Question related to Bending Stress and Shear Stress of a I shape beam
In summary, the beam ABCD with pin connections at B and C is subjected to a uniformly distributed load w. The allowable bending stress is 150 MPa and the allowable shear stress is 80 MPa. After calculating the maximum shear force and bending moment, it was determined that the correct solution for w is 57.1 kN/m. Some errors were made in the calculations, including using incorrect values for the height and distances in the equations for moment of inertia, shear stress, and bending stress. Once these errors were corrected, the correct solution could be obtained.
kuku
1. Homework Statement
The beam ABCD with the cross section has pin connections at B and C and is subjected to a uniformly distributed load w. If the allowable bending stress is 150MPa and the allowable shear stress is 80 Mpa. ( Hint : the horizontal reaction forces at A and D are both zero).
the picture of beam is :
https://fbcdn-sphotos-f-a.akamaihd...._=1425149738_3735a63d312d409ebc2ebe6405dca32c
Bending stress = My/I
Shear stress = VQ/It
I tried in this way but cannot get the answer. answer : w = 57.1 kn/m
6 Rd-5w*3=0
6Rd = 15w
Rd = 2.5w
Ra=2.5 w
then i draw shear force diagram to find Vmax.
V max = 2500w N
I also find neutral axis at 165mm
Moment of Inertia I = 1/12 * 300^3*10 + 2 [ 1/12*15^3*70+15*170*157.5^2]
= 1.491075*10^-4 m^4
t= 0.01 m
Q = y'A' = 150*10*75+170*15*157.5
= 5.14125*10^-4 m^3
So, we have 80*10^6 = 2500w * 5.14125*10^-4 / 1.491075*10^-4 *0.01
w = 92.8 kN
_________________________________________________________________
For bending moment stress
I draw bending moment diagram to find max bending moment = 4.375 kN.m
150*10^6 = (4.375w * 165/1000) / 1.491075*10^-4
w = 30.98 kNCan anyone tell me what's wrong that I can't get the solution w = 57.1 kN/m
Thank you :cool:
Hello,
Thank you for your attempt at solving this problem. I can see that you have correctly calculated the maximum shear force and bending moment, which are important values in determining the allowable load for the beam. However, there are a few errors in your calculations that are leading to the incorrect solution.
Firstly, in your calculation for the moment of inertia (I), you have used the incorrect value for the height (h) of the beam. The correct value for h is 300 mm, not 75 mm. This will lead to a different value for I, and ultimately a different value for the allowable load.
Secondly, in your calculation for the shear stress, you have used the incorrect value for the distance (y) from the neutral axis to the top of the beam. The correct value for y is 150 mm, not 157.5 mm. This will also lead to a different value for the allowable load.
Lastly, in your calculation for the bending stress, you have used the incorrect value for the distance (y) from the neutral axis to the point where the bending stress is being calculated. The correct value for y should be the distance from the neutral axis to the top of the beam, which is 150 mm, not 165 mm.
Once you make these corrections, your calculations should lead to the correct solution of w = 57.1 kN/m. I hope this helps and good luck with your studies.
1. What is bending stress?
Bending stress is the stress that occurs in a beam when it is subjected to a bending moment. It is the result of the internal forces that act on the beam, causing it to bend or deform.
2. How is bending stress calculated?
Bending stress is calculated using the formula sigma = My/I, where sigma is the bending stress, M is the bending moment, y is the distance from the neutral axis to the outermost point on the beam, and I is the moment of inertia of the beam.
3. What factors affect the bending stress of a beam?
The bending stress of a beam is affected by several factors including the material properties of the beam, the cross-sectional shape and dimensions of the beam, the magnitude and location of the applied load, and the beam's support conditions.
4. What is shear stress?
Shear stress is the stress that occurs in a beam when it is subjected to a shear force. It is the result of the internal forces that act parallel to the cross-section of the beam, causing it to shear or slide.
5. How is shear stress calculated?
Shear stress is calculated using the formula tau = VQ/It, where tau is the shear stress, V is the shear force, Q is the first moment of area of the beam's cross-section, I is the moment of inertia of the beam, and t is the thickness of the beam's cross-section.
