leibo
- 11
- 1
Hello.
I wrote a simple gas simulation in python, with pygame. In the simulation the atoms collide elastic collisions with each other and with the walls. Although the simulation does run and the collisions look realistic, when I try to calculate physical parameters like p,T,V,n and compare them to the gas law's there is no match. For example, when the radius is doubled the mean free path becomes smaller, but not in a factor of 2^2=4. the ratio PV/NT is not exactly constant and can be changed by a factor of 10, etc. I wonder what can be the problem? thank you.
this is the code:
this is the code:
Code:
from __future__ import division
import pygame, sys,pygame.mixer
import math
import pylab
import numpy as np
import time
import random
from pygame.locals import*
pygame.init()
"""basic variables"""
clock = pygame.time.Clock()
font1 = pygame.font.Font(None, 17)
edgeX,edgeY = 10,10
boxWidth,boxHeight = 950,680
size = width,height = 1000,700
centerX,centerY=int(width/2),int(height/2)
screen = pygame.display.set_mode(size)
x,y = width/2, height/2
radius = 3
number_of_atoms =200
position = []
v = []
color = []
"""set initial positions and velocities"""
for j in range(number_of_atoms):
position.append([400+random.randint(-250,320),325+random.randint(-285,375),0])
v.append([random.uniform(-5,5),random.uniform(-5,5)])
m.append(1)
color.append((0,0,255))
color[number_of_atoms-1]=((250,0,0))
for i in range(4):
v.append([0,0])
def colission(a,v,b): # a - list of all atoms, v - list of all velocites (atom j has in position position[j] and travel with velocity v[j]), b - the atom we check for collisions
for ball in a:
if ball is not b:
distanceX,distanceY = (b[0]-ball[0]),(b[1]-ball[1])
distance = distanceX*distanceX + distanceY*distanceY
if distance < 36: #radius=3,(2radius)**2=36
ma,mb=1,1 #the mass of all atoms is 1
i,j = a.index(ball),a.index(b)
change = [-0.15*distanceX,-0.15*distanceY]
Vax,Vay = v[i][0],v[i][1]
Vbx,Vby = v[j][0],v[j][1]
Angle =math.atan2(distanceY,distanceX) # math.acos((distanceX/distance))
cos,sin = math.cos(Angle),math.sin(Angle)
#changing coordiantes:
vg,vh=[Vag,Vah],[Vbg,Vbh]=[Vax*cos+Vay*sin,Vay*cos-Vax*sin],[Vbx*cos+Vby*sin,Vby*cos-Vbx*sin]
#after collision:
Va2,Vb2=(2*mb*Vbg)/(ma+mb), (2*ma*Vag)/(ma+mb) #because ma=mb the term (ma-mb)*Vag or (mb-ma)*Vbg cancels out
v1,v2 = [Va2,Vah] , [Vb2,Vbh]
#changing coordiantes again:
sin = -sin
v1,v2 = [(Va2*cos+Vah*sin),Vah*cos-Va2*sin], [v2[0]*cos+v2[1]*sin,v2[1]*cos-v2[0]*sin]
v[j],v[i]= v2,v1 #update velocites
a[i][0],a[i][1]=a[i][0] + change[0], a[i][1] + change[1] #treating overlaps
return()
"""the loop"""
while 1:
screen.fill((0,0,0))
mouseX,mouseY=pygame.mouse.get_pos()
for event in pygame.event.get():
if event.type == pygame.QUIT:
pygame.quit()
sys.exit()
elif event.type == MOUSEBUTTONDOWN:
if mouseY<edgeY+50 and mouseY>edgeY-50 and mouseX<edgeX+boxWidth and mouseX>edgeX-50:
z=1
elif event.type == MOUSEBUTTONUP:
z=0
if z==1:
dy = mouseY-edgeY
boxHeight = boxHeight-dy
edgeY=mouseY
pygame.draw.rect(screen, (200,100,0), (edgeX,edgeY,boxWidth,boxHeight),1)
sys.exit()
for j in range(len(position[:number_of_atoms])):
colission(position,v,position[j]) #check for collisions
position[j][0]+=v[j][0]
position[j][1]+=v[j][1]
"""checking for collisions with the walls"""
if position[j][0]+radius>edgeX+boxWidth:
v[j][0]=-1*(v[j][0])
position[j]=[(-radius+edgeX+boxWidth)-2,position[j][1],0]
if position[j][0] - radius<edgeX:
position[j]=[radius+edgeX+2,position[j][1],0]
if position[j][1]+radius>edgeY+boxHeight:
v[j][1]=-1*(v[j][1])
position[j]=[position[j][0],(-radius+edgeY+boxHeight)-2,0]
if position[j][1]-radius<edgeY:
position[j]=[position[j][0],edgeY+2+radius,0]
clock.tick(40)
for i in range(len(position[:number_of_atoms])):
circle = pygame.draw.circle(screen,color[i], (int(position[i][0]),int(position[i][1])),radius)
pygame.display.flip()
