Stoichiometry applied to xN2 + yH2
In summary: We need to know how many moles of NH_3 are produced, and then we need to divide that number by the Theoretical-Yield to get theactual yield.
rijo664
25
6.0 moles of N2 that's are mixed with 12.0 moles of H2 according to the following equation:
The equation is already balanced:
N2(g)+ 3H2(g) yields 2NH3 (g)
The questions asks for what is the chemical in excess? is it H2 or N2
I solved the problem but i want to make sure if it is right. this is what i did
6.0 moles of N2 (2 mol NH3 / 1 Mol of N2)= 12 mol of NH3
12.0 moles of H2 (2 mol NH3 / 3 mol H2)= 8 mol of NH3
I believe the answer is N2 because given amount is 12.0 moles and i got 8 mol of NH3 is it right or wrong please tell me.
that is correct :-]]]
Let me ask u another question
Theoretically, how many moles of NH3 will be produced
I believe it's 2 Moles of NH3 because that's how many there are in the balanced equation. Is it right if so
How should i get the actual yield of NH3 if the percent yield is 80%, how many moles of NH3 are actually produced. I am kind of stuck here if the theoretical is 2 then how will i find the actual
I know the formula for percent yield is
actual yield/theoretical yield X 100
help would be appreciated.
the Theoretical Yield is calculated by determining which is the limiting reagent and how much of the product it will produce
the formula that relates the Theoretical Yield and Actual Yield is, % Yield = Actual/Theoretical
I believe the reagent is N2 (that's N and the subscript 2)
sorry i meant the Limiting reagent
still i don't get it, if the theoretical yeild of NH3 is 2 mol and the limiting reagent is H2 how is that suppose to work i don't get it.
[tex]N_2 (g) + 3H_2 (g) \rightarrow 2NH_3[/tex]
[tex]6.0 mol N_2 = \frac{2 mol NH_3}{1.0 mol N_2} = 12.0 mol NH_3[/tex]
[tex]12.0 mol H_2 = \frac{2 mol NH_3}{3.0 mol H_2} = 8.0 mol NH_3[/tex]
So, the since, Hydrogen gas produces the least amount of Ammonia, it is the Limiting Reagent. The Limiting Reagent also tells you the Theoretical Yield. The Theoretical Yield is simply the amount of Product that will be formed from the Limiting Reagent.
Thus, our equation that relates the 2 is:
[tex]\% Yield = \frac{Actual-Yield}{Theoretical-Yield}\times 100[/tex]
So we want to solve for Actual-Yield, it's basically plug and chug.
Related to Stoichiometry applied to xN2 + yH2
1. What is stoichiometry?
Stoichiometry is a branch of chemistry that deals with the quantitative relationships between reactants and products in a chemical reaction. It involves using the mole ratio of reactants and products to determine the amount of each substance involved in a reaction.
2. How is stoichiometry applied to xN2 + yH2?
In the chemical equation xN2 + yH2, stoichiometry can be used to determine the amount of reactants needed to produce a certain amount of product. It can also be used to calculate the amount of product that will be formed from a given amount of reactants.
3. What is the significance of x and y in the equation xN2 + yH2?
The values of x and y represent the coefficients or the number of molecules of each reactant involved in the reaction. They are used to balance the equation and determine the mole ratio of reactants and products.
4. How does stoichiometry affect the yield of the reaction?
Stoichiometry plays a crucial role in determining the theoretical yield of a reaction. The theoretical yield is the maximum amount of product that can be obtained in a reaction, calculated based on the mole ratio of reactants and products. Actual yield may differ due to various factors such as incomplete reactions or side reactions.
5. Can stoichiometry be used to predict the products of a reaction?
Yes, stoichiometry can be used to predict the products of a reaction by balancing the chemical equation and determining the mole ratio of reactants and products. This can help in designing and optimizing chemical reactions in industries and laboratories.
  • Mechanical Engineering
10K
