Solved thermodynamics problem - Can you interpret the solution, please?
C) + (0.1m)qSolving for C_v, we get:C_v = (C_wΔT_w - q)/10°CSubstituting the given values of C_w = 4.2 J/g.K and q = 2.26 J/g, we get:C_v = (4.2 J/g.K * 100°C - 2.26 J/g)/10°CC_v = 419.74 J/g.KThis is the specific heat capacity of the system, which includes both water and vapor. However, we are also asked to find the specific heat capacity of fog, which is a mixture of vapor and water droplets. We can
playmannn
"In a closed container there is water in equilibrium with saturated vapor at temperature 100°C (212°F). The ratio of the masses vapor/water is β=0.1. The heat capacity of water is C(o) = 4.2 J/g.K. Find the specific heat capacity of the system, considering that the specific heat of transition is q=2.26 J/g. Identify the specific heat capacity Cv of a thin fog (saturated vapor with water drops, the full mass of which is much lower of the mass of the vapor)."
The solution with the key steps is provided in the attachment!
Can you, please, tell me how are the stated equations derived, starting with why is the one for mc like so, as well as the following ones. I'll be so thankful if you do!
Thank you for your question. I am happy to explain the steps and equations used in the solution provided. First, let's define some variables:
- m: mass of water
- m_v: mass of saturated vapor
- m_f: mass of fog (saturated vapor with water droplets)
- C: specific heat capacity of the system (water and vapor)
- C_v: specific heat capacity of fog
- T: temperature of the system
- q: specific heat of transition (latent heat)
The key equation used in the solution is the heat capacity formula:
Q = mCΔT
Where Q is the heat absorbed or released, m is the mass of the substance, C is the specific heat capacity, and ΔT is the change in temperature.
In this problem, we are given the temperature of the system as 100°C, which is also the boiling point of water at standard atmospheric pressure. This means that the water and vapor are in equilibrium, and the heat absorbed by the system is used to convert water into vapor. This is known as the latent heat of vaporization, and it is represented by the variable q.
Now, we can write the heat capacity equations for the water and vapor separately:
Q_w = mC_wΔT_w
Q_v = m_vC_vΔT_v + m_vq
Where ΔT_w and ΔT_v are the change in temperature for water and vapor respectively. Since the system is in equilibrium, we can assume that the temperature of both water and vapor are equal to the boiling point of water, 100°C. Therefore, ΔT_w = ΔT_v = 100°C.
We are also given the ratio of masses of vapor to water, β=0.1. This means that for every 1 gram of water, there is 0.1 grams of vapor. We can use this ratio to find the mass of vapor, m_v:
m_v = βm = 0.1m
Substituting this into the heat capacity equation for vapor, we get:
Q_v = (0.1m)C_v(100°C) + (0.1m)q
Now, we can equate the heat absorbed by the water to the heat released by the vapor, since the system is in equilibrium:
Q_w = Q_v
mC_wΔT_w = (0.1m)C
1. What is thermodynamics?
Thermodynamics is a branch of science that deals with the relationships between heat, energy, and work. It studies how energy is transferred and transformed between different forms, such as heat, mechanical work, and electrical energy.
2. What is a solved thermodynamics problem?
A solved thermodynamics problem is a problem that has been analyzed and solved using the principles and equations of thermodynamics. This involves understanding the initial and final states of a system, the energy transfers and transformations that occur, and applying the laws of thermodynamics to find a solution.
3. What does it mean to interpret the solution of a thermodynamics problem?
Interpreting the solution of a thermodynamics problem means understanding the meaning and implications of the calculated values and equations. This may involve explaining the physical processes that are occurring, identifying the key variables and their relationships, and determining the significance of the results in the context of the problem.
4. How do scientists interpret solutions to thermodynamics problems?
Scientists interpret solutions to thermodynamics problems by carefully analyzing the equations and values obtained, applying their knowledge of thermodynamics principles and concepts, and considering the physical and practical implications of the results. They may also use graphs and diagrams to help visualize and explain the solution.
5. Why is it important to interpret solutions to thermodynamics problems?
Interpreting solutions to thermodynamics problems is important because it helps to understand the underlying physical processes and principles involved, and to determine the accuracy and reliability of the results. By interpreting the solution, scientists can also identify any potential errors or limitations in the calculation and improve their understanding of thermodynamics concepts.
