Reason for change in deformation if we switch from n to p
In summary, n-type and p-type silicon have similar deformation values up to 3000 KPa, but their different mechanical properties become more apparent at higher pressures and the threshold of 3000 KPa may indicate the maximum capacity of the sensor.
Ganga Raju
In the research paper, a piezoresistive pressure sensor is designed.
My question is if we look at table 1
in column 1 the values of deformation of diaphragm for single crystal silicon n type is used
If we interchange n type and p type the values for 1000,2000 Kpa are same and then the values changes, why ?
and why n,p type is not getting any deformation after 3000 Kpa ?
  • 28I20-IJAET0520926_v7_iss2_521-531.pdf
The values of deformation for single crystal silicon n type and p type remain the same up to 3000 KPa because both materials have similar mechanical properties. As the pressure increases, the differences in the mechanical properties of the two types of silicon start to become more pronounced, leading to different levels of deformation at higher pressures. This difference is most likely due to the different crystal structures of n-type and p-type silicon, which affects their ability to resist deformation. Additionally, the threshold values of 3000 KPa might indicate that the sensor has reached its maximum capacity, meaning that further increases in pressure will not cause any additional deformation.
1. What is the difference between n and p type semiconductors?
N and p type semiconductors are two types of materials used in electronic devices. N type semiconductors have an excess of negatively charged particles, known as electrons, while p type semiconductors have an excess of positively charged particles, known as holes.
2. How does switching from n to p type affect the deformation of a material?
Switching from n to p type can cause a change in the deformation of a material. This is because the type of semiconductor affects the movement of charges within the material, which in turn can affect its mechanical properties such as flexibility and elasticity.
3. Why does the deformation change when switching from n to p type?
The change in deformation is due to the different movement of charges in n and p type semiconductors. In n type semiconductors, electrons are the majority charge carriers and are able to move freely, while in p type semiconductors, holes are the majority charge carriers and can also move freely. This difference in charge carrier movement can result in a change in the material's deformation.
4. Can the reason for change in deformation be predicted when switching from n to p type?
The exact reason for the change in deformation when switching from n to p type cannot be predicted with certainty. This is because it depends on various factors such as the properties of the specific material, the type of charge carriers, and the external conditions.
5. How can the change in deformation be measured when switching from n to p type?
The change in deformation can be measured using various techniques such as tensile testing, where the material is pulled apart to measure its strength and elasticity. Other methods include using strain gauges or optical techniques such as digital image correlation to measure the change in shape and size of the material under different conditions.
  • Atomic and Condensed Matter
  • Materials and Chemical Engineering
  • Math Proof Training and Practice
20K
