How Can I Solve a Density Function Using the Fundamental Theorem of Calculus?
In summary, using the fundamental theorem of calculus, you can solve this density function by taking the definite integral of fx(t) from 0 to t. The result will give you the cumulative density function (CDF) for fx(t). To find the probability of a random variable T being between alpha and beta, you would take the definite integral of fx(t) from alpha to beta, which gives the area under the density function curve between alpha and beta.
barneygumble742
28
hi,
i'm given the density function
fx(t) = 0 (t<0)
fx(t) = 2t (0<t<1)
fx(t) = 0 (t>1)
how can i solve this using the fundamental theorem of calculus?
i had a similar situation before where my function was:
fx(t) = 0 (t<0)
fx(t) = 1 (0<t<1)
fx(t) = 0 (t>1)
and the g(t) i came to was:
g(t) = 0
g(t) = t
g(t) = 2-t
g(t) = 0
some work from the previous situation:
integral of fx(u) * f(t-u) du
integral of 0 for t<0 = 0
integral of 1 for 0<t<1 = t
integral of 1 for 0<t-t<1 = 2-t for 1<t<2
integral of 0 for t>2 = 0
finding the probability between alpha and beta:
integral of g(t) dt from 0.45 to 1.35 = integal of t dt from 0.45 to 1 + integral of 1 to 1.35 = 0.6875
which is the correct answer.
i tried to apply the same principles where fx(t) = 2t but i keep getting the wrong answer.
for my simulation, x1 = rnd (a random number between 0 and 1) and x2 = sqrt(rnd) (square root of another random number). i added the numbers and I'm finding the expected value and variance perfectly and my theory supports it. however I'm not getting the theory for my probability of being between alpha and beta.
i think I'm loosin' it!
any help would be greatly appreciated.using the fundamental theorem of calculus, you can solve this density function by taking the definite integral of fx(t) from 0 to t. The result will give you the cumulative density function (CDF) for fx(t). The CDF is defined as the probability of a random variable X being less than or equal to some value x. In this case, it would be the probability of a random variable T being less than or equal to a given value t. The CDF gives you the area under the density function curve up to the given value t. To find the probability of a random variable T being between alpha and beta, you would take the definite integral of fx(t) from alpha to beta. This integral gives you the area under the density function curve between alpha and beta, which is the probability of T being between those two values. For your particular density function, the CDF is given by: Fx(t) = 0 (t<0)Fx(t) = t^2 (0<t<1)Fx(t) = 1 (t>1)To find the probability of T being between alpha and beta, you would take the definite integral of fx(t) from alpha to beta. This would give you the area under the density function curve between alpha and beta. For example, if alpha = 0.45 and beta = 1.35, then the probability of T being between those two values would be: P(T ∈ [0.45,1.35]) = integral of fx(t) from 0.45 to 1.35 = integral of 2t from 0.45 to 1 + integral of 0 from 1 to 1.35 = integral of 2t from 0.45 to 1 = 0.6875
Related to How Can I Solve a Density Function Using the Fundamental Theorem of Calculus?
1. What is probability?
Probability is a measure of the likelihood or chance that an event will occur. It is expressed as a number between 0 and 1, where 0 indicates impossibility and 1 indicates certainty.
2. What is convolution?
Convolution is a mathematical operation that combines two functions to produce a third function. In probability, convolution is used to calculate the probability of two independent events occurring together.
3. How is probability related to convolution?
Probability and convolution are closely related as convolution is used to calculate the probability of two independent events occurring together. It is also used to calculate the probability of a series of events occurring in a specific order.
4. What is the difference between discrete and continuous probability distributions?
Discrete probability distributions are used when the possible outcomes of an event are countable, while continuous probability distributions are used when the possible outcomes are infinitely divisible. For example, rolling a dice is a discrete event, while measuring the weight of a person is a continuous event.
5. How is convolution used in real-world applications?
Convolution is used in a variety of real-world applications, such as signal processing, image processing, and machine learning. It is also used in finance to model the probability of stock prices and in physics to model the probability of particles interacting in a system.
