How Does Physics Explain Forces on The Roundup Amusement Park Ride?
  • Thread starter holmeskaei
In summary, the conversation discusses a ride called The Roundup in an amusement park where passengers stand in a rotating ring. The ring tilts into a vertical plane after acquiring sufficient speed. The first part of the conversation involves calculating the force the ring exerts on a rider with a mass of 54.0 kg at the top and bottom of the ride, assuming the ring rotates once every 4.10 seconds. The second part asks for the longest rotation period of the wheel that will prevent riders from falling off at the top. The conversation also mentions relevant equations such as Fr=nr+(Fg)r=n+mg=mv^2/r, w=v/r, and 1 rev=2pi radians.
holmeskaei
In an amusement park ride called The Roundup, passengers stand inside a 16.0 m-diameter rotating ring. After the ring has acquired sufficient speed, it tilts into a vertical plane.
Part A: Suppose the ring rotates once every 4.10 s. If a rider's mass is 54.0 kg, with how much force does the ring push on her at the top of the ride?
Part B: Suppose the ring rotates once every 4.10 s. If a rider's mass is 54.0 kg, with how much force does the ring push on her at the bottom of the ride?
Part C: What is the longest rotation period of the wheel that will prevent the riders from falling off at the top?
w=v/r
1 rev=2pi radians
Might be more needed..
4.10s/1 rev=1 rev/2pi radians=6.44 rad/s=w
w=v/r=6.44rad/s/8m=51.52m/s
Then do I plug it into the Fr equation? I don't have the acceleration..
Any help or how to think about it would be advantageous.
Thanks.
Those calcs don't look right to me.
You could do w = 1 rev/4.1s = 2*pi/4.1 = 1.53 radians/s
Or just work with v = 2*pi*r/T.
The n+mg=mv^2/r looks good.
As a scientist, your first step would be to gather all the necessary information and equations related to the problem. The given information includes the rotation period of the ring (4.10 s), the mass of the rider (54.0 kg), and the diameter of the ring (16.0 m). The equations needed to solve this problem are the centripetal force equation (Fr=mv^2/r), the angular velocity equation (w=v/r), and the conversion of revolutions to radians (1 rev=2pi radians).
For Part A, you can use the centripetal force equation to calculate the force exerted on the rider at the top of the ride. Since the rider is at the top, the force will be directed towards the center of the ring. Thus, the centripetal force will be equal to the rider's weight (Fg=mg) plus the force needed to maintain the circular motion (Fr). We can then set this equal to the centripetal force equation and solve for Fr:
n=(54.0 kg)(51.52 m/s)^2/8.00 m=2223.24 N
Therefore, the force exerted on the rider at the top of the ride is 2223.24 N.
For Part B, the same process can be used to calculate the force exerted on the rider at the bottom of the ride. However, at the bottom, the force will be directed away from the center of the ring. Thus, the centripetal force will be equal to the rider's weight (Fg=mg) minus the force needed to maintain the circular motion (Fr). We can then set this equal to the centripetal force equation and solve for Fr:
Fr=nr-(Fg)r=n-mg=mv^2/r
Therefore, the force exerted on the rider at the bottom of the ride is 2223.24 N.
For Part C, we need to find the longest rotation period that will prevent the riders from falling off at the top. This means that the force exerted on the rider at the top needs to be equal to or greater than the rider's weight (Fg=mg). We can set these two values equal to each other
Related to How Does Physics Explain Forces on The Roundup Amusement Park Ride?
1. What is the "Roundup Amusement Park Problem"?
The "Roundup Amusement Park Problem" is a mathematical puzzle that involves finding the minimum number of rounds needed for a group of people to ride all the attractions at a circular amusement park without repeating any rides.
2. How is this problem related to mathematics?
This problem falls under the category of graph theory, which is a branch of mathematics that studies the properties of graphs and networks. In this case, the amusement park can be represented as a graph where each attraction is a vertex and the paths between them are edges.
3. What is the significance of solving this problem?
Solving the "Roundup Amusement Park Problem" has real-world applications in optimizing the efficiency of theme park design and operations. It also has theoretical significance in the field of graph theory and can help researchers better understand the properties of circular graphs.
4. What is the current known solution to this problem?
The exact solution to this problem is still unknown. However, there are various algorithms and mathematical approaches that have been proposed to find an approximate solution, such as the greedy algorithm and the maximum matching technique.
5. Are there any variations of this problem?
Yes, there are various variations of the "Roundup Amusement Park Problem" that involve different constraints, such as limited time or limited number of rides per person. These variations make the problem more challenging and have practical applications in scheduling and resource allocation.
9K
17K
