Quadratic Inequality....5
  • MHB
  • Thread starter mathdad
  • Tags
    Quadratic
In summary, the solution to the quadratic inequality (x^2 - 1)/(x^2 + 8x + 15) ≥ 0 is (-infinity, -5) U (1, infinity). This is determined by finding the roots of the numerator and denominator and testing the intervals on a number line, where the sign of the expression alternates. The end-points of the intervals are included in the solution due to the inequality being weak.
mathdad
1,283
Section 2.6
Question 50Solve the quadratic inequality.
x^2 - 1 = (x - 1)(x + 1)
Question:
Do I solve the numerator or denominator to find the end points?
Setting each numerator factor to 0 we get x = 1, x = -1.
Factor denominator.
x^2 + 8x + 15 = (x + 3)(x + 5)
Set each denominator factor to 0.
x + 3 = 0
x = -3
x + 5 = 0
x = -5
Question:
Do I place x = -3 & x = -5 on the number line to test each interval?
Is the correct number line as follows?
<-----(-5)-----(-3)-----(-1)-----(1)----->
It looks like we must test 5 intervals, correct?
Mathematics news on Phys.org
RTCNTC said:
Section 2.6
Question:
You want to determine the roots of both the numerator and denominator as your critical numbers (i.e., values for which the expression can change sign).
Factor denominator.
x + 3 = 0
x = -3
x + 5 = 0
x = -5
Question:
Yes, that's correct.
You really only need to test 1 interval, since all roots are of multiplicity 1 (odd), the sign will alternate across all intervals. Because the inequality is weak, we include the end-points of the intervals that are part of the solution. :D
I am going to test each interval for algebra practice.
(x - 1)(x + 1)/(x + 3)(x + 5) ≥ 0
When x = -3 & -5, we get undefined. This means we do include -3 and -5 as part of our solution. The same can be said for x = -1 & x = 1.
For (-infinity, -5), let x = -6. Here we get a true statement.
For (-5, -3), let x = -4. Here we get a false statement.
For (-3, -1), let x = -2. Here we get a false statement.
For (-1, 1), let x = 0. Here we get a false statement.
For (1, infinity), let x = 3. Here we get a true statement.
Solution: (-infinity, -5) U (1, infinity)
Correct?
What is a quadratic inequality?
A quadratic inequality is an inequality in the form of ax^2 + bx + c < 0, ax^2 + bx + c > 0, or ax^2 + bx + c ≤ 0, where a, b, and c are constants and x is a variable. It represents a region on a graph where the y-values are either less than or greater than the x-axis.
How do you solve a quadratic inequality?
To solve a quadratic inequality, you must first factor the quadratic expression and find its zeros. Then, you must plot these zeros on a number line and determine the intervals where the expression is positive or negative. Finally, you can use these intervals to write the solution as an inequality.
Can a quadratic inequality have more than one solution?
Yes, a quadratic inequality can have more than one solution. It can have two solutions if the parabola intersects the x-axis at two distinct points, and it can have infinitely many solutions if the parabola is entirely above or below the x-axis.
How do you graph a quadratic inequality?
To graph a quadratic inequality, you must first graph the corresponding quadratic function. Then, you can shade the region above or below the x-axis, depending on the inequality symbol. You can also use test points to determine which side of the inequality to shade.
What is the difference between a quadratic inequality and a quadratic equation?
A quadratic inequality involves an inequality symbol (<, >, ≤, or ≥) and represents a region on a graph, while a quadratic equation involves an equal sign (=) and represents the points where the parabola intersects the x-axis on a graph.
  • General Math
  • General Math
  • General Math
  • General Math
