Soft X-Rays: Causes & Energy Rates
  • Thread starter Thread starter Entanglement
    Energy X-rays
Soft x-rays are produced when accelerated electrons interact with atoms, causing deceleration and scattering, which leads to photon emission. The energy of emitted photons is related to the deceleration rate of the electrons, with maximum photon energy limited by the initial electron energy, determined by the voltage of the x-ray tube. Traditional x-ray generation involves colliding electrons with a metal film to produce characteristic x-rays, while soft x-rays typically arise from synchrotron sources using undulators. The process of bremsstrahlung, or braking radiation, describes how x-rays interact with matter, leading to a cascade of lower-energy photons. Understanding these mechanisms is crucial for calculating the number and energy of emitted photons.
Entanglement
what is the reason of soft x-rays, Is it because when a accelerated electron approaches an atom the electrons' electric field repel the incoming electron causing deceleration and also i scattering could be a reason when the electron approaches the nucleus, is that correct?
what is the relation of the number and energy of photons emitted to the rate of its deceleration, how can it be calculated? Big :smile: to PF, and thanks in advance!
Science news on Phys.org
"Soft x-rays" have less energy than "hard x-rays". The traditional method for making x-rays was to accelerate electrons through a fixed potential - call it V - so that every electron has the same energy; about eV in this case.
Then collide the electrons with a thin metal film. If the electron energy is sufficient, then the "characteristic x-rays" for that metal will be emitted.
"Hard" x-rays are more penetrating.
See https://en.wikipedia.org/wiki/X-ray_generator
See [PLAIN]https://en.wikipedia.org/wiki/X-ray_generatorsf[/PLAIN]
Thanks a lot for your answer, but I don't think you understood my question correctly :smile:
Maybe can work you some question so it clearer be.
Yeah, clearer question would help.
Soft x-rays are typically generated at synchrotrons and wiggling the electron beam using an undulator.
I mean I know that when an electron falls from a higher level it emits a photon of energy hv,
What is the equivalence of that for decelerating electrons, what governs the number of photons and the energy of each photon??
The undulator produces a magnetic field that acts on the electron beam (http://en.wikipedia.org/wiki/Undulator).
A magnetic field has a potential energy similar to a (quantum) harmonic oscillator along one axis (Introductory Quantum Mechanics, Liboff 4th editon).
I'm guessing the transitions are harmonic oscillator type transitions, with higher energy and lower energy states available.
ElmorshedyDr said:
..... what governs the number of photons and the energy of each photon??
The maximum energy of the produced X-ray photon is limited by the energy of the incident electron, which is equal to the voltage on the tube times the electron charge, so an 80 kV tube cannot create X-rays with an energy greater than 80 keV
Dave
For braking radiation, conservation of energy tells us that the total energy released as photons cannot exceed the total energy of the initial source.
An x-ray passing through matter will have multiple interactions, all electromagnetic, knocking off electrons as it goes. These electrons will in turn generate additional photons - a chain reaction - but with ever lower energies in the photons, and in the electrons.
This cascade is called bremsstrahlung or braking radiation.
For some calculations see http://www.astro.utu.fi/~cflynn/astroII/l3.html
and http://whs.wsd.wednet.edu/faculty/b...onphysics/lecturenotes/chapter7/chapter7.html
its so much fun being ignored :frown:
Likes 1 person
It's my favorite activity! :-p
Likes 1 person
Thanks guys I got it. :smile:
What do you mean?
ElmorshedyDr said:
What do you mean?
That was for me, so you can just ignore it. :smile:
10K
18K
