B Sine/Cosine behaving like a linear function
The discussion focuses on the relationship between sine and cosine functions in the context of simple harmonic motion, highlighting that their equations are similar but differ by a phase shift. It emphasizes that while sine and cosine are not linear functions, they can be approximated by linear functions over small intervals. The conversation also touches on Euler's formula, which connects these functions through complex variables, illustrating their trade-off behavior. Additionally, the importance of the conservation of energy in harmonic motion is discussed, with potential and kinetic energy being represented by sine and cosine functions, respectively. Overall, the thread explores the mathematical properties and relationships of sine and cosine in physics.
Neck
Hello all. After completing a problem in which we derived the formulas for potential and spring force energy as functions of time, with simple harmonic motion I noticed the equations are EXACTLY the same, but with sine and cosine switched. The equations were:
A sin^2(pi * t)
A cos^2(pi * t)
I apologize for this awful format, I want to learn the math script used on this website, but I forgot the name (would be appreciated also).
Anyways here is a graph of the aforementioned functions.
My question: Is there a way to represent this back and forth behavior with a linear function or any other way?
Mathematics news on Phys.org
Both functions are not linear.
If two functions f,g are shifted by a fixed amount with respect to each other, then f(x)=g(x+c) for some constant c. Here ##\cos(x)=\sin(x+\frac \pi 2)##, for example. Sine and cosine are also periodic, so you have additional relations like ##\sin(x)=\sin(x+2n \pi) = \cos(x+2n \pi - \frac \pi 2)## for every integer n.
Likes Neck and QuantumQuest
LaTeX.
Likes Neck
https://www.physicsforums.com/help/latexhelp/
This link will help you learn LaTeX for PF
Likes Neck
jedishrfu said:
If you use the series representation of a sin or cos function then you can see that it can never be represented by a linear function.
But you can approximate either of these functions in small intervals by straight lines.
Near x = 0, ##\sin(x) \approx x## and ##\cos(x) \approx 1##. Notice that these are the first terms of the Maclaurin series for each of these functions.
Likes Neck, QuantumQuest and lekh2003
The "back and forth" behavior is a trade-off between the two things. Combining those two into one equation is motivation for Euler's formula involving complex variables: e = cos(θ) + i ⋅ sin(θ). (There is a reason for using θ as though these are functions of angle rather than functions of t=time.) That one equation can be used to represent how the two things trade-off.
(see https://en.wikipedia.org/wiki/Euler's_formula )
PS. I see that the wikipedia article goes into a lot of advanced subjects that are not appropriate for this thread. The first paragraph is appropriate. This may be better: https://betterexplained.com/articles/intuitive-understanding-of-eulers-formula/
The reason for your graph being what it is in the OP is that ## v=v_o \sin(\omega t) ##, so that the kinetic energy ## K.E.=(\frac{1}{2})mv^2=(\frac{1}{2})mv_o^2 \sin^2(\omega t) ##. In order for the total energy ## E ## to be constant, we must have the potential energy ## U=(\frac{1}{2})m v_o^2 \cos^2(\omega t) ##, because ## \cos^2 (\theta)+\sin^2(\theta)=1 ##. ## \\ ## It may also interest you that ## \cos^2(\omega t)=(\frac{1}{2})(\cos(2 \omega t)+1) ## , and ## \sin^2(\omega t)=(\frac{1}{2})(1-\cos(2 \omega t)) ##. This is why the two curves in the graph of the OP are essentially sinusoidal.
Likes Neck
gmax137 said:
LaTeX.
thank you! will learn that asap
