Simple connectivity and finite coverings
  • Thread starter Thread starter cduston
    Finite
cduston
Hey everyone,
First of all this is my first post and it's in regards to something I am (supposed to be) learning for my research. The topic is Algebraic Topology, so this was the closest general topic I could find.
The question is in regards to the connection between covering spaces and the fundamental group. I had a conversation with my advisor about CP_2 (complex projective plane in 2 D), and she said "Since CP_2 is simply connected, there cannot be any actual finite covering because these would correspond to normal subgroups of the fundamental group". Then she goes on to talk about branched coverings. Now, I understand that simple connectivity implies the fundamental group is trivial, and that a covering space p:X'->X means p(pi(X'))->pi(X) must be injective, but I don't really understand her "finiteness" remark. Does anyone have any thoughts on this?
cduston said:
Hey everyone,
This is something I don't quite understand how to prove, but apparently, there is a one to one correspondence between the MINIMUM number of "copies" of your space X in your covering space with the number of elements in pi(X). For example, RP_1 can be thought of by identifying antipodal points on the circle S^2. If we let U and V be open semi-circles on S^2 such that U and V cover S^2. Then the disjoint union of U and V will form a covering space of RP_1. Thus, pi(RP_1) has two elements. There is only one such group: a cyclic group of order 2.
So, in your case, if you did have a finite and nontrivial open covering of CP_2, then you should be able to form a covering space of CP_2. These would tell you that pi(CP_2) has more than one element which as you already know it cannot. So, CP_2 can't have a finite covering.
Actually, no simply-connected, Hausdorff, arc-connected, and locally arc-wise connected space has a nontrivial covering. For a proof, see Section 3 (Covering Spaces) of Chapter III (Fundamental Group) of Bredon's "Topology and Geometry." Actually, any standard algebraic topology text should prove this result.
Also, you can look up at Prop 1.32 on page p. 61 of this: http://www.math.cornell.edu/~hatcher/AT/ATch1.pdf
Here's what she shaid: finite covers correspond to normal subgroups, so if there are no normal subgroups, then there are no finite covers. This doesn't tell you anything about covers where the fibres (a fibre is a pre-image of a point under the covering map) are not sets of finite points.
For example take the sphere S^2, this is simply connected, so has no non-trivial finite-to-one covers. But there is the Hopf fibration which is a covering map
S^3 --> S^2
and the fibre above each point is S^1. This is non-trivial in the sense that S^3 is not S^2 x S^1.
Great work everyone, I think I'm beginning to get this. I found the chapter in Hatcher on the issue but I'm glad you (Doodle Bob) confirmed what I thought was the relevant result. But I think I understand what's going on, thanks very much everyone!
(and for the record, you guys were more helpful then http://www.mathhelpforum.com/math-help/" :wink:)
Hello! There is a simple line in the textbook. If ##S## is a manifold, an injectively immersed submanifold ##M## of ##S## is embedded if and only if ##M## is locally closed in ##S##. Recall the definition. M is locally closed if for each point ##x\in M## there open ##U\subset S## such that ##M\cap U## is closed in ##U##. Embedding to injective immesion is simple. The opposite direction is hard. Suppose I have ##N## as source manifold and ##f:N\rightarrow S## is the injective...
