How can we determine the sum of roots in a quadratic equation with real roots?
In summary, if the product of the roots is positive, then either both roots are positive, or both roots are negative. If the product of the roots is negative, then there is one positive root and one negative root, so we have what we need.
DaalChawal
87
I am confused in (iia) and (iib).
If $x^4 +( \alpha - 1) x^2 + \alpha + 2 = 0$ has real roots that means $y^2 + ( \alpha -1) + \alpha + 2 =0 $ should have at least one non-negative root. This means product of roots of (2) can be greater or less than zero...But I'm not able to comment on sum of roots.
Help Please.
Mathematics news on Phys.org
Help Please.
Let's assume from here on that the discriminant is $\ge 0$. Otherwise there is no solution.
Now let's forget about roots that can be zero for a moment.
If the product of the roots is positive, then that means that either both roots are positive, or both roots are negative.
Otherwise the product is not positive.
So we can't tell yet if we have at least one positive root.
However, if there is at least one positive, then the other root must also be positive, so their sum must be positive.
And if both roots are negative, then their sum must be negative.
So the sum of the roots allows us to distinguish cases.
In short if $\text{Product of roots} >0 \text{ and } \text{Sum of roots} > 0$, then we have a non-negative root as desired.
If the product of the roots is negative, then that means there is one positive root and one negative root, so we have what we need.
In short if $\text{Product of roots} <0$, then we have a non-negative root as desired.
Now let's go back to roots that could be zero.
If at least one root is zero, then the product is zero as well, and we have a non-negative root as desired.
In short if $\text{Product of roots} =0$, then we have a non-negative root as desired.
In all other cases, we don't have a non-negative root.
Can we combine those 3 conditions into what we have in (iia) and (iib)?
Isn't there a possibility that other root can be negative but of less magnitude so that sum becomes positive and product becomes negative?
We can combine for (iia) and (iib) we will take union of those domains and for whole (i) and (ii) we can take intersection
If both roots are negative, then the sum is negative.
So in your case we must have a root that is positive.
Then the product is indeed negative.
If the product is negative, then we don't need to look at the sum at all because one of the roots must be positive, so that we have a solution.
What is a quadratic equation?
A quadratic equation is a polynomial equation of the form ax^2 + bx + c = 0, where a, b, and c are constants and x is the variable. It is called quadratic because the highest power of the variable is 2.
What is the standard form of a quadratic equation?
The standard form of a quadratic equation is ax^2 + bx + c = 0, where a, b, and c are constants. This form is useful for solving quadratic equations using various methods such as factoring, completing the square, or using the quadratic formula.
What is the discriminant of a quadratic equation?
The discriminant of a quadratic equation is the expression b^2 - 4ac, which is found under the square root in the quadratic formula. It is used to determine the nature of the solutions of a quadratic equation. If the discriminant is positive, the equation has two distinct real solutions. If it is zero, the equation has one real solution. And if it is negative, the equation has no real solutions.
What are the different methods for solving a quadratic equation?
The three main methods for solving a quadratic equation are factoring, completing the square, and using the quadratic formula. Factoring involves finding two numbers that when multiplied, equal the constant term and when added, equal the coefficient of the x term. Completing the square involves adding a constant to both sides of the equation to create a perfect square trinomial. The quadratic formula is a formula that gives the solutions to any quadratic equation.
What are some real-life applications of quadratic equations?
Quadratic equations have many real-life applications, such as in physics to calculate the trajectory of a projectile, in engineering to design bridges and buildings, in finance to calculate interest rates, and in computer graphics to create parabolic shapes. They are also used in sports to analyze the trajectory of a thrown or kicked object.
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
