Can You Find a Unique N for This Cubic and Quadratic Diophantine Equation?
  • MHB
  • Thread starter lfdahl
In summary, to solve the given equation, one must first expand the expression on the left side using the distributive property. Then, combine like terms and move all the terms to one side of the equation. Next, factor out the greatest common factor and use the zero product property to find the possible values of x and y. It is possible to have multiple solutions to this equation depending on the values of x and y that satisfy the original equation. These solutions can be found by using the zero product property. However, not all values of x and y will satisfy the equation, so it is important to check the solutions obtained. This equation can be solved algebraically, but it may be more efficient to use a graphing calculator or computer program
lfdahl
MHB
749
Consider the equations:
$$N = x^3(3x+1) = y^2(y+1)^3$$
- where $x$ and $y$ are coprime positive integers.
Show, that there is only one possible value for $N$ and find it.
Mathematics news on Phys.org
my solution:
$x^3=(y+1)^3---(1)$
$3x+1=y^2---(2)$
solution of $(1)(2),x=5,y=4,N=2000$
Albert said:
my solution:
$x^3=(y+1)^3---(1)$
$3x+1=y^2---(2)$
x and y are co-primes that does not mean that 3x+1 and y+1 are co-primes. If they are then we need to prove it
It is clear
for $1=\dfrac {(x^3)(3x+1)}{(y^2)(y+1)^3}$
if $\dfrac {x^3}{y^2}=\dfrac {b}{a}$
then $\dfrac {3x+1}{(y+1)^3}=\dfrac {a}{b}$
$a,b$ are co-primes
Albert said:
It is clear
$a,b$ are co-primes
Not quite correct as we can have 3x+1 = na and $(y+1)^3=nb$.
Albert said:
my solution:
$x^3=(y+1)^3---(1)$
$3x+1=y^2---(2)$
Hi, Albert!
You´re almost right. Since $gcd(x,y) = 1$, $x^3$ must divide $(y+1)^3$, i.e. $x|(y+1)$, and we conclude that: $x \le y+1$. By the same argument, we have: $y^2 \le 3x+1.$
lfdahl said:
Hi, Albert!
ex:$x=5,y=3, gcd(5,3)=1$ but $x^3$ not divide $(y+1)^3$
in this case if $3x+1=na,(y+1)^3=nb$
then $x^3=nb ,y^2=na$
$x\,\,and\,\,y$ are not coprime (if $n\neq 1$)
and $x^3=b ,y^2=a$
satisfy the given condition
Thankyou kaliprasad and Albert for an interesting discussion and for Albert´s correct solution. I do hope we can agree on the suggested solution :)
Suggested solution:
Since $gcd(x,y) = 1$ it follows that $x^3|(y+1)^3$, hence $x|(y+1) \Rightarrow x \le y + 1$.
Similarly $y^2|(3x+1)$, so $y^2 \le 3x+1$. Combining the inequalities gives: $(x-1)^2 \le y^2 \le 3x+1$.
As $x$ is positive, only $x = 1,2,3,4,5$ are possible. Trying these values in $x^3(3x+1) = y^2(y+1)^3$,
we find that only $x=5, y = 4$ work, so $N = 4^2\cdot 5^3 = 2000$ is the only solution.
This is also Albert´s conclusion and final result. The solution $(5,4)$ underlines the fact, that
the factors $(3x+1) = 2^4$ and $(1+y)^3 = 5^3$ are indeed coprimes.
Related to Can You Find a Unique N for This Cubic and Quadratic Diophantine Equation?
1. How do you solve this equation?
The equation can be solved by first expanding the expression on the left side using the distributive property. Then, combine like terms and move all the terms to one side of the equation. Next, factor out the greatest common factor and use the zero product property to find the possible values of x and y. Finally, plug in these values to check which ones satisfy the original equation.
2. Is there more than one solution to this equation?
Yes, there can be multiple solutions to this equation depending on the values of x and y that satisfy the original equation. This can be determined by using the zero product property to find the possible values of x and y.
3. Can this equation be solved algebraically?
Yes, this equation can be solved algebraically by using the steps mentioned in the first question. However, the process can be quite lengthy and it may be more efficient to use a graphing calculator or computer program to find the solutions.
4. What are the possible values of x and y that satisfy this equation?
The possible values of x and y that satisfy this equation can be found by using the zero product property. This means that either x^3 = 0 or 3x+1 = 0, and either y^2 = 0 or y+1 = 0. Solving these equations will give the possible values of x and y.
5. Can this equation be solved for any values of x and y?
No, not all values of x and y will satisfy this equation. The values of x and y must make the equation true in order for them to be solutions. Some values may make the equation undefined, while others may not satisfy the equation when plugged in. It is important to check the solutions obtained to make sure they work in the original equation.
  • General Math
  • General Math
  • General Math
