Solving for \Pi: Unraveling the Logarithmic Equation
  • Thread starter Thread starter roadworx
    Logarithmic Pi
The discussion focuses on rearranging the logarithmic equation Θ = log(Π/(1-Π)) to solve for Π. The initial attempt incorrectly equated exp(Θ) to Π - (1-Π), leading to a miscalculation. Participants suggest using the basic definition of logarithms to correct the approach. The correct rearrangement results in Π = exp(Θ)/(1 + exp(Θ)). The conversation emphasizes the importance of accurately applying logarithmic properties in mathematical transformations.
roadworx
Hi,
I have the following equation:
\Theta = log \left(\frac{\Pi}{1-\Pi}\right)
I want to re-arrange it for \Pi
Here's my attempt:
\Theta = log \left( \frac{\Pi}{1-\Pi}\right)
\Theta = log \left( \Pi \right) - log \left(1-\Pi \right)
exp^{\Theta} = \Pi - (1-\Pi)
exp^{\Theta} = 2\Pi - 1
1 + exp^{\Theta} = 2\Pi
\Pi = \frac{1 + exp^{\Theta}}{2}
The answer should be
\Pi = \frac{exp^{\Theta}}{1+exp^{\Theta}}
Any idea where I'm going wrong?
Mathematics news on Phys.org
Your mistake was on the 2nd step you made: exp^{\Theta} = \Pi - (1-\Pi)
Try using the basic definition of logs: log_ab=c hence a^c=b
\theta =\log \left(\frac{\Pi }{1+\Pi }\right)
\frac{\Pi }{1+\Pi }=\exp (\theta )
\Pi =\exp (\theta )+\exp (\theta ) \Pi
[1+\exp (\theta )]\Pi =\exp (\theta )
\Pi =\frac{\exp (\theta )}{1+\exp (\theta )}
This should be
1- \exp(\theta)]\Pi= \exp(\theta)
\Pi =\frac{\exp (\theta )}{1-\exp (\theta )}
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
