The X3 sensor and the Sigma XD1
In summary, the Bayer filter only detects the total amount of light incident and it does not distinguish colors. Therefore, to generate a color image, sensor companies coat the sensor with an array of color filters, and the particular pattern has been standardized to a 'Bayer filter': Every other pixel sees green, and the other pixels alternate between red and blue. One important result from this is that the final image (say a color Jpeg file) has been produced by interpolating between pixels in order to appear that each image pixel has full color information. RAW images consist of the actual individual pixels and are used in more advanced photography, because each pixel retains its original identity and the photographer/print shop has more control over the final color print.
Andre
4,311
74
Andy has elaborated about photo sensors https://www.physicsforums.com/showpost.php?p=3091595&postcount=2. The essential part:
Bayer filter: the pixels only detect the total amount of light incident; they do not distinguish colors. In order to generate a color image, sensor companies coat the sensor with an array of color filters, and the particular pattern has been standardized to a 'Bayer filter': Every other pixel sees green, and the other pixels alternate between red and blue. One important result from this is that the final image (say a color Jpeg file) has been produced by interpolating between pixels in order to appear that each image pixel has full color information. RAW images consist of the actual individual pixels and are used in more advanced photography, because each pixel retains its original identity and the photographer/print shop has more control over the final color print.
This gives the impression that a lot is wasted. If a "red" photon happens to hit a blue filter, it's lost. So every "pixel" containing two green and a red and a blue part, only use their surface area of the pixel to detect that color. The rest is lost. Can we do better than that?
So that question was explored by Foveon, and the idea was that photons with different wavelenghts have a different penetration depth in a silicon sensor, so if you could measure this depth you could reconstruct the corresponding 'color'. That way you could use all photons that hit the sensor. Nothing is lost and you'd have a superior signal to noise ratio, as each pixel is using its full surface for all colors.
That's the idea behind the X3 sensor, which was used in several cameras, like the Sigma SD1, however the system was very expensive, only aimed at the professional market.
So there is a successor now, the Sigma SD1 Merril, which is actually in the price range of the Canon 7D/Nikon 7000/Sony A77. And indeed it's image quality is stunning compared to those peers, as can be seen here
You may want to move the crop around on the overview pic, (in the lower part of the Martini bottle label) to view different parts. For instance on the tree in the Bayleys bottle label, the portret in line drawings above Mickey mouse or the feathers to the right.
I wonder why the system, whilst using all the photons, does not hold up at higher sensitivities, where it lags behind, especially on color noise. Thoughts?
edit: sorry typo, the title should read "The X3 sensor and the Sigma SD1"
I've been watching the Foveon guys since, like, 2001. I have no idea why they never caught on.
It seems to be very lacking on color saturation and dynamic range. I wonder if stacking the sensors on top of each other leads to significant amounts of attenuation of green and red light.
1. What is the X3 sensor?
The X3 sensor is a type of image sensor used in cameras, particularly in the Sigma XD1. It is known for its unique design that allows it to capture three layers of color information, resulting in high-quality and accurate color reproduction in images.
2. How does the X3 sensor differ from other sensors?
The X3 sensor differs from other sensors in its design, as it utilizes three layers of color information instead of the traditional single layer. This allows for better color accuracy and detail in images, making it a popular choice among photographers.
3. What are the benefits of using the X3 sensor in the Sigma XD1?
The X3 sensor offers several benefits when used in the Sigma XD1, including better color accuracy, higher resolution, and improved image quality. It also allows for better noise reduction and low-light performance.
4. Can the X3 sensor be used in other cameras besides the Sigma XD1?
Yes, the X3 sensor can be found in other cameras, but it is mainly used in Sigma cameras. The unique design of the X3 sensor is proprietary to Sigma, making it exclusive to their cameras.
5. Is the X3 sensor a new technology?
The X3 sensor was first introduced in 2002, making it over 18 years old. However, it is still considered a groundbreaking technology in the world of digital cameras and is continuously improved and used in newer Sigma models.
  • Computing and Technology
  • General Discussion
  • Other Physics Topics
  • Mechanics
12K
