Calculating Minimum Energy for Relativistic Collision of Proton and Photon
In summary, the minimum energy for a proton to cause a head-on collision with a cosmic microwave-background photon and produce a delta baryon is a very large energy, approximately 1232 MeV. This can be calculated using the equation K = E - mc^2 and taking into account the doppler shift of the photon's energy in the center of momentum frame. The Greisen-Zatsepin-Kuzmin limit is relevant in this calculation.
joriarty
62
Consider the following reaction that is possible when a proton (p+) collides with a photon (γ):
p+ + γ → ∆+.
Suppose that the photon is a cosmic microwave-background (CMB) photon of energy 2.3 × 10−4eV. Calculate the minimum energy that the proton must have for this reaction to take place. m = 1232eV/c2.
Hints:
• The minimum energy will be for a head-on collision. Be careful with the signs of the momenta when doing the calculation.
• The answer is a very large energy, so you will be able to make the approximation that the the proton energy is much bigger than it’s rest energy.
• You might find it interesting to look up Greisen-Zatsepin-Kuzmin limit. (is this relevant?)
K = E − mc2
E2 −(pc)2 =(mc2)2
(See attached table)
I am thinking that because I'm after the minimum energy of the proton for a head on collision, would this mean that the delta baryon is going to have zero kinetic energy and momentum thus a total energy 1232 MeV?
I can then say that the proton has momentum pc = -2.3*10-10MeV. But that just makes the energy of the proton also equal to 938.3 MeV within the precision of my calculator. That's not right, I should get Eproton>>mprotonc2.
Where to now? Does the change in mass of 293.7 MeV have anything to do with this?
Thanks!
The GZK limit is very relevant, that's what this whole problem is about. The 10^(-4)ev CMB photon energy is it's energy in the 'lab' frame, one at rest with respect to the CMB background. If you consider the collision in the center of momentum frame of a highly energetic proton, the photon will be 'doppler shifted' up to a high enough energy to produce a delta. You want the energy of the proton in the 'lab' frame.
1. What is a relativistic collision?
A relativistic collision is a type of collision that occurs at high speeds, typically close to the speed of light. This type of collision takes into account the principles of relativity, including time dilation and length contraction, in order to accurately describe the behavior of particles involved in the collision.
2. How is energy conserved in a relativistic collision?
In a relativistic collision, energy is conserved through the use of Einstein's famous equation, E=mc². This equation shows the relationship between mass and energy, and allows for the calculation of energy in a relativistic system.
3. What is the difference between an elastic and inelastic relativistic collision?
In an elastic collision, both kinetic energy and momentum are conserved, while in an inelastic collision, only momentum is conserved. In a relativistic system, both types of collisions take into account the principles of relativity, but the final velocities and energies of the particles may differ.
4. Can relativistic collisions be observed in everyday life?
No, relativistic collisions typically occur at speeds close to the speed of light, which is not attainable in everyday situations. These types of collisions are mostly observed in high energy particle accelerators, such as the Large Hadron Collider.
5. How do relativistic collisions impact our understanding of the universe?
Relativistic collisions are important in understanding the behavior of particles at high speeds, which is crucial in fields such as astrophysics and cosmology. They also play a role in the development of theories such as the Big Bang theory and the Standard Model of particle physics.
