Stirling Engine Theory - Mechanically Driven
In summary, The conversation discusses the efficiency and potential applications of a Stirling engine, specifically in regards to utilizing solar heat collection. The idea of heating the cool side externally is proposed, which would result in more energy being collected, but at the cost of some energy. The conversation also mentions the use of a Rankine cycle for cooling at lower temperatures.
kintreemonkey
Hi,
I have had an idea floating around regarding stirling engines, and was hoping that somone may be able to provide some information.
Supposing a stirling engine is run mechanically, one side heats up, the other cools down.
what would happen if the cool side was heated externally?
afaik the cool side should act like a sink drawing heat from the surroundings, the purpose of the question relates to solar heat collection, supposing the receiver is kept cool, more energy could be collected? (in theory)
Science news on Phys.org
Yes more energy could be collected, but at the cost of some energy. The effect would be that the hot side could be maintained at a higher temperature, or if kept at constant temp the load produced by the sterling heatpump would be reduced. Once you heat the "cold" side above the warm side, of course you're back in engine mode.
Heat pumps heat their targets more efficiently than simply converting the input energy to heat. Of course if you heat the "cool" side you need to input less energy still since you're pumping up a shorter temperature difference.
The collected energy is still heat though and will have higher entropy per unit of energy than the prior external heat plus mechanical energy used to drive the pump.
As usual Wikipedia is your friend.
http://en.wikipedia.org/wiki/Applications_of_the_Stirling_engine#Stirling_cryocoolers
kintreemonkey, the Striling heat pump, as you suggest, has been designed and has several applications and is really nothing new. In your instance the cooling would be better served by a Rankine cycle. At your temperatures, the Stirling engine is less efficient, which is why one does not see a window air conditioner operating on the Stirling cycle. These use the Rankine cycle.
What is a Stirling engine?
A Stirling engine is a heat engine that operates by cyclic compression and expansion of air or other gas at different temperatures, resulting in net conversion of heat energy to mechanical work.
How does a Stirling engine work?
The Stirling engine works by using a temperature difference between two connected metal cylinders, with a gas such as air or helium inside. The gas expands and contracts as it is heated and cooled, which drives a piston back and forth, creating mechanical energy.
What are the advantages of Stirling engines?
Stirling engines have several advantages over other types of engines, including their ability to run on any fuel that can create a temperature difference, their high efficiency, low noise levels, and low emissions.
What are the applications of Stirling engines?
Stirling engines have a wide range of applications, including power generation, heating and cooling systems, solar power, and marine propulsion. They are also used in some automotive and aerospace applications.
What are the limitations of Stirling engines?
Stirling engines have some limitations, such as their relatively low power-to-weight ratio, which makes them less suitable for high-power applications. They also require precise engineering and can be expensive to manufacture.
  • Mechanical Engineering
  • General Engineering
