Spherical Cavity in Dielectric Subject to Uniform Field
CaptainMarvel
The polarization charge on the surface of a spherical cavity is - \sigma_e cos(\theta) at a point whose radius vector from the centre makes an angle \thetawith a given axis Oz. Prove that the field strength at the centre is \frac {\sigma_e}{3 \epsilon_o} parallel to Oz.
If the cavity is in a uniform dielectric subject to a field of strength E_o parallel to the direction \theta = 0, show that \sigma_e = \frac {3 E_o \epsilon_o ( \epsilon_r -1)} {1 + 2 \epsilon_r} where \epsilon_r is the relative permittivity of the dielectic. Verify that that this gives the correct value for the field strength at the centre of the cavity E = \frac {3 \epsilon_r E_o} {1 + 2 \epsilon_r} and note that \sigma_e is not simply ( \epsilon_r - 1 ) \epsilon_o E_o because of the distortion of the field in the dielectric caused by the presence of the cavity.
The first part of the question is no problem and deriving the field strength in the center which it asks you to verify using boundary conditions etc. etc. is no problem.
However polarization charge density = P . \hat{n} = - P cos( \theta ) which is the form of what's given at the beginning of the question leading to \sigma_e = P
Therefore:
P = ( \epsilon_r - 1 ) \epsilon_o E
Subbing in my equation for field inside:
P = ( \epsilon_r - 1 ) \epsilon_o \frac {3 \epsilon_r E_o} {1 + 2 \epsilon_r}
Which is the answer they want, apart from I have an extra \epsilon_r term in the numerator.
Any ideas?
Many thanks in advance.
When I say 'my equation for field inside' I mean:
as verified in the question.
Thanks everyone.
Please can somebody give me some idea as to where I'm going wrong?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
