Range of speeds of particle confined in box
The discussion centers on estimating the speed range of a proton confined within a nucleus of diameter 3.80 femtometers using the uncertainty principle. The calculation involves the relationship between position uncertainty and momentum, leading to a derived speed of approximately 5.22 x 10^7 m/s. There is confusion regarding the use of Planck's constant (h) versus the reduced Planck's constant (h-bar) in the calculations. Participants clarify that the uncertainty principle should use h-bar for accurate results. The original poster is encouraged to revisit their setup and calculations for consistency with quantum mechanics principles.
Linus Pauling
1. A proton is confined within an atomic nucleus of diameter 3.80 fm. Estimate the smallest range of speeds you might find for a proton in the nucleus.
2. Uncertainty Principle
3. 3.80fm * mv = h/2
Soliving for h, using mass of proton = 1.67*10-27kg, I obtain v = 5.22*107
. Then, dividing by two I obtain a final answer:
0 less than/equal to v less than/equal to 2.6*107
Is this correct?
That is how I would set it up. I got a different answer though. You are using h-bar not h right?
Why h-bar? The uncertainty principle is delta(x)delta(p) greater than/equal to h/2
any luck with this question? I have the same question with different values am not sure how to approach it
Op set it up right he just used h instead of h-bar.
