Proving Fourier Transform is Entire
fauboca
g is continuous function, g:[-\pi,\pi]\to\mathbb{R}
Prove that the Fourier Transform is entire,
<br /> G(z)=\int_{-\pi}^{\pi}e^{zt}g(t)dt<br />
So,
G&#039;(z) = \int_{-\pi}^{\pi}te^{zt}g(t)dt=H(z).
Then I need to show that G(z) differentiable for each z_0\in\mathbb{C}.
I need to show \left|\frac{G(z)-G(z_0)}{z-z_0}-H(z_0)\right| &lt; \epsilon whenever 0&lt;|z-z_0|&lt;\delta, correct?
If that is correct, I am also having some trouble at this part as well.
My guess is you can separate the real and imag part of G(z) and show that they satisfy Cauchy-Riemann equations
How are the partials done? x and y and neglect t?
sure, t is a dummy variable, you are essentially exchanging differentiation over x,y and integration over t
So the C.R. equations are satisfied and that is it then?
What can be done to justify slipping differentiation past the integral?
How can I show the partials are continuous at this point?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
