B Resolving the Relativity of Simultaneity: A Geometric Approach
Andrew1955
Hi, I read through einsteins popular book on relativity translated into english around 1922 and subsequently read the original 1905 paper on the electrodynamics of moving bodies.
So we have a fixed observer seeing flashes happening at the same time and we have a moving observer seeing one flash after the other. However we know the reason the moving observer sees one flash before the other is because he is moving towards the first flash. By einsteins definition of his experiment the two flashes occur at the same time.
So how do we then get to the conclusion of time passing at different rates?
Yes we can say the observers are confused by their experience due to the motion of the train and the finite speed of light, but it seems clear to me it is a fact the flashes happen at the same time on the train/moving line.
Am i missing something or am I reading too much into the proposed thought experiment which in fact is not so very good at introducing the idea?
You can't analyse it from only one point of view.
Both observers consider themselves as at rest, and between the location of the two strikes *. If one see the flashes at the same time, the strikes were simultaneous for them, if the flashes are not seen at the same time, the strikes were not simultaneous for them. The experiment goes on to show the two observers can't both see the flashes at the same time, so their judgement of the simultaneity of the strikes can't be the same. Neither is wrong, though they don't agree.
(Note that two other strikes could occur, that the train observer considers simultaneous and the embankment observer doesn't. There's nothing special about either observer.)
It's easy to get misled into thinking the train is "really" the thing moving, because we think of the ground as not moving and trains are moving, so we can think the ground observers view is the "real" view, but that's missing the point.
(* the train observer is at rest relative to the train, and as far as they are concerned it's the tracks and the embankment observer who is moving. Also note that the strikes are clearly said to be hitting across the tracks and the ends of the carriages.)
Likes Vitro
I realize the observers do not both see simultaneous flashes. The issue i am raising is why it matters? how does einstein then leap from observer experience to time itself having changed? Sure the two observers might be confused but we can see the cause of their confusion, ie one observer is moving more rapidly towards one of the light flashes.
Andrew1955 said:
I realize the observers do not both see simultaneous flashes. The issue i am raising is why it matters? how does einstein then leap from observer experience to time itself having changed? Sure the two observers might be confused by we can see the cause of their confusion.
Neither is "confused". They are both correct in their view. The strikes were simultaneous for one, they were not for the other.
Overall, the thing is we tend to see distance and time as fixed, but they are not, they wiggle as it's the speed of light that's actually fixed.
A lot of that comes down to the relativity of simultaneity. One way to visualise it would be the ticks of clocks. Say two people in relative motion (each thinks they are at rest and the other is moving) are holding clocks. Since simultaneity is not absolute, they end up not being able to say that their clocks tick each second (or minute or hour) at the "same time". So they can't measure the same time.
Each observer is correct in what he observes. Only one correctly detects reality using his vision. One observer does not see a simultaneous flash. However on the moving object there were two simultaneous flashes. We can explain to the observer on the moving platform why he has not seen a simultaneous flash when in fact it did in reality happen simultaneously. In reality he did not experience it simultaneously even though in reality it did happen simultaneously.
Again the point i am making here is how does Einstein make the enormous leap to time being different due to relative motion? How did he go from observer experience of time being different to saying time passed at a different rate?
You seem to contradict yourself, but, why is only one correct?
I think you've mixed up the scenario.
No, as soon as you say "in reality" here you're asserting absolute simultaenity, and missing the whole point of what the experiment shows us.
There's nothing special about the embankment observer. Again, it could be that two strikes are simultaneous for the train observer and not the embankment observer.
It's not an enourmous leap, and it's covered above.
Maybe you can quote the exact passage that concerns you, but I do think you should get the relativity of simultaenity straight before worrying about what it leads to.
https://www.marxists.org/reference/archive/einstein/works/1910s/relative/relativity.pdf
Page 25
Einstein says "
Lightning has struck the rails on our railway embankment at two places A
and B far
distant from each other. I make the additional assertion that these two lightning flashes
occurred simultaneously."
He supplies a diagram to show the points of the train A and B are exactly alongside the embankment points A and B at the moment of the simultaneous lighting strikes.
Einstein then says "every event which takes place along the line also takes place at a particular point of the train."
and
the events A and
B also correspond to positions A
and B on the train"
A light pulse inside a moving train takes a little bit of extra time to travel from rear to front, as observed from the platform. Returning to the rear cancels that out almost perfectly at slow speeds, but not at high speeds.
Check out yourself that the above is true, no relativity is required.
When the train moves at relativistic speed, it takes a long time for a light pulse to travel from the rear to the front and then back to the rear, as observed from the platform. A passenger on the train does not notice that, so he must have a slow wristwatch or a slow atomic clock, as observed from the platform.
Page 25
Einstein says "
and B far
It's rather dishonest to have that quote and omit the following words "If I ask you whether there is sense in this statement, you will answer my question with a decided "Yes." But if I now approach you with the request to explain to me the sense of the statement more precisely, you find after some consideration that the answer to this question is not so easy as it appears at first sight."
In any case, study the next chapter, then come back to this one. It's what clearly explains the relativity of simultaneity. https://www.marxists.org/reference/archive/einstein/works/1910s/relative/ch09.htm
I am sorry to hear you find me dishonest.
From my point of view i am trying to understand why einsteins concludes what he concludes.
I am not sure what you are wanting to say to me.
Einstein tells us the train observer does not see simultaneity because he is moving towards the light rays coming from B.
That's from the point of view of the embankment observer.
From the point of view of the train observer, they are exactly between the two strikes, and they are at rest, so if the strikes were simultaneous they'd see the flashes at the same time. They don't, so according to them, the strikes were not simultaneous. It's no bother to them that the embankment observer saw the flashes at the same time, it makes perfect sense because according to the train observer the embankment observer was moving towards one strike and away from the other.
Both views are correct, even though the two observers don't agree on simultaneity.
Maybe forget relativity of simultaneity for a moment, as you're stuck on thinking it's absolute.
Consider some (ambidextrous!) person holding a ball in each hand, we'll consider them as at rest. They throw the two balls forward at 20 km/h at two other people.
Those two other people are running towards the ball thrower; one at 5 km/h and one at 10 km/h.
The one running at 5 km/h finds it easier to catch their ball, than the one running at 10 km/h; as their speed relative to the ball is 25 km/h compared to the other person for whom the ball is 30 km/h.
OK so far? That's our regular non-relativistic World, as we see it every day.
It's wrong.
What if it's not balls but light? Two people are moving towards a light source. At different speeds.
The trick is, light will always be measured to be moving at the same speed (in a vacuum ...). How can the two people moving towards the light source at different speeds, both measure that light to be moving at the same speed? Because distance and time are not the same for both of them.
So you agree that the flashes of light are not simultaneous from the point of view of the train observer? What's the problem, then?
This is going to be easier if you just stick with einsteins text.
Are you saying the timing of the two events on the embankment are not directly related to the timing of the two events on the train where both events are known as A and B?
So I am asking you how are you interpreting his text and diagram which i drew your attention to earlier? You strongly appear to be saying the events are not corresponding to each other. That seems to require an explanation by you.
Einstein talks about events and uses the same letters for Event A on the embankment and the A event on the train.
-----------------He supplies a diagram to show the points of the train A and B are exactly alongside the embankment points A and B at the moment of the simultaneous lighting strikes.
and
the events A and
and B on the train"
Its a consequence of the constancy of the speed of light which means that light travels at the same speed, c, to all observers (in flat spacetime/inertial frames).
Your situation is essentially identical to the traincar problem.
First, imagine you are inside a moving traincar, directly in the center, and you fire two beams of light in either direction. The invariance of the speed of light in your frame of reference means they will hit the train walls at the same time.
Now imagine there is another person sitting on the station witnessing the events happening in the train as it moves by. The invariance of the speed of light in their reference frame means that it will hit the back first and the front later.
Neither frame is more valid than the other, because how could you determine that?
This isn't like throwing two balls to either end of the traincar, because the light doesn't have the additional velocity of the train. Think about it: imagine the person standing in the middle of the train threw two balls to either end of the traincar and they hit the walls simultaneously. Because the balls have the initial velocity of the train, they would also contact the walls simultaneously in the outside observer's frame too. This isn't the case with light.
Because of this relativity of simultaneity, Einstein thought that maybe it was time that was changing. He concluded that time may be flexible and went on to make an incredible theory around that.
Likes Vitro
Einstein appears to be saying the reason for the flash not being simultaneous for the train observer is because he is moving towards the light rays coming from B and moving away from the light rays coming from A. According to Einstein the A events are linked as are the B events. event A on the embankment is an event A on the train. Einstein gives no indication event A on the embankment is not happening at the same time as event A on the train.
If in advance of his words he is saying A on the embankment is at a different epoque as event A on the train the whole wording just becomes very odd.
All he is saying is the two observers cannot agree on simultaneity using the method he has chosen. He then leaps into time being different for each observer.
I don't know why you make this more complicated than it is.
He stipulates that A and B are simultaneous for the embankment observer, then asks if they (A and B) are simultaneous for the train observer. Turns out the answer is no.
Yes, A is on the tracks and train, yes, B is on the tracks and train. But that doesn't mean the two observers in relative motion must agree whether A and B were simultaneous.
Yes, that's from the point of view of the ground observer. From the point of view the train observer he's not moving at all, so the flashes of light ARE non-simultaneous.
Likes Alfredo Tifi
A lazy Shizno
Thanks. It seems I was not understanding what Einstein was saying and getting confused by what is meant by the invariance of the speed of light.
I will have to think about the text but it seems to be sorted out.
Cheers
Andrew
This is a highly counter-intuitive conclusion for me, and I think for most people.
The highly counter-intuitive axiom that leads to this conclusion is that all observers measure the speed of light to be the same speed in all frames. If one takes that as a starting point and follows it, one arrives at the conclusion that all observers may not then agree on the rate of passage of time.
It is experimentally verified beyond any room for reasonable doubt that the speed of light is constant in all frames - this isn't a derived conclusion from more fundamental axioms, it is itself a starting point for subsequent reasoning.
It might help you to consider two moving objects on the train - one of them a normal baseball that an observer on the platform sees moving at the speed of the train plus whatever velocity the train passenger see the ball moving at, and one photon baseball that moves at the same speed according to both the platform observer and the train observer regardless of how fast the train is moving. You should be able to see that constraining both observers to always agree on the speed of the photon baseball forces you to change some of the other things that it seems natural for the observers to agree on, like the rate of passing time.
Likes Alfredo Tifi
I am still finding this hard. If it is agreed the A events are one and the same then the only thing left to discuss is what each observer experiences.
I am not getting it.
You guys appear to be saying the A events happen at a different time. If so the whole thought experiment seems to be a waste of time as no meaning can be found from it.
Andrew1955 said:
I am still finding this hard...
Have you understood A Lazy Shisno's example? I too prefer the scenario with a single flash of light originating in the middle of the train instead of Einstein's two flashes starting at the ends, but they are both equally valid and illustrate the exact same thing.
In A Lazy Shisno's example define events A = "light hits left wall" and B = "light hits right wall". Do you agree and understand that these events happen at the same time for the observer on the train? Do you understand and agree that these same two events do not happen at the same time for the observer on the platform?
That's all there is to it, and the reason is because the speed of light is finite and the same for both observers, they both measure it to propagate at ##c## to the left and to the right in their own coordinate system.
Likes A Lazy Shisno
I understand a lazy shisnos example alright. I am still not clear why peculiarities about the speed of light must mean time and length must also change.
If light causes us to perceive weird stuff does this mean that weird stuff is really happening? If we see wave lengths of light as red is red really out there or is there just colourless energy which we interpret and imagine as being red? Do you think the sky is actually blue? The grass is green? These things are only illusions created by the human visual system.
We use light to help us perceive reality. If light tells us time has changed, should be believe that just because 'light says its true'.?
For that you have to move beyond the relativity of simultaneity thought experiment: google for "light clock time dilation" to find the simplest thought experiment that demonstrates time dilation.
To understand Einstein's coordinate system (which is considered the conventional system) the half-hour video YouTube instructor/animation listed below does a remarkable job at simplifying the relationships you describe in SR:
Episode 42. The Lorentz Transformation
It is a short 30 minute Caltech college classroom lecture and animation with Professor David Goodstein.
Prof. Goodstein was a student of Feynman who was noted for his uncanny ability to make physics understandable to the neophyte and Goodstein is no slouch himself. I was able to obtain a DVD set just before the series sales were discontinued, but it is still relevant today, perhaps only a bit incomplete due to new discoveries. I'm glad it is still available on YouTube because I thought it would be lost forever.
Wes
CREDIT and additional webpage info:
"Episode 42. The Lorentz Transformation: If the speed of light is to be the same for all observers, then the length of a meter stick, or the rate of a ticking clock, depends on who measures it.
“The Mechanical Universe,” is a critically-acclaimed series of 52 thirty-minute videos covering the basic topics of an introductory university physics course.
Each program in the series opens and closes with Caltech Professor David Goodstein providing philosophical, historical and often humorous insight into the subject at hand while lecturing to his freshman physics class. The series contains hundreds of computer animation segments, created by Dr. James F. Blinn, as the primary tool of instruction. Dynamic location footage and historical re-creations are also used to stress the fact that science is a human endeavor.
The series was originally produced as a broadcast telecourse in 1985 by Caltech and Intelecom, Inc. with program funding from the Annenberg/CPB Project.
The online version of the series is sponsored by the Information Science and Technology initiative at Caltech. http://ist.caltech.edu
©1985 California Institute of Technology, The Corporation for Community College Television, and The Annenberg/CPB Project"
This post does a nice job introducing the traincar problem and the relativity of simultaneity, but the paragraph I put in bold needs qualification: In Newtonian mechanics, yes, the balls hit the walls simultaneously in all frames; but in special relativity, they do not.
No. But light is not causing us to perceive weird behavior in this case. Rather, light is being used to demonstrate that weird stuff is actually happening. The weird stuff can be demonstrated in other ways that don't involve light. For example, engineers who orchestrate the various clocks used in the GPS must take this weird behavior into account otherwise the GPS receiver you use to find your location wouldn't be precise enough to locate the city you're in, let alone the street corner you're on. The weird stuff really happens.
I recommend that before you try to understand Einstein's relativity you try to understand this example from the relativity we had before Einstein gave us his.
You toss a ball directly upward and then catch it when it comes back down, about 0.5 s later. To you it travels along a vertical line. If you do it while seated in an airplane traveling at 200 m/s you know in that 0.5 s the plane moves a distance of 100 m, so the ball doesn't move in a vertical line, it follows a curved path. So, what is the true path of the ball? Is the path really curved or is it really straight?
Likes SiennaTheGr8
Andrew1955 said:
... You guys appear to be saying the A events happen at a different time. ...
No, it's about whether A happens at the same time as B, and more interestingly, if two observers in relative motion can agree on that.
The relativity of simultaneity should hold between the two frames no matter if a ball or light is used. I think to show this you would have to use the relativistic addition of velocities whereas you are assuming classical addition.
@pixel has a good point. The ball doesn't have the additional velocity of the train, either. There's nothing special about the light itself in this context, the thing that's special is the speed of the light. I realize that everybody knows this, but it might be worth making explicit because sometimes learners are confused by it.
  • #31
  • #32
There is more than one "time". Each reference frame judges the time that events occur by its own set of clocks synchronized within its reference frame. But if two frames in relative motion try to synchronize between the two at one point, they are forced to be unsynchronized at other points in the direction of relative motion. So they can never agree on whether two events which are separated in the direction of relative motion are simultaneous. If one reference frame thinks that they are simultaneous, then the other can not agree.
I couldn't disagree more. It helps one understand how it all fits together. It helps one to understand how each reference frame can think that the other's clocks are running too slow. -- Because each reference frame is moving toward the other reference frame's trailing clocks, which people in the first frame thinks were synchronized incorrectly.
  • #33
SiennaTheGr8 said:
I think @SiennaTheGr8 likewise had a good point in #26. :wink:
@pixel missed your post #26 and would have otherwise referenced it.
Likes SiennaTheGr8
  • #34
The question I would add to this discussion is what is time? I would stress that it is not a thing itself but rather a measurement or snapshot of the state of the relationship of things (atoms) at a particular moment. Personally I think Einstein treats time too much as a thing.
  • #35
Sorry, I'm still trying to learn some of the finer details of SR, but why doesn't the ball have the initial velocity of the train? If I'm on a train and I have a ball in my hand, it has the same velocity as the train. So when I throw it in the direction of the train's motion, it has the velocity of the train plus the velocity I imparted on it (from the perspective of an outside observer). I thought the special thing about light is that its speed doesn't depend on the velocity of the thing it's being emitted from?
  • #36
Yeah, the special thing about light is its speed. Any object that has the speed of light in one inertial FoF moves at the speed of light in any other inertial FoF. The velocity of light (or any object moving at the speed of light), though, unlike speed, can change with the change of the FoF (inertial). And it does so according to the laws of SR (velocity addition formulas). E.g. if you shoot a photon perpendicular to the movement of the train (from your point of view), while you on the train, the photon will have the additional velocity of the train along the direction of its movement (from the ground point of view).
  • #37
No, I know what happens when you fire the light perpendicular, but what I'm talking about it that the speed doesn't depend on the speed of the source. When you (on a moving train) throw a ball in the direction of the train's motion, it has the speed of the train plus the speed you threw it at (from the perspective of an outside observer). The point is that light is different, it doesn't have a speed of c plus the velocity of the train, it just has a speed of c in both frames.
  • #38
For humans, time actually is a thing or rather, rotation event. Time is always, always a real rotation of "something". There is no other way to measure a periodic event but to count the clicks as the "merry-go-round" comes around again.
Although confined to a roundy-ness in all clocks, time can be proportioned to any other motion direction within geometries, a length or temperature change as simple examples. It is even true for the "bouncing ball clock" in the relativity animation I tried to promote above in post #25 (so Andrew1955 could finally 'get it'). The ball on Einstein's train is made to bounce in continuous sine-wave-like fashion as it passes... which is merely a set of stretched-out circle-like rotations.
Wes
  • #39
Define "plus". If you're saying that the speed of ball changes (in this case, increases), then yes, the speed of light is special (as Mister T has pointed out in his original post). Because it stays the same. But the amount by which the speed of ball changes is not the exactly the same as in classical non-relativistic mechanics.
  • #40
Yeah, that's what I was trying to get at in my original post. I'm aware that relativistic phenomena obviously apply to the ball, but I was trying to explain that the light doesn't act like a ball being thrown to either end of the traincar because it is independent of the speed of its source, hence why the relativity of simultaneity was realized.
  • #41
But there's nothing special about the light (except for its speed). The relativity of simultaneity is realized, whether we're talking about the light, or the balls. Light is affected by the movement of its source. Only the speed of the light is absolute (not even velocity in general).
  • #42
Yes. The only complication for the thrown ball is that an outside stationary observer will not add the same velocity numbers. He would think that the person on the train is wrong about the ball's speed because of the distortion of distance and time.
  • #43
Yes, it does.
No, adding is not the right way to combine speeds. If you have two wedges and you stack them to make a steeper wedge, you wouldn't add the slopes of the wedges to get the slope of the stacked wedge. That's not the right way to combine slopes.
Because light travels at a special speed, the fastest speed possible. So when you combine it with the speed of something else you get the same speed. Again, adding speeds is not the right way to combine them.
  • #44
Hello Andrew. I've been looking through your thread here. The problem as I see it, is that you do not yet understand the theory, and so as is often the case, you challenge the validity of the relativistic effects. And until one understands the theory, one has no other choice but to lean toward absolute time and absolute simultaneity, because that's the casual everyday experience for the average person. To know whether the relativistic effects are real or not, one must first come to master the LTs and their meaning. Takes awhile. One will never understand it by a collection of relativistic buzz words and buzz phrases from relativists. If you are truly interested, pay close attention to what the experts on the forum here say, and take your own time to start the process of deriving the LTs. And if you wish to learn the theory much sooner than much later, then look at how Minkowski spacetime diagrams are designed, and draft some of your own. Their geometric presentation is very intuitive. It may well save you months to years in the learning process. It did for me.
SR is not about illusionary effect. Its about real relativistic effects, per the LTs. They have been verified by measurement. It is also not about brain processing. The LTs hold for all, and no matter the brain considering them. They held long before the first man walked the earth. For example ... a driver traveling 60 mph wrt the road holds another driver at 30 mph wrt himself, if that driver is 30 mph wrt the road (same direction) ... we do not assume this an illusionary effect simply because we do not know if everyone sees the exact same shade or color of (what we all call) blue.
Andrew1955 said:
We use light to help us perceive reality. If light tells us time has changed, should we believe that just because 'light says its true'.?
If it is compelling enough, certainly. The question is ... what does the math say? Then, is our physical description of the math compelling? The answer is yes, if many tests and their repeat-ability support the math and its interpretation as true. And, that has certainly been the case wrt relativity theory.
Best Regards,
GrayGhost
Likes Dale
  • #45
My take on this thorny issue:
Easy way to vaguely understand:
(1) Every timed measurement is pair of simultaneous events (the hand of your clock arriving at a certain tick mark coinciding with the event you are looking at, e.g., the simultaneous events of the hand of your clock moving to a point and, say, the racer you are timing arriving at a point).
(2) If every timed measurement is at minimum a pair of simultaneous events, and simultaneity is not universal, then timed measurements cannot be universal either.
(3) Since everything that moves in a periodic way can be used as a clock (including the motion of the atoms that make you), it seems to follow that time itself cannot be universal as well.
Hard way to vaguely understand:
How fast are you moving right now?
When you are finished considering that question, hopefully you will realize the question is completely meaningless. You are sitting still, on a spinning earth, which is orbiting the sun, which is orbiting the milky way, which is moving with respect to other galaxies, which are themselves moving in a large galaxy cluster, and so on and so on.
In my humble opinion, the first step to figuring this "paradox" out is understanding this concept. Galileo figured it out some time ago: the principle of relativity. So when you get that down, you'll truly realize there is no inherent difference between the person at rest on the train and the person who sees the train fly by (or from the perspective of the train passenger, the person who flies by the train).
That's a big Step 1, I believe.After that, all you have to do is incorporate the idea that all the fastest signals used for communication move at the same maximum speed for all uniformly moving observers (conveniently, the speed of light is this speed). So what happens when you combine "Step 1" with the fact that there is a maximum speed which all observers agree on regardless of how "fast" (remember the question is meaningless in and of itself) they are moving?
Then you can turn to the good old fashioned light clock (and realize that what applies to a light clock must apply to any type of clock as well, because there is nothing magical about them that makes them unique with respect to the laws of physics). This little cognitive tool really does the trick. So, we have both observers agreeing on the speed of light, and we have the principle of relativity. So we can imagine a pulse of light bouncing vertically between two mirrors, and each trip up is a tick, each trip down is a tock. And we can further imagine the clock being held steadily by one observer (so that the other one sees the clock moving). You end up with a straight up and straight down path of the light for the observer holding it, and a triangle shape for the path of light for the other observer. This will actually give you a right triangle if you combine the two. You can use t and T to represent the time that each measures, and it MAY be that the times are the same, and it MAY be that they are not. Don't make the assumption yet.
So, looking at the triangle, you have a hypotenuse of ct, a horizontal line of vt (v is the relative speed between the two observers), and a vertical line of cT. Use the Pythagorean theorem to find the ratio of t to T, i.e., t/T. (c in both cases because all observers agree on the speed of light, and ct and cT because speed times time is distance). Just basic middle school stuff.
(ct)2 = (vt)2 + (cT)2
First divide everything by (ct)2(1)2 = (v/c)2 + (T/t)2
Now, subtract (v/c)2
1 - (v/c)2 = (T/t)2
Now take the root
√[1 - (v/c)2 ]= T/t.
We could stop right there and see that the only way T = t is if v is 0, but just to make things look standard, divide by T/t and then divide by √[1 - (v/c)2 ]:
t/T = 1/√[1 - (v/c)2 ]
Then multiply by T to get your standard time dilation formula:
t = T/√[1 - (v/c)2 ] ****
So yeah, if you assume the principle of relativity and the constancy of the maximum speed (which conveniently matches with the speed of light), and then use simple thought experiments like a light pulse clock, you see rather clearly that the two observers are going to disagree on time. Then if you are clever enough to realize that, because of the principle of relativity, this result applies universally, in all similar instances regardless of where the observer is and how fast s/he is moving, it is clear that anything that can be used to measure time will give measurements of time that depend upon frame of reference. And if you are super clever, you will note that the atoms your body is made of, the electrical pulses in your brain as you think, and every other thing that moves in a way that could conceivably be used as a clock, will have the same property of time depending on frame of reference, and then you can make the next logical leap to realize that time itself depends on frame of reference, rather than merely clocks.
Then you can make the next logical leap and consider how you would measure the length of something moving past you, and realize you'd be depending on some sort of signal coming from the edges of the object to your eye, taking a finite amount of time to get there, and once again depending upon simultaneity (to get an accurate length, you need to measure the two ends simultaneously, since the object is moving). From there you will realize that length contraction will occur according to observers measuring the length of a moving object. And once again, if you understand Galileo's principle of relativity, you will note that your particular frame of reference is not special, and thus the measured length will also necessarily depend on frame of reference (since it depends on simultaneity, which is not universal).Or you could go the simple route and realize that if simultaneity is not absolute than neither can time be absolute.
(****on a somewhat unrelated note, this works for pre-special relativity time as well. All you have to do is assume that c is infinity, and you end up with t = T, like it was in the old days. Or you could assume that v is approximately zero compared to c, making v/c zero in the limit, reducing the thing to t = T again. But of course we know that c is finite and that all inertial observers agree on it, meaning you are stuck with t not being equal to T when v is not equal to zero).
  • #46
A long as the two occurrences are in the same location (co-located) when they occur then they are a single event.
If they occur at the same place and at the same time according to one observer, then that will be true for all observers. This is an event. This kind of simultaneity is absolute. But if the two events are separated along the line of relative motion, then simultaneity is relative.
Likes FactChecker
  • #47
Andrew1955 had asked ... how did Einstein make the leap of faith that time must pass more slowly in a moving frame, based on his train thought-experiment alone?
Before Maxwell, there was absolute time, absolute simultaneity, and a variable light speed. As such, the train passenger must agree with the embankment observer (and all observers) that the 2 remote flash events occurred simultaneously. Maxwell's 1864 EM theory required light speed be invariant, but this was not supported by experiment until the MMX experiment in 1887. So from about 1887 onward, great physicists first began tackling compatibility issues associated with an invariant light speed, with Einstein succeeding in 1905. Einstein's train scenario assumed an invariant light speed c. As such, the train passenger could no longer agree that the 2 remotely located flash events were simultaneous. So absolute simultaneity was in need of revision. If absolute simultaneity required revision, so too did absolute time. So the train thought-experiment presented the requirement for relative simultaneity (RoS), and also revealed that absolute time was insufficient. If time is not absolute, then it must be relative in some way. However the precise manner in which the measure of space and time needed change required a complete derivation process, which is over-and-above the train thought-experiment.
Andrew mentioned he had read through Einstein's 1905 OEMB paper. Near the beginning of Section 3, Einstein relates the 3 events of the 2 frames (emission, reflection, and reception) in what is often referred to as his 3 Taus Eqn. In particular, the reflection event in system K which DOES NOT occur at the midpoint of the ray's round trip, is related to the reflection event in system k which DOES occur at the midpoint of the ray's round trip. RoS is introduced right there, and that in-and-of-itself gives rise to the relativistic effect of "time-desynchronization of moving entity". The relative measure of space and time (ie LTs) was determined by all that follows (the 3 Taus Eqn) in Section 3, which includes a partial differentiation of his 3 Taus Eqn, a subsequent integration of that result to establish a frame-to-frame relation for time in a general form, then followed by a number of assumptions, substitutions, and algebraic manipulations to attain the LTs in their final form. There was in fact "a dance of sort" between RoS and the relative measure of space & time, such that all observers agree on all LT solns, even though they disagree as to what are simultaneous events and the relative measure of space and time.
OEMB for reference ... https://www.fourmilab.ch/etexts/einstein/specrel/www/
Best Regards,
GrayGhost
  • #48
Thanks for the insight. But there would by necessity be a distance separating them, would there not? If you are timing when a train arrives, your clock is close to the train, but not on the train. That is, your measurement is comparing two events: the event of the second hand hitting a number, and the event of a train pulling into a certain location. Is that right?
  • #49
Yes. But there are two caveats.
First, the Lorentz transforms only do "funny" things in the direction that the other frame is moving. We usually pick that to be the x direction. Two events with equal x coordinates will be simultaneous (or not) for all frames moving in the ±x direction, regardless of their y and z coordinates.
Secondly, if the two clocks are a lot closer together than the length of the train then any error introduced by a failure to consider clock synchronisation between those two clocks becomes small compared to the relativistic effects you're measuring along the train. That idea of things being close enough together that you can neglect some effects is important throughout relativity.
Likes FactChecker
  • #50
There will be agreement on the simultaneity of two events that are not separated in the direction of relative motion. They may be separated in other directions with no problem.
