What Is the Correct Calculation for the Running Dog Vector Problem?
In summary: The book's answer is consistent with the dog finishing 12 m south of starting position, rather than 10 m.
andylatham82
New user has been reminded to post schoolwork in the Homework Help forums and fill out the HH Templatge showing their work
I've been racking my brain for a while now over what I feel should be a simple problem to solve, but my answer is wrong. I'm not wildly wrong, but wrong enough to think I've made a proper error and it's not just a rounding error or something. The question goes like this:
A dog in an open field runs 10.0m east and then 30.0m in a direction 55.0° west of north. In what direction and how far must the dog run to end up 10.0m south of her original position?
I decided to work this out by making the starting position of the dog coincide with the position the dog is aiming for. She'll follow vector A up to the original staring position, then travel east on vector B, followed by the north-westerly direction along vector C. Then I'm looking for the resultant vector D. I worked out the vector components as follows:
Ax = 0m
Ay = 10.0m
Bx = 10.0m
By = 0m
Cx = -30 sin 55.0° = -24.57m
Cy = -30 cos 55.0° = 17.21m​
I then calculated the resultant components of vector D:
Dx = Ax + Bx + Cx = 14.57m
Dy = Ay + By + Cy = -27.21m​
Then the magnitude of vector D is:
D = √(Dx2 + Dy2) = 30.9m​
And the direction is:
θ = tan-1(Dx / Dy) = 28.2° east of south.​
However the answers given to the problem are 32.6 m, 26.5° east of south. So you can see I'm not a million miles out, but I can't for the life of me spot my error! If anyone could put me out of my misery I'd be very grateful!
Thanks!
Andy
Likes Aufbauwerk 2045
[edit] matter of reading more carefully what you did. o:)
I don't understand how your Bx and By come about. You should use the same coordinate system as you used for A.
Goes to show making a drawing of the situation is a life saver. Even when you intend to do things in a different way, a check is always nice ! :smile: [edit] still good advice
[edit]me and my arrogant posts! The book answer is off and -- at least as stated -- you're not.
Likes andylatham82
Ah! I'm correct? Thank heavens for that! I thought my brain had stopped working! Thanks for putting my mind at ease!
As for a diagram, I always draw them, I just didn't include my diagram here. I'd be lost without a diagram haha.
Likes BvU
I did it a slightly different way, but I get the same answer you do.
I assume the dog starts at (0,0). She goes to P1 = (10,0). (Units of course in meters.)
Then she goes to P2 by walking a distance of 30 m at an angle of 55 degrees west of North. So P2x = 10 - 30 (sin 55 deg) = -14.575 and P2y = 30(cos 55 deg) = 17.207.
So now the dog is at P2 = (-14.575, 17.207). The problem is how far does she walk and at what angle to get to P3 = (0, -10). Think of a right triangle formed by drawing a vertical line down from P2 to y = -10, and from there draw a horizontal line to P3. The vertical side has length 27.207 and the horizontal side has length 14.575. The hypotenuse is the final leg of the journey, from P2 to P3.
The distance traveled on the last leg is the hypotenuse = sqrt (27.207^2 + 14.575^2) = 30.865 m.
The angle between the vertical side and the hypotenuse = sin^-1(14.575/30.865) = 28.177 degrees.
Rounding gives your answer.
Does the book give a worked out solution, or just the answer?
Can you check the goal description again?
Likes BvU
Is the book old. At one time, books assumed the student did the calculation with slide rules. I taught physics in the old days and I often saw different answers depending on the tools that did the calculation.
What is a running dog vector problem?
A running dog vector problem is a mathematical model used to describe the motion of a dog running in a straight line. It takes into account factors such as the dog's speed, direction, and acceleration.
Why is the running dog vector problem important?
The running dog vector problem is important because it allows scientists to accurately predict the movement of a running dog, which can be useful in various fields such as animal behavior research, sports science, and robotics.
What are the key components of the running dog vector problem?
The key components of the running dog vector problem are the dog's position, velocity, and acceleration. These factors determine the dog's movement and can be represented by vectors in a coordinate system.
How is the running dog vector problem solved?
The running dog vector problem is solved using mathematical equations and principles of vector algebra. The initial conditions, such as the dog's starting position and velocity, are used to calculate its position at any given time.
What are some real-world applications of the running dog vector problem?
The running dog vector problem has various real-world applications, such as predicting the trajectory of a running dog in a race, analyzing the movement patterns of hunting dogs, and designing robots to mimic the movement of dogs.
