aDabOfRanch
- 3
The resolution of the eye is ultimately limited by the pupil diameter. What is the smallest diameter spot the eye can produce on the retina if the pupil diameter is 2.59 mm? Assume light with a wavelength of λ = 550 nm. (Note: The distance from the pupil to the retina is 25.4 mm. In addition, the space between the pupil and the retina is filled with a fluid whose index of refraction is n = 1.336.)
Hint: The size of the spot is twice the distance from the main axis to the first minimum.
θrad=1.22λ/D
tanθ=Ym/L
Found the resolving angle using θrad=1.22λ/D where D is the diameter of the pupil, and the angle turned out to be 1.98E-4 radians. Then I used the angle to find the distance from the main axis to the first minima by plugging in θ into tanθ=Ym/L solving for Y1 I got 5.03
Using the hint provided I doubled 5.03 to get 10.06μm however the answer is 9.85μm
