Why Does a Wave Reflect at a Free End with Unchanged Polarity?
In summary: However, the back of the wave pulse is still moving to the right, so it moves back into the string. This creates a reflected wave with the same polarity as the incident wave. In summary, when a wave pulse on a string moves towards a free end, it reflects and propagates from right to left with the same speed and amplitude as the incident wave, and with the same polarity. The slope and vertical force at the free end must be zero for the end to move without infinite acceleration, which is explained by considering the situation where the end is attached to a mass. However, for an actual free string, the force and angle must both go to zero for the end to move. The reflected wave has the same polarity as the incident
kelvin490
A wave pulse on a string moving from left to right towards a free end will reflect and propagates from right to left with the same speed and amplitude as the incident wave, and with the same polarity.
My question is, why the slope and the vertical force must be zero at the free end? If the restoring force is zero why the free end can move? Some textbooks explain by imaging a wave with same polarity traveling in opposite direction but I think it's just an analogy and the phenomenon is better be explained by force interaction.
Some ref:
p. 489 University Physics
https://books.google.com.hk/books?id=7S1yAgAAQBAJ&pg=PA489&lpg=PA489&dq=string+is+now+stretched,+giving+increased+tension,+so+the+free+end+of+the+string+is&source=bl&ots=oSDs7tqt4M&sig=5zzzUMnsC8dG_qdObx9nJxQRPkg&hl=zh-TW&sa=X&ei=MT2VVYbREdP-8QWssoDgAw&ved=0CCQQ6AEwAQ#v=onepage&q&f=false
http://www.acs.psu.edu/drussell/Demos/reflect/reflect.html
Science news on Phys.org
Consider what is going on at the free end. Think of the situation where the end is attached to a mass m. The acceleration of the mass would be proportional to the transversal force from the string. As the mass goes to zero (which is what you would have for an actual free string), the force needs to go to zero for the mass not to have infinite acceleration. For the transversal force to go to zero, the angle the string makes with the horizontal must go to zero.
Likes kelvin490
Thanks. It is a common way to explain why the slope and force is zero at the free end. But I still have some more questions (may be stupid questions): Why the end particle of the string moves if there is no force ever acted on it? Why the end of the string can move to a height which is two times the amplitude of incident wave? What makes it move back and create a reflected wave without polarity change?
You have to go back to the assumption that the end is massless here. The force equation would tell you that 0 = 0a, which is always satisfied, so just from this you do not get a constraint.
You are here talking about a single wave pulse. When it propagates along the string, the front is being pulled down (and therefore decelerated). When you reach the free end, this no longer happens and you reach a higher amplitude.
Likes sophiecentaur
1. What is a reflected wave from a free end?
A reflected wave from a free end is a wave that bounces back when it reaches the end of a medium, such as a string or a spring, that is fixed at one end. This phenomenon is also known as wave reflection.
2. How does a reflected wave from a free end differ from a transmitted wave?
A reflected wave from a free end is a wave that bounces back in the opposite direction when it reaches the end of a medium, while a transmitted wave is a wave that continues to propagate through the medium. In other words, a reflected wave changes direction, while a transmitted wave does not.
3. What factors affect the reflection of a wave from a free end?
The reflection of a wave from a free end can be affected by several factors, including the angle of incidence, the properties of the medium, and the wavelength of the wave. These factors can determine the amount of energy that is reflected back and the behavior of the reflected wave.
4. How is the intensity of a reflected wave from a free end related to the intensity of the incident wave?
The intensity of a reflected wave from a free end is often related to the intensity of the incident wave by the law of reflection, which states that the angle of incidence is equal to the angle of reflection. This means that the intensity of the reflected wave can be greater or less than the intensity of the incident wave, depending on the angle of incidence.
5. What real-life applications involve reflected waves from free ends?
Reflected waves from free ends have several real-life applications, such as in musical instruments like guitars and violins. They are also used in radar technology, where waves are transmitted and then reflected off of objects to determine their distance and location. Additionally, they play a role in seismic exploration for oil and gas, where reflected waves are analyzed to determine the composition and structure of the Earth's subsurface.
  • Other Physics Topics
