Is Microwave-Based Jet Propulsion Viable for Marine Vehicles?
In summary, a new member of the forum has proposed an idea for a microwave-based jet propulsion system for marine vehicles. They believe it would be more efficient and easier to maintain than existing technologies. However, other members have pointed out that water does not expand like air when heated, making this idea impractical. They also discuss the efficiency of steam and diesel engines. Finally, there is a brief conversation about the efficiency of RF antennas and power conversions.
No Otters
Hi,
I'm new to the forums and I'd like to bounce an idea off of someone :biggrin:
Although I've got a physics degree, I have successfully managed to forget a lot of it as people tend to do when not practicing, and I was wondering if someone would kindly pick some holes in an idea I've had.
Firstly, I should imagine at least someone has heard of pumpjet propulsion for marine vehicles, as well as its nerdier cousin the magnetohydrodynamic drive. What I can't understand is why no one has mentioned a simple jet based on heating water using microwaves. It would not be necessary to boil the water, and in fact this would be unwise as it would cause cavitation, and the direction of flow could be controlled by simply shaping the tube so that it expands in the desirable direction.
I think I'm right saying that microwave absorption would be very efficient if done correctly, and although it would not make for particularly responsive propulsion, it would be quiet and easy to maintain. The technology required is much more readily available than for MHD, and it would have the capacity for greater velocity.
Can anyone see something I'm missing? I've got my suspicions you see :tongue2:
Thanks!
Welcome to PF, No Otters.
I have no education, so I can't really address your issue other than to say that it sounds very reasonable to me on the face of it, but I can't see how you would get propulsion without actually boiling the water. It won't expand like air does just from being heated. The only way that I can think of this operating would be like a pulse-jet, where you flash-boil a small amount of water to force out a liquid slug, then intake new water and repeat. I'm not the proper one to answer this, though. Hang tight, and some experts will be along.
Yes, air expands a lot when heated, water does not. That's why it works with air, but wouldn't work with water.
I have one of those pulse-jet boats, Danger. Circa 1960, or so. It was made of 'tin', powered by a candle and cost a whole 10 cents at the time.
Ah yes... Just found a nice graph showing thermal expansion. Water is at its greatest volume at 4ºC, and is officially useless as a medium for propulsion!
Thanks anyway guys
You may recall in the past steam engines were used...Didn't CARNOT figure out the maximum efficiency of such an engine...around 15% or 20% or something at that level...and that was using steam expansion...diesel is MUCH more efficient...
You have that backwrds, but still...
Steam engines are roughly the same efficiency as diesel engines (30-40%) and partly for that reason, most of our electricity comes via steam.
Thanks anyway guys
At its greatest density at 4º C so a given mass is at its least volume.
Where does the electricity come from.. A Diesel generator? Losses all they way.
Makes more sense to use the mechanical power from the Diesel directly.
Neat. I hadn't heard of one of those. There was something that I used to read when I was a kid (can't remember what) that had all sorts of plans to make stuff like that. The only one that I can sort of remember was a toy boat that had 3 (or 4 or 5) sewing thread spools wound up with rubber bands.
There are some exceptions to that, though, particularly in submarines.
Also if I remember correctly RF antenna's are very inefficient and transform about 5% of the energy into RF wave.
Antennas are virtually 100% efficient as long as they are well (impedance matched) to the source of RF. Whether the RF is going in a direction you want to to is another matter.
Power conversions can be inefficient.. AC to DC to supply a magnetron and DC to RF output...overall is typically 60% efficient. Our 850 Watt microwave oven takes 1400 Watts from the mains.
1. What is solid state marine propulsion?
Solid state marine propulsion is a type of propulsion system used on ships and boats that utilizes an electric motor and a solid-state power converter instead of traditional mechanical systems, such as propellers and shafts.
2. How does solid state marine propulsion work?
Solid state marine propulsion works by converting electrical energy from a power source, such as a battery or generator, into mechanical energy to drive the propeller. The power converter controls the speed and direction of the electric motor, allowing for precise control of the vessel.
3. What are the advantages of solid state marine propulsion?
There are several advantages to using solid state marine propulsion. It is more efficient, reliable, and environmentally friendly than traditional propulsion systems. It also allows for greater control and maneuverability of the vessel.
4. Are there any disadvantages to solid state marine propulsion?
One potential disadvantage of solid state marine propulsion is the initial cost of installation, as it can be more expensive than traditional propulsion systems. It also requires a power source, such as a battery or generator, which may add weight and take up space on the vessel.
5. Is solid state marine propulsion currently being used on commercial ships?
Yes, solid state marine propulsion is already being used on some commercial ships, particularly in the ferry industry. It is also being tested and developed for use on larger vessels, such as cargo ships and cruise ships. It is expected to become more widely adopted in the future as technology advances and the demand for more efficient and sustainable propulsion systems increases.
  • STEM Academic Advising
12K
  • Aerospace Engineering
