Problem with the idea of identical particles in QM
In summary: I am not entirely clear about what your point of confusion is, but I suspect you are thinking something like this: "How can I count the number of combinations in which k particles are on the left side of the box if I cannot distinguish anyone of those combinations from another?"If that is the case, imagine this process: starting with a bag of n identical particles, you draw out the particles one by one and with equal probability put each one in either the left or the right side of the (initially empty) box. Can you now calculate the probability of k particles in the left side of the box?Yes, you can. The probability of k particles in the left side of the box is 1/(N
QuasarBoy543298
32
assume i have a gass made from N identical particles in a box and i want to calculate the probability for k out of N particles to be in the left side of the box.
the problem is ,that if we treat the N particles as identical , each state in which exacly k of the N particles are in the left side of the box is considered to be the same state (thats the meaning of identical particles from qm as i understood - the configuration in which particle A is on the left side and particle B on the right side and the configuration in which particle A is on the right side and particle B is on the left side are considered as one configuration ).
that does not seem very reasonable considering the fact that we now have not so neglegable probability for all the particles to go to the left side of the box
its kinda silly but i can't figure out where the mistake is
help me I am confused :(((
Why do you think the probability would not be negligible? Have you tried to calculate the fraction of states that have exactly ##k## particles on the left side of the box?
if what i said is true. the probability of having k particles on the left side of the box is simply 1/(N+1) (independent of k).
correct , i am unsure why the idea of identicle partices does not states that we basically need to count all the possible configurations where there are k particles in one side as one configuration
(for example ,why the configurations left- A,B right - C and left -A C , right-B can be treated as diffrenet configurations and be counted as two diffrent possibilities although A,B,C are undistinguishable)
and yes, with this process there are 1/2^N times N choose k probability , but I am still not sure why can you think of the problem like that, or why what i said is wronge
and thanks for the quick response :):):)
No, it isn't. For a simple counterexample, suppose N = 2 (2 particles) with the particles indistinguishable. Then the probability of having 1 particle in the left half of the box (and the other in the right half) is 1/2, not 1/3; but the probability of having 2 particles (i.e., both of them) in the left half of the box is 1/4, not 1/3. So (a) the probability is not independent of k, and (b) the probability is never 1/(N+1) as you claim.
How much do you know about the basics of probability theory?
If the particles are indistinguishable, these are the same configuration, not different ones.
What references (textbooks or peer-reviewed papers) are you looking at to learn about how QM treats indistinguishable particles?
unfortunately I am currently learning statistical mechanics without a proper background in qm (which i will get in the next semester),so we had to take the concept of identical particles as given.
i still can't understand why on the one hand you said that the two configurations are the same but on the other hand you said that for 2 particles there is 1/4 probability for 2 particles to be on the same side (that means that we have 1/2 probabilty for the two particles to be on different sides, hence 2 configurations if we give each configuration the same probability)
A very good standard text is
A. L. Fetter, J. D. Walecka, Quantum Theory of Many-Particle Systems, McGraw-Hill
Book Company, New York (1971).
1. What is the problem with the idea of identical particles in quantum mechanics?
The main problem with the concept of identical particles in quantum mechanics is that it goes against our classical understanding of particles as distinct and unique entities. In quantum mechanics, identical particles are indistinguishable and cannot be tracked individually, which can lead to confusion and paradoxes.
2. How does the concept of identical particles affect our understanding of quantum systems?
The concept of identical particles has significant implications for how we understand and model quantum systems. It requires us to use new mathematical tools, such as permutation operators, to properly describe the behavior of these particles. It also leads to the phenomenon of quantum entanglement, where the state of one particle is intrinsically linked to the state of another, even if they are separated by large distances.
3. Can identical particles ever be distinguished from each other in quantum mechanics?
No, according to the principles of quantum mechanics, identical particles are fundamentally indistinguishable. This means that even if we were to label them with different names or properties, we would not be able to tell them apart in terms of their quantum state. This is known as the quantum indistinguishability principle.
4. Are there any real-world examples of identical particles in quantum mechanics?
Yes, there are several examples of identical particles in quantum mechanics, including electrons, protons, and neutrons. These particles all have the same fundamental properties, such as mass and charge, and cannot be distinguished from each other in terms of their quantum state.
5. How do physicists deal with the problem of identical particles in quantum mechanics?
Physicists use mathematical tools and techniques, such as the aforementioned permutation operators, to properly describe and understand the behavior of identical particles in quantum systems. They also rely on experimental evidence and observations to validate and refine their understanding of these particles and their interactions.
  • Quantum Physics
  • Thermodynamics
  • Quantum Physics
  • Quantum Physics
