Why Do Rubbed Materials Attract or Repel Each Other?
For part (b), which answer makes sense to YOU? Part (c) asks how YOU would do something.In summary, when a piece of cellulose acetate is rubbed with a polythene strip, it becomes negatively charged. This is due to the transfer of electrons from the polythene strip to the acetate. When a neutral body is rubbed, it can acquire a charge due to the transfer of electrons. In this case, the soft cloth becomes negatively charged after rubbing. To discharge an insulator like a polythene strip, it can be brought in contact with a conductor or exposed to high energy radiation.
zaftcouncil
1. When a piece of cellulose acetate (transparency) is rubbed by stroking it for about 10 to 20 times in one direction and brought towards a piece of rubbed polythene strip,
i. state what happens, and
ii. explain the observation.
2. Before rubbing a polythene strip with a soft cloth, both the strip and the cloth are neutral. After rubbing, the polythene strip is charged negatively.
a. Does a neutral body possesses any charge? Explain.
b. Is the soft cloth charged after rubbing? If it is, is it charged positively or negatively?
c. How do you discharge an insulator like a polythene strip?
Thanks in advance.
1. The question asks what YOU observe. No one else can tell you that! Go ahead and DO the experiment and see what happens.
2. What do YOU think? Part (a) certainly should be easy. These are just a matter of knowing the definitions.
1. When the rubbed cellulose acetate is brought towards the rubbed polythene strip, the two materials will attract each other and stick together. This is due to the build-up of static electricity, which causes opposite charges to attract each other. The cellulose acetate becomes positively charged while the polythene strip becomes negatively charged. This is known as the triboelectric effect, where two materials rubbing against each other transfer electrons and create static charges.
2. a. No, a neutral body does not possess any charge. This means that it has an equal number of positive and negative charges, which cancel each other out and result in a net charge of zero.
b. Yes, the soft cloth will also become charged after rubbing. However, the type of charge depends on the materials involved. In this case, since the polythene strip becomes negatively charged, the soft cloth will become positively charged.
c. To discharge an insulator like a polythene strip, you can use a grounding wire or a grounding mat. By connecting the insulator to a conductive surface, the excess charge will flow through the conductor and neutralize the insulator. Another method is to use a discharge wand, which is a pointed metal object that can be touched to the insulator, allowing the excess charge to escape.
1. When the cellulose acetate is rubbed and brought near the rubbed polythene strip, they will attract each other. This is due to the buildup of static electricity on the surfaces of both materials. The rubbing process causes the transfer of electrons between the two materials, leaving one with a positive charge and the other with a negative charge. This attraction is observed because opposite charges attract each other.
2. a. No, a neutral body does not possess any charge. This means that it has an equal number of positive and negative charges, resulting in a net charge of zero.
b. Yes, the soft cloth will also become charged after rubbing. It will have the opposite charge of the polythene strip, so it will be charged positively.
c. To discharge an insulator like a polythene strip, it can be touched by a conductor, such as a metal object. This will allow the excess electrons to flow from the polythene strip to the conductor, equalizing the charges and discharging the strip. Another method is to place the insulator near a high-voltage source, which will cause the excess electrons to jump from the insulator to the source, again equalizing the charges and discharging the insulator.
Related to Why Do Rubbed Materials Attract or Repel Each Other?
What is electrostatics?
Electrostatics is the branch of physics that studies the behavior of electric charges at rest. It involves the study of electric fields, electric potentials, and the interactions between charged objects.
What are some common problems with electrostatics?
Some common problems with electrostatics include the buildup of static electricity, which can cause shocks or interfere with electronic devices, and the attraction or repulsion between charged objects, which can cause objects to stick together or push each other apart.
How can static electricity be controlled?
Static electricity can be controlled by grounding or bonding objects to release excess charge, using anti-static materials, and avoiding friction between different materials that can cause the transfer of electrons.
What causes electrostatic discharge (ESD)?
ESD is caused by the sudden flow of electric current between two objects with different electric potentials. This can occur when there is a buildup of static electricity or when two charged objects come into close contact.
How can the effects of ESD be minimized?
The effects of ESD can be minimized by using ESD-safe materials and equipment, grounding or bonding objects to prevent charge buildup, and using protective measures such as wrist straps or conductive mats when handling sensitive electronic components.
10K
