What Is the Focusing Range for a 45 mm Lens on an SLR Camera?
In summary, the range of movement for a lens with a focal length of 45 mm in a 35 mm single lens reflex camera is 1.49 mm, in order to focus on objects ranging from infinity to 1.4 m away. This is determined using the thin-lens formula for both cases, where 1/infinity can be considered as zero, and the difference between the two values of q is 1.49 mm.
HenryHH
In a 35 mm single lens reflex camera (SLR) the distance from the lens to the film is varied in order to focus on objects at varying distances. Over what range must a lens of 45 mm focal length vary if the camera is to be able to focus on objects ranging in distance from infinity down to 1.4 m from the camera?
1/f = 1/p +1/q
First, the thin-lens formula is applied for the case of focusing on objects at a distance of infinity:
1/45 = 1/∞ + 1/q
q = 45 mm
Then, the same formula is applied for the case of focusing on objects at a distance of 1.4 mm:
1/45 = 1/1400 + 1/q
q = 46.49 mm
Therefore, the range of movement is 46.49 - 45 = 1.49 mm.
I actually had help from a tutor with solving this problem. I understand the problem itself, but what I don't understand is how q = 45 was derived from the equation 1/45 = 1/∞ + 1/q since the equation contains ∞ as a variable.
Generally speaking, how do you solve equations with infinity (∞) as one of the variables? I am really stumped...
1/∞ is a very tiny number, called zero. :smile:
So 1/p = 1/q, giving p=q
OH... so 1/infinity basically just cancels out, then? Duh... thanks!
I wouldn't use the phrase "cancels out".
 Perhaps "fades away", "disappears", or "vanishes", would be appropriate though.
The concept of infinity (∞) can be difficult to grasp, but in mathematics, it is often treated as a limit or a value that is larger than any real or imaginable number. In the context of this problem, the distance from the lens to an object at infinity is essentially the same as the focal length of the lens, since the object is so far away that the light rays can be considered parallel. Therefore, we can substitute ∞ for the distance in the thin-lens formula, and solve for q. This gives us q = 45 mm, which means that the lens must be positioned at a distance of 45 mm from the film in order to focus on objects at infinity.
To solve equations with infinity as a variable, we can apply the same principles as we would with any other variable. In this case, we can manipulate the equation algebraically to isolate the variable (q in this case) and solve for it. In some cases, we may also need to use limits or other mathematical techniques to find a solution. It is important to keep in mind that infinity is not a number, but rather a concept that we use in mathematics to represent something that is unbounded or without limit.
Related to What Is the Focusing Range for a 45 mm Lens on an SLR Camera?
1. What is the range of movement of a lens?
The range of movement of a lens refers to the distance that the lens can move in order to focus on different subjects. This movement is typically measured in millimeters and can vary depending on the type of lens.
2. How is the range of movement of a lens determined?
The range of movement of a lens is determined by the focal length and the construction of the lens. A longer focal length typically requires a larger range of movement in order to focus on different subjects, while a wider aperture can also affect the range of movement.
3. Why is the range of movement important in photography?
The range of movement of a lens is important in photography because it allows the photographer to focus on different subjects and adjust the depth of field. Without a sufficient range of movement, it may be difficult to achieve the desired focus and composition in a photograph.
4. Can the range of movement of a lens be adjusted?
Yes, the range of movement of a lens can be adjusted through manual or automatic focusing. With manual focusing, the photographer physically adjusts the lens by rotating the focus ring. With automatic focusing, the camera's autofocus system adjusts the lens based on the subject's distance from the camera.
5. How does the range of movement affect image quality?
The range of movement of a lens can affect image quality in several ways. If the lens has a limited range of movement, it may be difficult to achieve a sharp focus on the subject. Additionally, a lens with a larger range of movement may have more elements and moving parts, which can potentially impact image sharpness and introduce distortion.
