How Is the Distance to the Seabed Calculated Using Sonar?
  • Thread starter Jess_18033152
In summary, the conversation discusses using a depth sounder on a ship to measure the distance to the seabed using sonar. The equation used is d = vt, with a speed of 1480 m/s and a time of 0.461 s. However, the correct equation is 1480 x (1/2 x 0.461) = 341 m, as the time given is for the pulse to reach the seabed and return to the boat, while we only want the time to reach the seabed.
Jess_18033152
32
A depth sounder on a ship measures the distance between the bottom of the ship and the seabed using a high-frequency pulse of sound (sonar stands for SOund Navigation And Ranging). Sound travels through water at 1.48 km/s.
Calculate the distance to the seabed if the reflected pulse is received 0.461 s after the sound is transmitted. Assume that the ship is not moving and that the transmitter and receiver are located at the same position on the boat. Also assume that the seabed is flat, so that the first reflection is received from the surface directly beneath the boat.
d = vt
v = 1480 m/s
t = 0.461 s
d = v t
= 1480 x 0.461
= 682.28 m
Is this the correct equation to use for this question, if not what equation should I use?
Jess_18033152 said:
d = v t
= 1480 x 0.461
= 682.28 m
This is the total distance traveled by the pulse. Is this the same thing as the depth?
The answer was using: 1480 x (1/2 x 0.461) = 341 m
That does not really answer the question if the total distance traveled is the same thing as the depth. The real question is not if you know what the answer is. The real question is whether or not you understand why the answer is what it is. What is the difference between your attempt and the answer? Why is it different?
Yes, it's half the time because we are only want the time to get to the sea bed, whereas we were given the time to reach the seabed and come back to the boat.
1. How is the distance to the seabed measured?
The distance to the seabed is typically measured using sonar technology. Sound waves are emitted from a ship or other vessel and the time it takes for the waves to bounce off the seabed and return to the ship is used to calculate the distance.
2. Why is it important to know the distance to the seabed?
Knowing the distance to the seabed is important for a variety of reasons. It can help with navigation, especially in shallow waters where ships need to avoid hitting the seabed. It is also important for activities such as offshore drilling, underwater construction, and mapping the ocean floor.
3. What factors can affect the accuracy of measuring the distance to the seabed?
Several factors can affect the accuracy of measuring the distance to the seabed. These include water depth, temperature, salinity, and the composition of the seabed. Changes in any of these factors can impact the speed of sound in water, which is crucial for calculating the distance.
4. How has technology improved the measurement of distance to the seabed?
Advancements in technology have greatly improved the measurement of distance to the seabed. Sonar systems have become more precise and can now provide detailed images of the ocean floor. Additionally, there are now autonomous underwater vehicles (AUVs) that can collect data and map the seabed without the need for human-operated vessels.
5. Can the distance to the seabed be accurately measured in all parts of the ocean?
In most cases, the distance to the seabed can be accurately measured using sonar technology. However, there are some areas of the ocean that can be challenging to measure, such as very deep trenches or areas with complex seafloor topography. In these cases, multiple measurements and advanced technology may be needed to accurately determine the distance to the seabed.
  • New Member Introductions
