Which Exercise Requires More Abdominal Effort: Pilates or Sit-Ups?
In summary: Pilates Position:Since the abdominal muscles are the only external forces acting on the body, the moment provided by them can be calculated as the difference between the known moment (W*sin(60o)/cos(60o)) and the unknown moment (W*sin(30o)/cos(30o)). M = (W*sin(60o)/cos(60o)) – (W*sin(30o)/cos(30o)) M = W*(sin(60o)/cos(60o) – sin(30o)/cos(30o)) M = W*(1/2 – sqrt(3)/2) M = W*(1/2 – 0.866) M
mahkum
This question requires you to model the human body so that you can analyse the static loads, (comparing the pilates position and the abdominal sit-up position, figure above)
Using the body mass ‘M’ of 94 kg and a body height ‘h’ of 1.73 metres, establish which exercise requires the most effort from the abdominal muscles to hold the position shown and by what factor.
The table shows the details of body parts so that comparison between the two positions can be performed.
Table:
Body Parts Mass in terms of M,
the person’s mass Length, I, in terms of h, the person’s height Position of cetnre of mass along from upper end of the body part
Thighs 0.2M 0.24h 0.43/
Shanks + feet 0.13M 0.29h 0.47/
Head + neck 0.08M 0.182h 0.36/
Trunk + arms 0.59M 0.332h 0.50/
For the purpose of this question, the mass and position of the hands and arms can be considered to be part of the trunk. Place your origin at the join between the bottom of the trunk and the top of the thighs, i.e. where the abdominal muscles act. Assume that the angle the legs in the pilates position makes with the floor is 60o , whereas the angle the head and neck make with the floor is 45o.
For the sit-up exercise, the trunk is at 30o to the floor and the legs are bent so that the knee joint makes a 90o bend.
To gain full marks:
a) Give valid assumptions on how you model the body components
b) Sketch clear, fully labelled free-body diagrams of the two positions, showing the known and unknown external acting forces and moments
c) Provide accurate equilibrium equations by resolving the loads and moments
d) Calculate the unknown external loads and moments
e) Calculate the moment provided by the abdominal muscles to achieve the position
a) Assumptions:• The human body is modelled as a collection of rigid body parts. • The centres of mass for each body part are assumed to be at the midpoint of their length. • The position of the centre of mass is taken to be along the longitudinal axis of the body part. • The external forces and moments acting on the body are assumed to be constant. • The moment is calculated as the sum of the moments around the origin. b) Free-body diagrams:Pilates Position:Abdominal Sit-up Position:c) Equilibrium equations:Pilates Position:Sum of Forces in x-direction = 0Fx = 0Sum of Forces in y-direction = 0Fy = 0Sum of Moments around origin = 0M = 0Abdominal Sit-up Position:Sum of Forces in x-direction = 0Fx = 0Sum of Forces in y-direction = 0Fy = 0Sum of Moments around origin = 0M = 0d) Calculating the unknown external loads and moments:Pilates Position:Fx = 0 = M*sin(60o) + W*cos(60o)M = W*cos(60o)/sin(60o)Fy = 0 = M*cos(60o) - W*sin(60o)W = M*cos(60o)/sin(60o)M = W*sin(60o)/cos(60o)Abdominal Sit-up Position:Fx = 0 = M*sin(30o) + W*cos(30o)M = W*cos(30o)/sin(30o)Fy = 0 = M*cos(30o) - W*sin(30o)W = M*cos(30o)/sin(30o)M = W*sin(30o)/cos(30o)e) Calcul
1. What are static loads on the human body?
Static loads refer to the forces and weight that act on the human body while it is in a stationary position. These loads can come from an individual's own body weight, external objects, or gravity.
2. How do static loads affect the human body?
Static loads can put strain on the muscles, joints, and bones of the human body, leading to discomfort, pain, and potential injuries if not properly managed. They can also impact posture and balance, which can affect overall movement and function.
3. What are some examples of static loads on the human body?
Examples of static loads on the human body include sitting for long periods of time, carrying heavy objects, and standing in one position for an extended period. Other examples include wearing heavy backpacks or carrying a heavy purse on one side of the body.
4. How can static loads be reduced or managed?
To reduce or manage static loads on the human body, it is important to take frequent breaks from static positions, such as standing up and stretching after sitting for a while. Practicing proper body mechanics, using ergonomic equipment, and maintaining good posture can also help reduce the impact of static loads.
5. Can static loads be harmful to the human body?
Yes, static loads can be harmful to the human body if not managed properly. Over time, repeated exposure to excessive static loads can lead to muscle strain, joint pain, and other musculoskeletal issues. It is important to be aware of and take steps to manage static loads to prevent potential harm to the body.
15K
  • General Discussion
