearly not done. There is a lot of talk about various measurements of the particles, without any consideration how the choice of these measurments influences the measurement of the photon. But this is an important feature of BM: The choice of measurements for one part influences the actual results of measurements of another part of some superpositional state.
This is not the first experiment which is claimed to be incompatible with causality: The quantum eraser has been interpreted in a similar way, but allows for a causal interpretation in BM (even if the corresponding trajectories have been characterized as "surrealistic"). The situation looks very close, and the outcome is predictable: Bohmian trajectories exist, and nothing in this game contradicts classical causality, but the explanation given by these trajectories will look extremely surrealistic: Probably some ways of particle detection appear to be fooled.
Yes, these are guesses, but similar to guesses of those mathematicians which become confronted with angle trisection algorithms. They know they have a theorem behind them and have some experience considering such examples, so they can give a conclusion without having to consider everything in detail.
A serious angle trisection paper would have to show in detail what is wrong with the impossibility proof for such algorithms. Similar for claims that some standard quantum experiment does not allow for an explanation in terms of causal Bohmian trajectories.
  • #64
Ilja, the experiment contradicts "collapse" interpretations of QM which are supposed to be equivalent to Bohmian mechanics.
I agree with you that Bohmian mechanics is compatible with non-locality, but the experiment shows that the wavefunction of QM is also non-sequential and thus non-causal.
However, the work of Professor Joseph Eberly and colleagues, e.g., see his article in the journal Science, shows that quantum entanglement can suddenly die. One might try to argue that this sudden death might restore some concept of 'causality'.
  • #65
First, I doubt that it contradicts collapse interpretations, but this question is not interesting enough for me to spend time evaluating it. But this experiment is clearly standard QM, and in standard QM the wave function follows a causal equation - the Schroedinger equation (if one uses classical causality, with the absolute time used in this equation).
Thus, a contradiction with classical causality cannot follow, it is a purely interpretational artefact.
I would not even try.
  • #66
No, no, this is much much worse hten you think.
As I said before, for any observer the only valid choice of basis is his own basis. Before box is opened, the world for Wigner and his friends is different.
And even worse, decomposition into systems is made by some observer, hence, it is observer (and basis-) dependent.
And even worse, an observer itself is not clearly defined.
And even worse, there are some branches from, let's call them 'early forks', where Wigner and his Friend did not decide to make an experiment, or where they were not friends, or Earth did not exist. So all we are talking about is relative to some branch.
And even worse (I don't know why it is not stressed) - basis itself must be redefined every time after any macroscopic event, after any act of decoherence. You cant, for example, talk about 'how sad Friend tells Wigner that cat is dead', using the old Friend's basis before he didnot knew cat's fate, because in the old basis he was in a superposition to both outcomes, which is not consistent with his own updated basis (I know that cat is dead/alive).
So you can't as you like to say 'I don't care about branches', because 1 the initial branch, 2 the decomposition of the universe into systems, 3 the definition of what is an observer are branch-dependent. And 2 and 3 are dynamic.
  • #67
If it would be as you claim, my article would be unnecessary and many worlds would be simply ill-defined, and nothing worth to care about. As circular as possible.
  • #68
I expected that question.
MWI is circular, but it is much better then CI: check the image.
Now, why I prefer it over BM... wait few mins, I will post a new thread.
  • Quantum Interpretations and Foundations
10K
11K
