Related Rates: Calculating the Pressure Change in a Gas Container
  • Thread starter Thread starter pry_or
    Related rates
pry_or
A container of constant volume contains a quantity of gas under pressure. At t=0, the pressure is 4 psi and the temperature is 15°C per minute. What is the rate of change of the pressure inside the container at time t=0?
\frac{P}{T} = constant
Taking the derivative of both sides and then simplifying, I ended up with:
T\frac{dP}{dT} - P\frac{dT}{dT} = 0
So solving for dP/dt:
\frac{dP}{dt} = \frac{P}{T}\frac{dT}{dt}
This is where I get stuck. I know P = 4 psi and dT/dt = 15°C per minute, but I can't figure out how to determine T. Without knowing the actual value of the constant in the original formula, I don't see how it is possible. The wording of the temperature value in the problem sounds odd to me. The only thing I can think of is that the temperature should be assumed to be 0°C at t=0 and so dP/dt does not exist. Is this it, or am I missing some way to find T?
15°C per minute is not a temperature. It's the time rate of change of temperature. What is the exact wording of this problem?
That is the exact wording of the problem. That's why I said the wording was odd.
Whoever wrote the problem made a mistake. I would get some clarification from the instructor as to what the real problem is.
That's what I expected, thank you!
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
