How Much Fresh Water Is Needed to Submerge a Submarine in Salt Water?
In summary, William Smith built a small submarine with a volume of 1.5 cubic meters and a buoyant force of 15,082.88 N. To keep the submarine submerged while transitioning from fresh water to sea water, an additional mass of 1,537.5 kg of fresh water must be added to the ballast, as the density of fresh water is 1000 kg/m3 and the density of sea water is 1025 kg/m3. This difference in buoyant force accounts for the additional mass needed to keep the submarine submerged in sea water.
b0r33d
William Smith built a small submarine capable of diving as deep as 30.0 m. The submarine's volume can be approximated by that of a cylinder with a length of 3.00 m and a cross-sectional area of 0.500 square meters. Suppose this submarine dives in a freshmwater river and then moves out to sea, which naturally consists of salt water. What mass of fresh water must be added to the ballast to keep the submarine submerged? The density of fresh water is 1000 kg/m3, and the density of sea water is 1025 kg/m3.
Cylinder volume = Base area x height
Buoyant force = Fluid density x Volume x Acceleration due to gravity (9.81 m/s2)
I found the volume, which is 1.5 cubic meters.
I then found the buoyant force, which is 15,082.88 N.
Then I tried to divide the weight of the fluid displaced, which is the buoyant force, by the acceleration due to gravity to try to find the mass...but that didn't seem right.
I got 1,537.5 kg, but if I try to find the weight, I'll just be back to the buoyant force...and if the buoyant force equals the weight of the object...the object is still floating.
There are two different boyant forces - one for sea water and one for fresh.
The difference between them is the extra mass you need.
Your calculations are on the right track. To find the mass of fresh water needed to keep the submarine submerged, we can use the equation: mass = buoyant force / acceleration due to gravity. In this case, the buoyant force is the weight of the fluid displaced, which is equal to the weight of the submarine. So we can rewrite the equation as: mass = weight of submarine / acceleration due to gravity.
Since the submarine is already capable of diving to a depth of 30.0 m, we know that its weight is equal to the buoyant force at that depth (15,082.88 N). Therefore, we can calculate the mass needed by dividing this weight by the acceleration due to gravity (9.81 m/s2). This gives us a mass of 1,537.5 kg, which is the same value you found.
However, the problem states that the submarine is diving in fresh water, which has a density of 1000 kg/m3. This means that the submarine is already slightly buoyant in fresh water, as its density (assumed to be equal to the density of water) is less than that of the surrounding water. So, to keep the submarine completely submerged, we need to add enough mass to make its overall density equal to that of the surrounding water.
To find this additional mass, we can use the equation: mass = volume x density. The volume of the submarine is 1.5 cubic meters, and the density of fresh water is 1000 kg/m3. So the additional mass needed is 1.5 x 1000 = 1500 kg.
Therefore, the total mass of fresh water needed to keep the submarine submerged in fresh water and sea water is 1,537.5 + 1500 = 3037.5 kg. This is the amount of additional mass that would need to be added to the ballast in order to keep the submarine submerged in both types of water.
What is a submarine?
A submarine is a watercraft that is designed to operate underwater. It is capable of diving and resurfacing by controlling its buoyancy.
How does a submarine stay underwater?
A submarine stays underwater by using its ballast tanks to control its buoyancy. When the tanks are filled with water, the submarine becomes heavier than the water and sinks. When the tanks are emptied, the submarine becomes less dense than the water and rises to the surface.
What is buoyancy and how does it affect a submarine?
Buoyancy is the upward force exerted by a fluid on an object that is submerged in it. In the case of a submarine, buoyancy is used to control its depth by adjusting the amount of water in its ballast tanks. When the submarine has neutral buoyancy, it will float at a specific depth without sinking or rising.
How is buoyancy calculated for a submarine?
The buoyancy of a submarine is calculated using Archimedes' principle, which states that the buoyant force on an object is equal to the weight of the fluid it displaces. In the case of a submarine, the buoyant force is equal to the weight of the water that is displaced by its hull.
Are there any risks associated with buoyancy control in a submarine?
Yes, there are risks associated with buoyancy control in a submarine. If the ballast tanks are filled or emptied too quickly, it can cause the submarine to rise or sink rapidly, which can put stress on the hull and potentially damage the submarine. It is important for the crew to carefully monitor and control the ballast tanks to prevent any accidents.
  • Mechanical Engineering
