Strength of a bond in a molecule
In summary, the conversation discussed the calculation of the bond strength of a carbon monoxide molecule based on its reduced mass and absorption of infrared radiation at a wavelength of 4.6um. The equation u=(m1*m2)/(m1+m2) was used to calculate the reduced mass, and the equation v=1/2pi \sqrt{k/u} was mentioned for the frequency of vibrations. The force constant, k, was identified as the stiffness of the bond and can be calculated from the given data. The equation λ=2pic\sqrt{u/k} can then be solved for k to determine the bond strength.
solas99
69
Carbon monoxide molecule, which has a reduced mass of 6.85 amu, absorbs infrared radiation wavelength of 4.6um. if the absorption is due to vibrational transitions, calculate the strength of the bond in molecule
u=(m1*m2)/(m1+m2)
1. (12*16)/(12+16)=6.85 amu= 1.13e-26 Kg
here i calculate the reduced mass...but the reduced mass is given in the question! i just don't know what equation to use to calculate bond strength from wavelength and reduced mass..
there is another equation for frequency of vibrations: v=1/2pi [itex]\sqrt{k/u}[/itex]
but i don't know what k stands for? and how we calculate it
is there any other equation I am missing?
thank you!
k is called the force constant of stretching the bond between carbon and oxygen, and it characterises the stiffness of this bond. Search your notes what was called "the strength of the bond". You can calculate k from the given data. Remember that a vibrating molecule absorbs that radiation which frequency corresponds its vibrational frequency. ehild
E=h(n+1/2)w
is k the bond strength?
from equation λ=2pic[itex]\sqrt{u/k}[/itex]
do we then solve for K, to give the bond strength?
thanks a mill :)
Well, k is not the bond strength, but your book might call it so. Anyway, calculate it.
ehild
Related to Strength of a bond in a molecule
1. What is the strength of a bond in a molecule?
The strength of a bond in a molecule refers to the amount of energy required to break the bond and separate the atoms.
2. How is the strength of a bond in a molecule determined?
The strength of a bond in a molecule is determined by the type of atoms involved and the arrangement of the electrons between them.
3. What factors affect the strength of a bond in a molecule?
The type of atoms, the distance between them, and the number of shared electrons are all factors that can affect the strength of a bond in a molecule.
4. Can the strength of a bond in a molecule be changed?
Yes, the strength of a bond in a molecule can be changed through chemical reactions or physical processes such as heating or cooling.
5. Why is the strength of a bond in a molecule important?
The strength of a bond in a molecule determines the stability and reactivity of a compound, and can also affect its physical properties such as melting and boiling points.
